Another HP Printer Driver issue...
AMDkid
I have a new ASUS laptop (Vista32) I carry it back and forth, at home I use a HP F4180 at work I use HP OfficeJet 5600, both latest USB drivers neither will print. I've un-installed, cleaned and reinstalled. Same results. Perhaps HP is the wrong print to own. Any suggestions?:mad:
    Custom...I have 3 rigs...
    AMD Phenom 9850BE Agena, clocked 3.0GHZ
    ASUS M3A78-T
    8GB GSkill PC8500
    Sapphire 4850 1GB DDR3
    Creative X-Fi Fatality Gamers Pro
    32' Samsung LCD TV HDMI
    1280x720
    2 Seagates 160GB/320GB
    Antec 850WTS
    ThermalTake Armor LCS Liquid cooled
    Liquid cooled, by Thermal Take
    Logitech G15 smaller version
    Creative Fatality Laser
    Satellite
    This is my primary rig. My other two rigs are running 790FX's one Gigabyte (Phenom9600),Gigabyte Mercury Case , other ASUS (AthlonX2-6400BE), XClio A380 Case.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Logik
    Technika TKOPTM2
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
Yes all other USB devices are working, Wireless mouse, Zune etc...
    ASUS M3A78-T
    8GB GSkill PC8500
    1280x720
    Antec 850WTS
    Satellite
Guru,
I've tried drivers no results, I've gone as far totally reformat and restore my laptop. It will print through a wireless link (thru a host PC), but not directly.
I'm gonna try a lexmark printer to see if something changes.
    ASUS M3A78-T
    8GB GSkill PC8500
    1280x720
    Antec 850WTS
    Satellite
I have found that everytime I disconnect the USB cable from my old HP Laserjet 4 printer, Vista goes around trying to install the drivers and I usually loose capability to print. This is for sure an annoying thing that I have been able to fix so it stops doing it but, I have been able to work around the problem by going into the properties of the printer and moving the USB port that Vista gives it to another one until it finds the correct one.
Either that or uninstall (delete) the printer, unplug it from the pc, reboot and reinstall again, this fixes the problem as well.
Again, this works for me but I sure would love to find a fix or understand why Vista does that... XP doesn't have a problem when I unplug USB cables.
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    WD Velociraptor 160GB
    Samsung Sata 750GB
    Maxtor External 160GB
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G15
    Logitech G7
    Comcast 6MB Broadband
    Linksys WRT54G router
