Solved a bit off but i learned the hard way
pacinitaly
HappyGuru Lovin2Help
Hi all,
I have an old cordless phone ( at least I guess it is ) it's a 2.4 ghz. I just noticed when I make a call I lose wireless internet connection.
has this happened 2 any1 else?
( i have made many calls and long ones at times but I just noticed it happened today and verizon said I have to get a 5.8 ghz phone.
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
Yes, one of my wireless (not cell) phones used to kill my 802.11 wireless network. Hang up the phone and it would come right back. The phone was stepping all over the signal. I ended up changing the channel the router used for wireless and that fixed it. I went from channel 5 to channel 11, which worked for me because there weren't any other 802.11 wireless networks around. Try changing channels and see what you get.
pacinitaly
right on Badcat!!!!!!!!!!!!!!!!!!!!!!!!!!
I called verizon again and they had me do just what you said. ( i did it B4 the even got on the line ) they also had me change something else to auto but i forgot .
thank a whole gigabyte
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
How did you manage to change the channel the router used???
Did you just get a new router?
:D:D
    Toshiba Satellite Pro l300
    Intel(R) Celeron(R) CPU 550 @ 2.00GHz
    Intel Corp. 88395664Q
    DDR2, PC2-5300 (333 MHz), 1024 MBytes, Hyundai Electronics,DDR2, PC2-5300 (333 MHz), 2048 MBytes, Ap
    Realtek HD Audio
    Matte screen
    1024 x 768 x 4294967296 colors
    120gb SATA 2.5inch FUJITSU MHZ2120BH G1 ATA Device
    Notebook
    Fan cooled
    Logitech Cordless Optical
    Logitech Cordless Desktop EX110
    256Kbps
    I like Spore,Rabbits and I'm a Computer Freak.
I use an Airport Express which has the ability to change channels built into it. I believe most wireless routers will have this function buried somewhere in their setups. Even an old Linksys 802.11 B access point had this ability built in. Check out your routers set up screens or google for instruction for your particular router. It can probably do this. Good luck!
pacinitaly
verizon is sending me a new router on monday
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
