You should upgrade or use an
alternative browser .
AMD Phenom x64 Vista Problem
PROBLEM SOLVED AMD Phenom x64 Vista Problem
Hi Just bought a new pc with four 2.5 amd phenom sticks but only 1 is showing up on my systems tab.But in device manager it shows the four of them how do i get all of them working so i have 10.0 processor speed any help helpful thanks j
Palicomp
2.50 but supposed to be 10.0
8 gb
NVIDIA GeForce 9500 GT
1 internal 500gb a external 500gb
Galaxy 3
Palicomp Fans
Cheap
Cheap
8mb
I Tunes hates Me
first of all mate you wont have 10Ghz processor speed you will have 4 x 2.5Ghz , quad core processors dont work that way mate :D
download this
CPUID it will tell you all you need to know , heres a screenie of mine so you can see what i mean . notice the "cores" bottom right......
XFX 780i
4GB OCZ PC2-8500C5 DDR2
Gainward GTX260/216 SLI
Creative X-FI Xtreme Gamer
Dell UltraSharp 2209WA 22"
OCZ Modstream 700w
Titan Fenir
Razer Reclusa
Logitech G5 Gamer
8mb
So Are you saying even though my sytem only shows 2.50 im actually get the speed i should
Palicomp
8 gb
Galaxy 3
Palicomp Fans
Cheap
Cheap
8mb
yes thats correct
my AMD X2 shows only 2.6 but thats the speed of a single core so yes it is at what it should be
AMD Athlon X2 5000+ @ 2.6Ghz
Acer Micro-ATX Motherboard
ATI HD3870 with 512mb GDDR4
Realtek HD 7.1 Onboard Sound
22" Acer X223 Widescreen
1680 X 1050
500gb Seagate SATA II
ULTRA X3 600 Watt Modular
Microsoft Sidewinder X6
Microsoft Sidewinder X5
6 Mbs Down 1 Mbs Up
AVerMedia 1500MCE TV Tuner
I Tunes hates Me
yes mate its a 2.5 gig processor , but you have 4 cores in that one cpu each running at 2.5 but its still only 2.5 ghz , not 10
It means you can for example run multiple applications each running on a differant core and your pc will remain responsive or alot of games nowadays will utilise more than one cpu core at a time feeding your gpu with more info making the game run faster or utilise one core for physics calculations in game <<< for example
thats the point of multicore , not to quadruple or double the cpu speed , just to have more cores so you can do "more" work
XFX 780i
OCZ Modstream 700w
Titan Fenir
Razer Reclusa
Logitech G5 Gamer
8mb
Thanks Very Much Everyone Problem Solved Btw Archie are you from scotland
Palicomp
8 gb
Galaxy 3
Palicomp Fans
Cheap
Cheap
8mb
I Tunes hates Me
no mate Yorkshire ........ :D
XFX 780i
OCZ Modstream 700w
Titan Fenir
Razer Reclusa
Logitech G5 Gamer
8mb
