Solved alphabetical order on files
6
Hey gang, i'm looking for a way or program to arrange all my files in "documents" into alphabetical order. I don't want to do it manually cause i have over 300 files which i use to fight Maleware . Any Help ??
Vista on a HP
Thanks
Chuck
richc46
Staff member
20,105
Location
Fairfield County, CT
Welcome
Go to doucments
right click on blank area then
sort by
Lorien
Account Suspended
2,212
Location
Laytonsville, Maryland, USA
You can also open Documents and click on the item in the Title bar (in this instance, Name) by which you want to sort and it will sort it all automatically that way - first folders and then files (but not combining the two together). To reverse the order, just click that header again and it will sort the other way. You can choose any item listed in the title bar (or, if you want, add more by right clicking on the title bar and clicking more and adding additional categories as you desire).
As with most things in Vista, there are often several ways to accomplish the same task.
I hope this helps.
Good luck!
    1920 x 1200 pixels
    Dell AIO Printer A940
    6TO4 Adapter
    Microsoft ISATAP Adapter
    Router Linksys / WRT54G -01
richc46
Staff member
20,105
Location
Glad that we were there for you
As an added note, all the notes and software will not keep you safe; common sense is essential
You may, also, want to download and use winpatrol
Its free, if anything is downloaded, within minutes Scotty the Dog barks so you know and can accept or reject.
One of the best Security people, Corrine, uses it all the time
Has many other features, too.
Thanks for the rep.
