"A problem caused the program to stop working correctly..."
roach_779
18
I sometimes get the following pop up error when playing World in Conflict:
The message would pop up then shut the program. I think the program does hangs and will resolved itself, but Vista (64) is too quick in shutting program.
Is there a way to shut off this feature?
Thanks
x24_vista
5
I'm not quite sure how to shut off that error message, but I had the same problem and resolved it by running it in compatibility mode for Vista 32 bit of Xp (SP2).
you can do this by:
(1) right click on the program
(2) chose properties
(3) click on the compatibility tab
(4) check "run this program in compatibility for:"
(5) select xp or Vista 32
This should stop WIC from crashing and resolve your problem.
The problem is that WIC does not support Vista 64
