Admin rights for a single program to standard user
pnpatel11
We have installed a SmartMusic program for my son's Trumpet practice.
However, it runs on his user login, only if I grant him admin rights.
I do not want to grant him admin rights to the laptop, but cannot find any way to grant just that particular program to run as admin on his login...
Can someone help? Its a Vista Home version of Windows...
    Acer
    Intel Pentium
    2GB
richc46
Welcome
You can give this a try and hope. The run as adminstrtor feature was put there by the software and not Vista.
You can turn off the UAC
http://www.vistax64.com/tutorials/48893-user-account-control-uac.html
Then right click on the software, probably properties, then advanced (or compatibility tab). In Compatibility or advanced tab. check run as administrator
Let me know how that works.
When you right click on the software, type in the software name in the search function by stat button, and then right click when it pops up. Do not click on any shortucuts.
For smart music rather than advanced, it might be under compatiblity tab.
If you do disable UAC, all Administrator users must exercise caution. The UAC is a warning that changes will be made to the system and not just to user account
nostaw5
"POW" Ur dead
Power User
what you can do is right click on the program shortcut on your sons desktop OR go to program files and right click the .exe and click properties. Then go to the security tab and navigate to group or user names and click your sons. then click "to change permissions" click edit. Check the boxes that come up:
Full Control (not of the computer but the .exe so he can use it.)
hope that helps.
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Mouse
    Logitech K120 Wired Keyboard
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6
    Thomson A/B/G/N Router
    LiteON CD/DVD Player
    GAME PERFORMANCE:
    Battlefield 3: 41 FPS High 1x AA @ 1280x720
    Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080
    Counter Strike Source (and other Valve games):
    300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
