A Tool That Can Control Fan Speed On Motherboard Help Pls..
Patonb
Hmm, it all really depends on the mother board, and I'm thinking as it's an hp, you can't. However case fans spin at max rpm by default, with most folks slowing them down with the use of inline resistors.
You can try speedfan, it may do something.
Download SpeedFan - Access temperature sensor in your computer
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
XGenius
Power User
You could try looking at your BIOS. I tried using speedfan and it works fine but not the best. It could have a more user-friendly interface. I had a little trouble setting it up. I do like looking at code, but not when I don't understand it!
    HP Compaq Presario C700
    Intel Pentium Dual Core T2370
    HP 30D9
    2GB 677Mhz
    Mobile Intel 965 Express Chipset Family
    Conexant High Definition SmartAudio 221
    WDC WD1200BEVS-60UST0
