32bit vs 64bit
Is there a big difference it the two? Would I really benefit with a switch to 64? What I have found out so far is that 64bit is better for graphics and video and not so much for applications. I just got my system in Feb of 2008, Vista 32bit, HP media center m8300f w/tv tuner, 3gigs ram, 640gigs hdd, 3.0ghtz AMD Athlon 64 x2 6000+ processor. I couldn't pass it up as it was a bundled deal w/monitor(HP) and a all-in-one printer (HP).
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
Hi Bassfisher,
If you have 64 bit versions of your device drivers, then yes you would benefit from using 64 bit vs 32 bit. Since the computer is new, you should have these versions available to download from the computer manufacturer's website.
Here's something to read that can help explain the differences in more detail:
http://www.vistax64.com/vista-news/99613-64-bit-more-than-just-ram.html
    Acropolis
    Intel Core i7-6800k @ 4.0 GHz
    ASUS X99-M WS
    32GB Corsair Vengeance 2x16GB
    ASUS GeForce GTX 1080 STRIX
    ASUS ROG Swift PG278Q
    2x 256GB Samsung 850 Pro (RAID 0) 1x 500GB Samsung 850 Evo 2x Western Digital RED 4TB (RAID 1) 50TB File Server (Multiple RAID 6)
    Corsair AX1200i
    Corsair Air 240
    Logitech G502
    Razer Blackwidow X Chroma
    250Mbps Down | 15 Mbps Up
monitor is a HPw1907 lcd (19") and the printer is a HP desk jet F4180 all in one print, scan, copy. Priced individually I would have spent $1250.00 but paid... wait for it.... wait for it....$850.00. That was piecing it from best buy, walmart and circuit city. who every had the cheapest part.
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
What do you use your PC for?
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
