Solved Auslogics Registry Cleaner
venom762
I just preformed the Auslogics Registry cleaner and this file showed up in my (Jon)file on the startup. It will not let me delete it. Could I move it somewhere else? I really do not like it there.
    Dell Inspiron 530
    Intel Core 2 quad Q6600 2.40GHz
    OFM586
    3.5GB DDR2 at 667MHz
    19inch dell HD flatscreen
    1280x768 60hz
    7mb
Hello Venom,
Check in the settings in the Auslogics Registry cleaner to see if there is an option to uncheck or turn off saving the file at that location.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
I figured it out they are supose to be there, the program must set the options to see the hidden files. Restored to default and all is good. thank you brink
    Dell Inspiron 530
    OFM586
    1280x768 60hz
    7mb
You're welcome Venom. Glad you got it sorted out. :)
