about deleting recovery drive
im having 160 GB HDD and in that 10 GB has been allocated to the recovery and i dont want it as i want to save it in the DVDs.please help me out in deleting the that drive and also help me how to store recovery in the discs..
thanks
Who is the manufacture of your computer.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
vicber
you can create Recovery Disks, then recover your 10Go
I did it , I now have two Recovery DVD's (Dual Layer), and already used them several time after having reformatted my HDD
Worth doing it!
vicber
    HP TouchSmart IQ818d
    Intel Core 2 Duo T8100@2.1GHz
    Pegatron IMISR-CF
    4 Go 200 pin DDR2 SO-DIMM
    NVidia GeForce 9600M GS 512 Mb DDR3
    SoundMAX Integrated High Definition audio
    25.5 inch
    1900 x 1200 @ 60Hz
    -640 Gb SATA 3G
    -2Tb LaCie FW400
    -500 Gb Linksys MediaHub NMH405
    -2x1Tb WD MyBook Home connected on WD TV
    Starhub MaxOnline Ultimate 100Mb - Paying USD 66.00 for that
Bare Foot Kid
R.I.P. August 13th 2014
Hello harsha.
Look in the start menu under HP; just look around in there till you find it; there'll be an option to create a set of recovery discs. Just be sure you get a good copy the first time as you only get one chance to create them.
Then after you have created the discs; have a look at this tutorial; at the link below to delete the partition.
http://www.vistax64.com/tutorials/95418-disk-management-delete-extend.html?ltr=D
Keep us informed!
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
harsha, click start then all programs then scroll down to PC help and tools then in there will be Recovery Disc Creation and click on that and follow the directions to make your recovery disc's you will need DVD-R disc's for it to work. Then after making the disc's you can in the same area of the start menu click on Recovery Manager then click on advanced options then a list will come up and dot the last one and it will remove the recovery partition.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
Bare Foot Kid
#8
Hello mansrm....:)
Thanks, since I installed 64-bit Ultimate and deleted all the HP stuff; I don't have the HP information I used to have for reference and I couldn't remember where it was.
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
#9
Hey Ted,
That's one thing about keeping my HP going cause I always forget stuff and have to actually do what people are asking help for.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
#11
That brings up a related topic/inquiry...can it be re-installed without clean system re-installation? Like through System Restore?
    HP Pavilion dv7-1170us
    Intel Core 2 Duo T5800 @ 2.00GHz
    Compal
    NVIDIA GeForce 9600M GT
    1440 x 900
    289.09 GB
    Synaptics PS/2 Port TouchPad
    IBM enhanced (101-or 102) keyboard
    cable Wireless
Bare Foot Kid
#12
Hello CNY.
If you're referring to doing a "System Recovery" from either the recovery discs or the recovery partition; the answer is no, it's 'clean' all the way.
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
#13
thanks a lot man its helpful..thanks.:)
