Any way to make desktop icons default on the right side of the screen?
EightBit
4
I have my desktop set up so that the sidebar is on the left side of the screen, simply because I like it better that way, but now whenever I install a new program or download a file from online, which downloads to my desktop, it always appears under the sidebar. Is there any way to make new icons default to the right side of the desktop instead of the left?
smarteyeball
Eye know, eye know
1,874
Location
Australia
The English translation of that site Flavius posted: (For those of us who don't sprachen Deutsche ;) )
DIManagerX is a helpful tool for saving the current position of your desktop icons in profiles for different resolutions. After changing your resolution or reinstall you can load your favorite profile to set your icons into the old position. Features:
  • Individual icon profiles for different screen resolutions/users
  • Live view of the icons on the mini-desktop
  • Optional automatic icon restoration on resolution change
  • Option to check icon positions at regular intervals
  • Automatic update function
  • Compatible with Microsofts Vista 32BIT | XP 32BIT | Windows 2000 | NT4
  • several other functions
  • "DIManager X" is currently available in German and English
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
    Clevo Sager P170HM //
    17.3 Matte 1920x1200 //
    i7 2720QM // 8GB 1333mhz //
    Dedicated GTX 485M //
    Samsung Story 2TB USB 3.0
smarteyeball
Eye know, eye know
1,874
Location
Australia
As far as I know, what you want to do may not be possible. There are plenty of apps that will save the icon position, but none (that I've seen) will allow a default placement to the right. I don't even know of any reg hacks either. I remember looking into this back in the W98 and XP days, but never managed to find a way to do it.
I'm happy enough to be proved wrong though :)
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
Thao
Teh Waiz Wun.
Power User
47
Location
BC, Canada
The only thing I could think of would be to run something like RK Launcher, and have it set to the right side of the screen.
    Gateway MT6821
    Intel® Core™ 2 Duo T5200
    Intel® 945GM
    2GB DDR2
    Intel® GMA 950
    SigmaTel 9250
    Built-In
    1200x800
    1.5 MB (Yes, slow high speed.)
