Accidentally encrypted my certificate
I encrypted the /Users/{username}/AppData/Roaming folder, which, I discovered afterward, contains the certificate needed to decrypt it. I have not forgotten the password used to encrypt and to login. Is there any possibility of decrypting the folder or the certificate?
    Lenovo 3000 N100
    Intel Core Duo T2350
    2.5 GB
Lorien
Account Suspended
I'm not sure if this will help, but it's an excellent tutorial on the subject: http://www.vistax64.com/tutorials/99959-encrypt-decrypt-folder-file.html. Reading it, you may note at the beginning there is a link to a 3rd party program (it's a trial version so use it to fix the problem and then cancel the trial) for difficult situations and yours seems to fall into that category. You can check the rest to see if anything helps, but I suspect you'll end up coming back to needing this program. There's no guarantee it will work (although the list of what it can do is impressive, it doesn't specifically include encrypting the certificate - but it's certainly worth a try).
I hope this helps.
Good luck!
    1920 x 1200 pixels
    Dell AIO Printer A940
    6TO4 Adapter
    Microsoft ISATAP Adapter
    Router Linksys / WRT54G -01
I encrypted the /Users/{username}/AppData/Roaming folder, which, I discovered afterwards, contains the certificate needed to decrypt it. I have not forgotten the password used to encrypt and to login. Is there any possibility of decrypting the folder or the certificate?
I know what you mean. It was the %AppData%\Roaming\Microsoft\Crypto that has caused the problem, and you know it! As I think you already know, that file stores the local key containers. Hopefully the above link will work, otherwise we will have to think about other strategies. I suppose you could try a System Restore, although I am not too sure that this will fix the problem.
Have you tried to just decrypt it? I see your problem though.
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
