Solved Another crcdisk.sys error
Hello,
I've been searching endlessly for help with this one.
Vista x64 up and running fine for a few weeks - had a sudden power outage.
Now cannot boot into windows - was getting hungup at the crcdisk.sys during attempts to get into safe mode.
I have tried:
1: Running the 'repair' option from my windows CD
Results: Now when it gets to where the 'login' screen should be, i get a blank 'error window' with no text. If i close it it pops up again. (Same thing happens in safe mode).
(It actually booted into windows the first time after running 'repair' - except there was no text anywhere - not on the icons, in the start menu, nada. Couldn't shut down properly, had to hard reset.)
Next I tried running chkdsk /f from the boot CD - still the same.
Any ideas?
    HomeBuilt
    Core2 Quad 6600
    Asus P5B Deluxe
    8GB
    GeForce 8800GTX
    Dual 19" LCD
    1280x1024x2
    C: 250gb Maxtor SATA
    D: 250gb Maxtor SATA
    E: 2x250gb Maxtor SATA RAID 0
    600w
roy69
47,65,65,6B
try chkdsk /r.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
Ok - trying now.
    HomeBuilt
    Core2 Quad 6600
    Asus P5B Deluxe
    8GB
    GeForce 8800GTX
    Dual 19" LCD
    1280x1024x2
    600w
Ok - I tried that with the exact same results:
When I get to where the login screen should be (after the logo and the green bars animation), whether in safe mode or normal, I get a completely blank error box that pops up - no text or anything. If I click the 'x' to close it, it just pops back up again, nothing else happens...
Any ideas?
Thanks a million,
Jonathan
    HomeBuilt
    Core2 Quad 6600
    Asus P5B Deluxe
    8GB
    GeForce 8800GTX
    Dual 19" LCD
    1280x1024x2
    600w
roy69
47,65,65,6B
Have a look at some of these post,
Vista error on boot; CRCDISK.SYS error. - Parallels Forums
From what I have seen crcdisk.sys is the last file to load in safe mode.
There has not been much help online so I would suggest backing up what you can and doing a reinstall.
Is this your only HD? If you have another create a bootable disk from that and then you can recover your data from the damaged vista install.
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Roy - thanks for your help.
I ended up doing a re-install. Of course, my version of vista is an upgrade, so I had to reinstall XP and re-upgrade (what a nightmare). I'm in the middle of two major projects so of course things pile up.
Oh well...
Take care.
    HomeBuilt
    Core2 Quad 6600
    Asus P5B Deluxe
    8GB
    GeForce 8800GTX
    Dual 19" LCD
    1280x1024x2
    600w
