AHCI drivers for Vista x64 ultimate
ArkaPro
5
Hi all,
I run hackintosh so I need to set the SATA to AHCI.
I installed XP PRO with no problem using the F6 Floppy drivers.
after that I installed vista x32 with the drivers from intel's web site with no problem.
Now I wanted to move and install a fresh copy of VISTA ULT x64bit
but I can't install the proper driver for it.
I dloaded the [FONT=Arial,helvetica]64-bit Floppy Configuration Utility for Intel® Matrix Storage Manager[/FONT][FONT=Arial,helvetica] (227KB) [/FONT][FONT=Arial,helvetica]8.2.0.100
Copied the driver to USB disk.
but when I tried to "LOAD DRIVER" during VISTA's install I loaded the ICH9 driver
After that I got the message "NO DRIVES WERE FOUND"
WTF?
Why am I having trouble installing the x64 version?
can anyone direct me to a proper driver for 82801IR controller - vista x64 driver!
damn!
BTW I did manage to install this Vista x64 in IDE mode...
HELP!
[/FONT]
    Core 2 Duo E6600
    Intel 975XBX2
    8GB's of DDR2 800
    Radeon 3870X2
    HT Omega Claro
    Viewsonic VG2030wm Widescreen LCD
    1680X1050
    120GB
    200GB
    320GB
    ThermalTake Toughpower 700
    Antec P182
    four 120mm fans
    Microsoft Wireless Intellimous Explorer 2.0
    Microsoft Natural Multimedia Keyboard
    10MB
    16X LG DVDROM & LG Dual Layer DVD Burner
    Logitech X-540 speakers
ArkaPro
5
First thing, thanks for the quick replay.
I Guess I can install Vista x64 this way - but Isn't there a simple way to just load the proper AHCI driver during install (like I did in XP and Vista 32)?
I mean, its really awkward, to install in IDE mode - only to change it to AHCI after that.
Even more important - say I do have it your way - will my system be stable?
Will it affect the stability or performance?
Thanks! :)
Just follow the instructions on the Microsoft Knowledge Base page below. They will tell you to enable AHCI via a registry edit, then you reboot and turn on AHCI mode in the bios for your motherboard. I've done it this way many times and it works.
Error message when you start a Windows Vista-based computer after you change the SATA mode of the boot drive: "STOP 0x0000007B INACCESSABLE_BOOT_DEVICE"
You should be able to press F6 on your keyboard, and then it should ask you to install the driver, but make sure you have AHCI mode enabled in the bios, when you attempt this, as Microsoft will first install a generic AHCI driver.
    Core 2 Duo E6600
    Intel 975XBX2
    8GB's of DDR2 800
    Radeon 3870X2
    HT Omega Claro
    1680X1050
    120GB
    200GB
    320GB
    Antec P182
    four 120mm fans
    10MB
ArkaPro
5
I'm feeling stupid.
I gave up trying to load a AHCI driver during install.
So I said to myself lets try something else.
I just installed Vista x64 ult. sp1 in AHCI mode. without loading any driver.
Windows installed itself with no problem!
after the install I got the messsage "competability ICH9 issue" and a window popped to download the latest intel chipset driver.
I installed it - no prblm.
everything works great!
in AHCI mode.
Didn't need to load any driver at setup!
Thanks but I guess problem solved...!
You're welcome. It's good to see you got AHCI working, but for some reason my soundcard does not get along with AHCI.
    Core 2 Duo E6600
    Intel 975XBX2
    8GB's of DDR2 800
    Radeon 3870X2
    HT Omega Claro
    1680X1050
    120GB
    200GB
    320GB
    Antec P182
    four 120mm fans
    10MB
ArkaPro
5
Weird, do you run the latest sound drivers?
is it on board?
which board?
I don't see any connection between AHCI and Sound
Are you sure its an AHCI problem?!
It happens with both my HT Omega Claro or the onboard IDT 9247 7.1HD codec.
When running AHCI the sound stutters. I expierenced this on two ATI/ULI motherboards a couple of years ago, and it happens with AHCI on my board now.
I'm running the latest drivers, which is why I suspect the AHCI drivers are at fault. I have no problems when in IDE mode.
    Core 2 Duo E6600
    Intel 975XBX2
    8GB's of DDR2 800
    Radeon 3870X2
    HT Omega Claro
    1680X1050
    120GB
    200GB
    320GB
    Antec P182
    four 120mm fans
    10MB
johngalt
Antidisestablishmentarian
3,922
Location
3rd Rock
#10
    Windows 10 Insider Preview current build
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Classified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    SanDisk Ultra SDSSDHII-960G-G25 SATA III SSD (System)
    Crucial MX100 CT256MX100SSD1 SATA III SSD (User Tree)
    2 * Seagate Barracuda 7200.12 ST31000528AS SATA II
    Seagate ST1500DL001 7200 RPM SATA II
    Intel SSDSA2M080G2GC SATA II SSD
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    300+ Mbps downstream / 30+ Mbps upstream
    Windows 10 Insider Preview (current)
    Dell Inspiron 3521
    Intel(R) Celeron(R) CPU 1007U @ 1.50GHz
    Dell
    Intel(R) HD Graphics
    Intel(R) Display Audio | Realtek Audio
    Inspiron 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Dell
    Dell
    Dell
    Logitech MX Master | Synaptics TouchPad
    Dell
    300+ Mbps downstream | 30+ Mbps upstream
#11
I went back to IDE long time ago. I don't really use or need hot plugging or NCQ. I suspect something in the AHCI drivers as causing what I expierenced, but I don't know what though.
    Core 2 Duo E6600
    Intel 975XBX2
    8GB's of DDR2 800
    Radeon 3870X2
    HT Omega Claro
    1680X1050
    120GB
    200GB
    320GB
    Antec P182
    four 120mm fans
    10MB
johngalt
3,922
Location
3rd Rock
#12
Quite possibly the Native Command Queuing.....
    The Beast Model V
    2 * 1920 x 1080
    Logitech MX Master
    Dell Inspiron 3521
    Dell
    Inspiron 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Dell
    Dell
    Dell
    Dell
