Adminstrator password
baptiste
I have recently started using an old pc which has vista home premium installed. My son owns the pc but unfortunately he cannot remember him administrator password which means I am unable to make any changes to the pc. Can anyone help me get over this issue?
Thanks
    vista home premium
What kind of changes do you want to make? To run most executables, you can right click on them and select "run as administrator."
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
I am unable download AVG ect, as soon as I try the pc throws up the administrator password prompt and there are several others upgrades I wish to make as well as delete some old programs
    vista home premium
Have you considered doing a clean reinstall ?
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
The Windows Help files provide instructions for creating a password reset disc. However, it indicates that's for the situation in which you can't log onto the computer because you forgot your password. That doesn't seem to be the case here so I don't know if the disk would work. The Help also indicates-
"What are the risks of resetting a password?
If you use an administrator account to reset the Windows‌ password for any other user account, the account with the reset password will lose access to its encrypted files, e‑mail messages that are encrypted, and stored passwords for websites or network resources. If the user account doesn't have any of these things, or the user doesn't mind losing them, then using an administrator account to reset the password is a fast and easy way to recover from a forgotten password."
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Any progress on this?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
I am unable to do a reinstall as the version of vista was installed on the pc and he has no disk available
    vista home premium
"an old pc which has vista home premium installed."
Is there a recovery partition?
Or you can find vista installation media easily.
What is the bit version and language?
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
If you reinstall, you will need to reactivate. Do you have the coa sticker that is readable?
What is the exact make and model of the machine?
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
You are not supposed to broadcast the coa. You can use it to activate vista if you have to clean reinstall.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
@baptiste
There is a tutorial here which might help you
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
