rmadisonwi
I've found a few issues regarding sleep mode, but none that seemed to directly address my problem, so here goes:
In the last two weeks or so, I've noticed that when I close my laptop's lid, the computer doesn't go into sleep mode, but instead hangs with a blank screen, and is completely unresponsive when I try to wake it up. The only way to fix it is to hold the power button to get it to shut off. However, this only seems to happen when my wireless network card (internal) is switched OFF. Even then, it doesn't happen all the time (i.e. sometimes it successfully goes to sleep, and wakes up again when I open the lid). It hasn't been a problem at all when the network card is on.
This started happening in late April, when two things happened (and they both happened at about the same time). First was that Windows Update automatically downloaded and installed a hotfix (946776) related to the computer crashing when the network status is changing. For what it's worth, I had never experienced the problem that the hotfix was supposed to correct.
The other thing that happened was that I uninstalled McAfee and installed ZoneAlarm antivirus and firewall.
I haven't been able to reproduce the problem 100% of the time, so I haven't figured out what sequence of programs running causes the problem (though it seems that iTunes and/or Windows Media Player is usually running when it happens).
The first thing I tried was to use system restore and went back to before I installed zonealarm and the update. When I reinstalled ZA, Windows Update decided it was going to hurry up and download the hotfix before I had a chance to tell it not to. I uninstalled the hotfix (though it still shows up on the update history page, but not the list of installed updates), and the problem still occurred.
I don't know if the problem is ZoneAlarm or something else. I looked over the sleep mode tutorial, but there doesn't seem to be anything that I hadn't already looked at previously.
Any ideas? Should I dump ZoneAlarm and go back to McAfee? Since my McAfee subscription expired, I'd only want to do that if ZoneAlarm is really the problem. If there's a fix available that allows ZA to still work, then that would be preferred.
