Autocheck program not found skipping autocheck message at bootup
jwalk3377
3
I keep getting the message "Autocheck program not found skipping autockeck" each time I boot or reboot which is very annoying. Has anyone else seen this message and if so, does anyone know how to get rid of it?
lemur
1,533
Location
University of Kentucky
Run chkdsk /r
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
lordbob75
Lord of Bobs
Vista Pro
1,676
Location
In my Fortress
Go into cmd prompt (as admin) and type:
Code:
sfc /scannow
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Samsung SP2514N ATA 250Gb 7200RPM
    Samsung [Model] 1Tb 7200RPM SATA2
    Razer Lachesis
    Razer Tarantula
    not fast enough
jwalk3377
3
I ran chkdsk /r and sfc /scannow but neither of these removed the autocheck message. I looked im msconfig and could not find a reference to autocheck.
Does anyone know if there is supposed to be an autocheck.exe program in the windows/system32 folder because it doesn't exist in mine? But there is an autochk.exe program in the windows/system32 folder.
I'm beginning to think I'll just have to put up with this message every time I boot or reboot my system!!!
lemur
1,533
Location
autocheck and chkdsk are basically the same thing, except autocheck is run on bootup. They both look for problems on the disk.
To disable automatic disk checking at Windows startup through registry, go to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager
In the right hand pane, double click BootExecute.
The default value of the key is autocheck autochk *
* means every drive is checked for consistency. Just add /K:C at the end before *. /K switch will disable autocheck on C: drive at Windows startup. So the final value should look like this:
autocheck autochk /k:C *
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
jwalk3377
3
Thank you. This information worked. Before I made the change you suggested the value in Bootexecute was as follows:
autocheck "autocheck""autocheck autochk *"""
autocheck smrgdf C:\Users\Jim\Appdata\Roaming\Iolo\
I deleted the 1st and 3rd lines and rebooted. I no longer get this message. However, I don't know what the lines I deleted do but hopefully they are not important. Thanks again for your help.
2
Location
U.S.
#8
I had same annoying problem.
It was caused by a corrupted registry.
Run REGEDIT and then go to HKEY_LOCAL_MACHINE\System\ControlSet001\Control\Session Manager. Click on BootExecute. Data should be "autocheck autochk*".
If you anything else other than "autocheck autochk*", delete other data shown there.
This should clear out the problem.
Do the same on all Controlset002, 003 etc. if you have more in the registry.
Hope this helps.
It worked on my case anyway.
2,049
#10
Can you tell me how to do that through the win 7 recovery disk cuz I'm stuck with this problem? Please reply quick:(
I understand you cannot run system. right? In this case boot Win 7 recovery disk
choose language>>repair computer>>command prompt
and type
regedit
//it open registry but all hives what you can see are only from recovery disk level,not from your system on your hdd!//
To have able edit registry hive from your hdd you have download proper hive manually
in your case
1.Click on HKEY_LOCALE_MACHINE hive
2. Go to menu from File choose "load hive" then navigate to drive where you have system (mostly it is C:) and go to C:\Windows\System32\config and choose SYSTEM file.
3.In key name type the name what you want i.e REM_SYSTEM -now you have loaded hive from your hdd
4.Go to HKEY_LOCAL_MACHINE\REM_SYSTEM\ControlSet001\Control\Session Manager. Click on BootExecute. Data should be "autocheck autochk*".If you have something different you have to correct it.
5.Repeat step 4 for all ControlSet00X (X -number) what you have
Good luck
davidfts
1
#11
Sir... will it work on server?
townsbg
~~тσωηsвg~~
2,248
Location
US of A
#12
Windows server versions aren't much different than the desktop versions so it should.
    Mid 2010 iMac
    3.2 Ghz I3
    8 gb
