Solved Auto play / run doesn't work anymore when USB Device is plugged in.
wazz64
My Auto Run/Auto Play stopped working in Vista Home Premium 32 bit OS, I 've ticked the box Use Autoplay for all media devices in Control Panel / Hardware and Sound/ Autoplay. Also tried other options like I'd used before when it used to work.
Tried Reset all defaults.Nothing seems to fix it.
Sounds like a Registry issue??? But don't know!
Any ideas how to repair/fix this problem please.
    HP PAVILION DV9700 NOTEBOOK
    LOGITECH V220
ilikefree
What anti-virus software do you use. If there is a virus on a USB my anti-virus (nod32) won't let auto run start. Try another device before you go into the registry.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
wazz64
I'm running Kaspersky Internet Security but had the same problem with Mcafee and Norton,I've had this problem for some months now but just can't find a solution.
I've used Registry Repair Pro but it doesn't find anything either.
If I go to My Computer I can access any USB Device, External HD and Thumb drives there with no problems at all. It just won't bring up the Auto play Options.
    LOGITECH V220
ilikefree
    LENOVO 64734VM
    15 inch
    External Speakers
wazz64
Can't find it with the link, tried another link below from another user and downloaded it, only 72kb. Seems small.
Installed it,scan took about a millasecond to scan and DONE, but didn't ask where to scan or what drive to scan and then come up with nothing missing. Something wrong there!
I checked my registry after reading the My Digital Life page and noticed my Registry Key settings were these Default REG_SZ (Value not set) BindDirectlyToPropertySetStorage 0x00000000 (0) NoDriveTypeAuto REG_ DWORD 0x0000003c (60). The article said it should be 0×00000091. Could this be the problem? Very cautious about touching the registry and don't know how to change it if I was game enough to.
Also tried Auto Fix exe. It just crashes and says it stopped working.. Windows is looking for a solution blah blah!!!
Any suggestions?
    LOGITECH V220
ilikefree
You should always back up your registry before making changes.
Right click the registry and select export, in the bottom left corner is the options All or Selected Branch. Pick all and save to your desktop.
    LENOVO 64734VM
    15 inch
    External Speakers
Sweet
Banned
Hello Wazz64
Download and extract the ZIP file,
then click on Fix Autorun - Windows Vista.reg
I hope this helps
    Acer Aspire 5738G-644G32MN
    Intel Core 2 Duo - clockspeed 2000 MHz
    Acer JV50
    RAM 4 GB - SO-DIMM DDR3
    NVIDIA GeForce - G105M - 512 MB
    1366 x 768 Pixels
    Hitachi HTS543232L9A300
    320 GB - Type SATA - Speed 5400 rpm
    Logitech Wireless Mouse M505
    Azerty
    Currently 14.5 MB/Sec which means 1.8 MB/Sec effective
ilikefree
Also go to Services and see if Shell Hardware Detection is set to Automatic in the start drop down box.
    LENOVO 64734VM
    15 inch
    External Speakers
ilikefree
OK also check Plug and Play. Maybe even try SSDP Discovery,Remote Procedure Call (RPC),Windows Image Acquisition (WIA)
When you are in the properties section look at the dependencies and see that they have started.
You could also try Disabling Shell Hardware Detection, Reboot,Re-enable,Reboot.
Did you backup your registry?
You could try the registry change in the My Digital Life link I sent you but remember to back up the registry first.
    LENOVO 64734VM
    15 inch
    External Speakers
wazz64
Additional you can try both things
1.Try this program Removing unwanted AutoPlay Handlers in Windows XP and Windows Vista
2.Download ,unpack and import another fix to registry View attachment 20191
and restart computer
:) Thank you so much, I'm not real sure which program I used, I think it may have been the second one, AUTOPLAYFIX exe. Done exactly what you suggested, it changed the registry value to what it should have been automaticley restarted my pc and NOW it's finally working perfectly after almost 2 years of not working.
Thank you so much,I really do appreciate you helping me out..:party:
    LOGITECH V220
ilikefree
SWEET glad to hear that's fixed I will click the ! symbol and mark it solved.
    LENOVO 64734VM
    15 inch
    External Speakers
wazz64
Thank you to all the kind people who went out of their way to help me out with this problem.
I'm so happy that it is now working, used autoplayfix.zip, it changed the registry value to what it should have been, I restarted my pc and autoplay worked as soon as I plugged in my thumb drive.
So HAPPY NOW...........THANKS ALL............
    LOGITECH V220
wazz64
:party:Thank you so much, I'm not real sure which program I used, I think it may have been the second one, AUTOPLAYFIX exe. Done exactly what you suggested, it changed the registry value to what it should have been automaticley restarted my pc and NOW it's finally working perfectly after almost 2 years of not working.
Thank you so much,I really do appreciate you helping me out..:D
    LOGITECH V220
adeanda
Does this zip also work for vista 64?
Flavius
Expelled
Yes of course.It owrks for x32 & x64 as well .
