Solved Anytime Upgrade - Clean Install
Hello,
I'm thinking about replacing my hard drive since my current one is too small and slow.
I was wondering if it was possible to do a fresh/clean install of Vista on a new harddrive using the Windows Anytime Upgrade disk? I still have the activation key since it was preloaded on my computer.
Can anyone help? Thanks
    Dell
    Intel Core 2 Duo - E4600 2.40GHz
    Dell
    2GB DDR2
    Sapphire ATI Radeon 2600 Pro HD 512MB
    Creative Sound Blaster X-Fi XtremeMusic
    1152x864
    80GB SATA
    Dell
    Dell
    14mbps
I believe it is not possible you can only use the Upgrade disk to Upgrade a Version of Vista to do so you will need a Previous version of Vista already Installed
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
Welcome
This is what you do
Use the DVD, when you are asked for a key number do not give it. In addition do not check activate automatically when on line.
After your install all of your software and are happy with the OS, activate by phone. If there is any problem, the rep will try to activate for you, if it is allowed.
http://www.vistax64.com/tutorials/68767-clean-install-upgrade-vista.html?ltr=C
http://www.sevenforums.com/tutorials/18715-activate-windows-7-phone.html?ltr=A
(for both Seven and Vista)
Oh wow! Thank you! I'll definatley do this.
Thanks alot :D
    Dell
    Dell
    2GB DDR2
    1152x864
    80GB SATA
    Dell
    Dell
    14mbps
