Solved Acer Aspire dark screen
STU9000
My mother is having problems with her laptop, she said she could shut it down last night so unplugged it and left it over night, and today when she started it up everything was fine apart from a dark screen.
I have been on teamviewer trying to get to the bottom of it. Fn and arrow keys apparently adjust the brightness temporarilly but it just defaults back. I ran some windows check for solutions and it threw up this warning which indicates to me it could be a video card issue.mum.JPG
It also said something about Skype, so I updated that. I ran CCleaner and the SF_diagnostic tool. I have attached the zipped file to this thread. can anyone offer any insight to the possible cause of this because I'm stumped?View attachment STU9000.zip
She is using Vista.
Patonb
hAVE YOU TRIED , oops, to update the drivers?
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
    Country Flag
    canada
STU9000
Did think about that actually, but I'm trying to fix this from several hundred miles away. Which drivers, the video card? wouldn't windows update deal with that? What about the SF diagnostic tool?
My incline at the moment is to think it may be some failed/failing hardware, ie the back light or a loose cable inside. It's 7 years old and I had it open a coueple of years ago trying to find to bodge it so I could do a full reinstall.
Patonb
If it's hardware, it's most likely the inverter or back light, but I believe there's 2 lights possibly.
I do think you are correct on a hardware isue, She could connect it to a monitor or tv even, and check if it works. An S-video cable is needed for the tv.
    Country Flag
    canada
STU9000
Well I sort of deduced, correctly or incorrectly, that if her screen looked fine on my monitor through teamviewer then it's likely that there is no problem with the video card and that it's the back light or the inverter?
Patonb
Not sure a gpu issue would show through team viewer. Connecting to a external would show if its gpu or monitor.
    Country Flag
    canada
STU9000
Well I finally got to the bottom of the problem when I was down visiting. Turns out, when I said press Fn and left and right arrow keys she was pressing all three at the same time. I simply turned the brightness back up using Fn and >
That's all it was:-/
Patonb
Sounds good.. And a lot cheaper than a hardware replacement.
    Country Flag
    canada
