Solved Adobe Shockwave 11.5 & Adobe Flash 10 - do I need?
meltie
Power User
All,
Please forgive my non techie ignorance here. Why do I need these?
P.S. My system is Vista Home Premium 64-bit with NVIDIA
I ask because when I go into Programs and Features, neither of these are there.
I do have an Adobe Flash Player 10 ActiveX and an Adobe AIR (whatever that is).
I also now have an Adobe Download Manager which came when I downloaded the subject two programs.
NOTE: The Flash Player shows as a plugin on Firefox
ALSO: The site told me to uninstall the older versions of these two programs prior to installing the new, but I don't have an older version of either
This came about because I was having a problem with a game that worked until after I installed the latest NVIDIA driver. The game manufacturer told me to install both of these as a measure to correct the issue. It didn't correct it BTW. Other games still work fine.
Soooo, do I remove these two items or leave them as added value for other programs?
Thanks for your help.
Meltie
    HP
    NVidia
osholt
Magister mundi sum!
re: Adobe Shockwave 11.5 & Adobe Flash 10 - do I need?
Hi, Adobe shockwave and flash are fundamental for experiencing the whole Internet.
Without Shockwave and flash almost no Internet games would work, most online Videos won't work (YouTube won't work unless you ask it to load the movie in HTML 5 from youtube.com/html5) and tons of other stuff wouldn't work to its full potential.
You can live without these 2 plugins from Adobe (1 of my friends doesn't have them installed for moral reasons) but I wouldn't recommend it until HTML 5 really becomes wide spread.
Oli
    Apple MacBook, 5,1
    Intel Core 2 Duo 2.4Ghz
    4GB DDR3
    Nvidia 9400m
    13.3" Apple MacBook LCD Screen + 22" HannsG DVI LCD + 21.5" Samsung USB Lapfit Monitor LD220
    1280x800 + 1920x1080 + 1920x1080
    SATA Internal 2.5" 500GB (305GB HFS+, 195GB NTFS)
    External USB 3.5" 1TB (HFS+)
    Aluminium Unibody
    Apple Magic Mouse
    Apple Late 2009 Wireless Keyboard (US)
    6.33Mb/s up. 0.36Mb/s down.
    Harman Kardon Soundsticks II Speakers
meltie
Power User
Interesting. I've viewed movies from YouTube without doing anything special and they worked. I wonder if I have another program that allowed me to do this or if it's an older version of Flash and Shockwave and I just don't see them. Is that likely?
These won't cause conflict with anything else will they?
If not, it sounds like I should keep them - yes?
Meltie
    HP
    NVidia
osholt
Magister mundi sum!
Flash and shockwave shouldn't conflict with anything.
I might suggest that you update them both because older versions of flash have known security holes, but you don't have to if you don't want to.
I would definitely leave them installed.
Oli
    Apple MacBook, 5,1
    4GB DDR3
    Nvidia 9400m
    Aluminium Unibody
    Apple Magic Mouse
meltie
Power User
OK. Thanks very much
Meltie
    HP
    NVidia
osholt
Magister mundi sum!
No problem :). I'll mark this solved.
Oli
    Apple MacBook, 5,1
    4GB DDR3
    Nvidia 9400m
    Aluminium Unibody
    Apple Magic Mouse
Airbot
I marked it solved 5 days ago. :sarc:
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    [email protected]
    1 OCZ Vertex2 180GB SSD
    Pioneer DVD Burner DVR-S18M
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
    Windows 7
    W.E.I final score= 7.7
    Windows Vista=5.9
osholt
Magister mundi sum!
    Apple MacBook, 5,1
    4GB DDR3
    Nvidia 9400m
    Aluminium Unibody
    Apple Magic Mouse
