Solved avast 6.0.1000 free home edition
t-4-2
Banned
My previous avast was expiring, so I installed the newer version 6.0.1000 free Home Edition.
One minor issue :
How do I disable the " voice " announcement that avast has been updated ?
I did that in the old version, but I have trouble in this new version.
What I did was to right click at the avast icon at system tray > click Silent/gaming mode.
Trouble is, even if it works, it does not stay this way on next reboot.
I'd like to disable the " voice " permanently.
Thank you.
Right-click the icon in the notification area and click on Open avast! user interface. Next, click on SETTINGS and then Sounds. Click on Enable avast! sounds to remove the tick to disable the sounds and then click OK and then close the interface dialogue. To reenable the sounds, repeat, but thius time make sure that the option has a tick.
If you have used a password to prevent unauthorised access to the interface, provide the required password when prompted.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
Ah ! That's the steps I had overlooked.
Thank you. It worked.
You're welcome. :)
The other option you tried, Silent/Gaming Mode, only applies for the current session, or until you change it. A restart turns this mode off.
    Gigabyte IF233
I had my sound off but then I discovered the pirate talk...too cool.:cool:
    Custom - Home Built
    QX9770 watered & O/C'd to 3.6 GHz
    Asus P5QL Pro bios V.0902
    G.SKILL 8GB (4 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
    BFG 8800 Ultra
    Integrated
    VX1930 wm
    1. VelociRaptor WD3000GLFS 300GB SATA (System)
    COOLER MASTER Real Power Pro RS-650-ACAA-A1 650W ATX
    COOLER MASTER Centurion 590 RC-590-KKN1-GP Black
    4 Antec 120mm
    standard Keytronic
    Microsoft Optical
    25 meg down / 5 meg up
    Workstation use
