Any way to allow downloads while in sleep mode?
Metamence
So, as the title suggests, I was wondering if there was a way to make sleep mode not terminate(For lack of a better word) my network, as I'd love to download things overnight but... I have my sleep mode set to Never in the control panel though, but I use it occasionally through my keyboard(The moon key is a shortcut for Sleep).
Any way to allow sleep mode to not disable downloads?
Or... Is there a way to have a low power computer(I'd like the monitor to be off), but be able to finish downloading?
    Gateway
    Intel Core 2 Quad Q6600 @ 2.40GHz
    Gateway G33M05G1
    6.0GB Dual-Channel DDR2 @ 332MHz
    Intel(R) G33/G31 Express Chipset Family
Lorien
Account Suspended
Hi Metamence,
Check out the following tutorial and see if it helps - it includes ways to enable or disable devices to awaken a computer from sleep mode: http://www.vistax64.com/tutorials/63567-power-options-sleep-mode-problems.html.
Here's a tutorial on how to awaken a PC to perform a task scheduled in task scheduler: http://www.vistax64.com/tutorials/166809-task-scheduler-wake-up-computer.html.
Here's a tutorial on how to change the return to sleep mode time for unattended tasks that awaken a PC from sleep mode: http://www.vistax64.com/tutorials/171042-sleep-return-timeout-unattended-wake-up.html.
I'm not certain how to prevent the display from activating when the computer awakens from sleep mode along with everything else. I'm not entirely sure that's possible - though perhaps I simply don't know how to do it.
The solution for "turning off" the display only during a download (assuming it is a laptop and you can't just turn off the monitor by pushing the power button) is to create an icon to activate the screensaver upon pushing it and set the screensaver to blank Create Icons to Start the Screensaver on Windows 7 or Vista - How-To Geek - though not officially turned off it will use minimal power and will also be totally dark as if it were off. Alternatively, you could try the solution in the following article which actually creates an icon to shutoff the display using 3rd party software: Create a Shortcut or Hotkey to Turn Off the Monitor - How-To Geek. I do not know how you activate the monitor if you want to see it if it is shutdown using this method, but presumably the sofware provides some method.
I also don't know how to activate sleep mode once the downloads are complete without risking entering sleep mode before they are finished (unless you go to Power Options and change the automatic timing so that you're certain the downloads will be done before the system automatically enters sleep mode) - but then you'll need to remember to change it back to normal the next day or it will have that prolonged period as your new setting (or add it as a setting when it was previously programmed to never enter sleep mode unless you specifically requested it).
I hope this helps.
Good luck!
    1920 x 1200 pixels
    Dell AIO Printer A940
    6TO4 Adapter
    Microsoft ISATAP Adapter
    Router Linksys / WRT54G -01
evinvit
Hi.. There's no way to download in the 'sleep' mode.
Anyhow, while you are away, you can kill all your other processes, like IE, explorer, etc from task manager, which wd lower CPU utilizn.
    HP dv2700
    Intel Core2 duo
    Intel
