8800 GTS 640mb or 8800 GT 512mb SLI?
splosher
Power User
Hi
I run a single BFG 8800 GTS 640mb OC2 in my PC at the minute due to using an EVGA 650i Ultra board - which has a single PCI slot - but have just bought a Asus 680i SLI board, so i'm wondering if it may be time to upgrade from my single card to dual cards?
The 8800 GTS i have is fantastic and i don't really see any problems with it: apart from Crysis and the snow levels that is, but i think everyone has problems with that anyway. I know the 8800 GT cards are the next GPU die (G92) and are cheap enough to justify SLI, but will i see a massive increase over what i'm playing with at the minute? I only usually play at 1280x1024 anyway due to burning out my Gainward Golden Sample 7800 GTX whilst running HL2 at 1600x1200 and so it's better to be safe than sorry (and out of pocket £300!).
Also, i'm wondering about power consumption with 2 cards and also the extra heat due to the single slot designs. Any advice would be helpful.
    [email protected]tock
    Asus P5N32-E SLI
    4GB Geil DDR2 PC6400 CAS4
    1 x BFG 8800 GTS 512mb OC
    2 x 80Gb Samsung SATAll in RAID 0
    2 x 80Gb Maxtor SATA1 in RAID 1
    1 x 120Gb Maxtor SATA1 back-up
    Bt Broadband, so about same as 56k modem!
splosher
Power User
Come on - anyone give me some advice please?!
    [email protected]
    Asus P5N32-E SLI
basty_goofy
Well, you shouldn't buy the 8800 GTs with the standard single-slot cooling system. During the holidays it was madness here in Romania, you couldn't find ONE 8800GT in stock. The only ones available were Palit standard-frequency 8800GT. After a lot of thinking I bought one and I can say I am super happy. It has a double-slot cooling system, HUGE cooler over the chipset and a HUGE radiator over the VRAM. Even this way, it's super silent. The case fan runs louder.
I recommend you buy 2x8800GT Palit Sonic(factory overclocked). Nice, sturdy and quiet cooling system plus amazing performance. One Sonic GT beats a stock GTX, no questions asked(I mean this from a price point of view). Imagine two...
The resolution wasn't the reason your video card malfunctioned. If you would of used 1280x1024 it would still of malfunctioned. It was doomed from the beggining. Maybe it was OCed too much? Use 1600x1200.
As for the PSU. I reccomend you get a 650W power supply unit. If you think it's to expensive, I recommend an expanding PSU. This should do the trick.
I hope I helped you.
splosher
Power User
Well i made the decision and bought a BFG 8800 GTS 512mb OC to replace my BFG 8800 GTS 640mb OC2 card and even though i had reservations due to dropping 128mb of video RAM, i can honestly say it's the best decision i've made. Seeing this new card running Crysis is a great improvement over the 640mb card, especially when the snow levels come due to the higher pixel pipelines and i've also been able to raise my resolution in all my games - COD4, Oblivion, STALKER, BF2 & Crysis - from 1280 x 1024 to 1600 x 1200.
To anyone thinking about the upgrade - don't think, just do it! I'm saving now for my 2nd 8800 GTS 512mb to go SLI...
    [email protected]
    Asus P5N32-E SLI
NiTaS
You're going to hate yourself soon; the 9 Series GeForces have been annouced and the 9800 cards are set for release in March :P
I was going to buy a 8800GT for myself (approx. 33000 Yen or $330 USD), but I'm holding off till the new cards come out :D
NiTaS
That would be in a month or two, seeing how fast the GFX cards are released =D
Although I'm not complaining, good time to be young :D:D
Keket
I just bought an 8800GT about a month ago. It had to be done though, I couldn't wait. My motherboard fried and it was impossible to find good to better specs with the current 939 socket I was running. Rebuilt the entire system.
grimreaper
PaSSiOn 4 ViSta
Vista Pro
I have the evga's 8800 GTS SSC 640Mb playing Crysis...and I'm amazed, well...that's about to change ...ordered BFG's 8800 GTX OC2 768MB card...savin up for SLi combo...wohoohoo
Just get what ever makes you happy:)
    custom of course...
    Intel Quad Q9650 3.00GHz
    EVGA 790i Ultra 3-way SLi
    1920X1080
    Thermaltake Armor 6000BWS
    ThermalTake MaxOrb CL-P0369
    10 Mb/sec DL - 1 Mb/sec UL
    D-Link DGL-4500 Extreme N wireless router ...siiick:)
    2XSamsung SH-S223Q/BEBN SATA LightScribe
    1XLG GGW-H20L super-multi Blu-Ray burner
    Belkin UPS F6C1500TWRK
    Pioneer 7.1 Channel HDMI Receiver (VSX-9130TXV-K)
splosher
Power User
And whatever you can afford! 2 GTX OC2's are touching £600!
    [email protected]
    Asus P5N32-E SLI
Donovan
I'm still reasonably happy with my 8800 GTS 640. I haven't played Crysis since the demo came out, and pretty much everything else I play doesn't even compare to that level of complexity and strain on the card. Maybe I'll upgrade after the 9-generation stuff calms down some.
splosher
Power User
OP should have bought the eVGA Card with the Step-up Program. That way he will be ready for the 9800 GTX.
Very happy with the BFG 8800 GTS 512mb OC at the minute and will be going SLI in a couple of weeks, so no need for a 9800 GTX for at least 12 months. I can run Crysis on high with textures and object detail to very high comfortably at 1280x1024 using the task manager tweak and this is the most demanding game by far, so i am not fretting regarding a new GPU.
Also, have checked out the reviews for the 9800 GX2 and it's nothing special at the minute due to the 512mb per core and phenomenal power supply demands!
    [email protected]
    Asus P5N32-E SLI
JinkoMK
Well the GTX won't be coming out for a while. =] Stupid motherboard... I knew I should have gone with a SLI motherboard. My 8800GT is doing fine though. How's Crysis? Got bored with it after a few hours.
roy69
47,65,65,6B
look at it this way. Price up two cards in sli mode. Buy a duel gpu card which will be cheaper than two sli cards.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
splosher
Power User
No it won't be cheaper with the additional cost of a 750watt or more power supply added on top. I can get a 8800 GTS 512mb card for around £170/ £180 UK pounds, so £350 for 2, ok? A 9800gx2 is over £400 then another £100 for a power supply!
Crysis is brilliant if you can run it around 25fps and accept it isn't as free-roaming as the developer suggested.
    [email protected]
    Asus P5N32-E SLI
roy69
47,65,65,6B
What are your system specs at the moment?
How much money are you willing to spend?
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
