Solved avi playback in green negative
kiwibabs
I downloaded my video from my camera and tried to view it through media centre and media player but it came out in the green negative. Our windows is vista 32 bit. Tried to download updates but came up with messages of not enough space - due to wrong download - was for xp. Then did the update for vista and said it wasnt applicable for the computer. Can you help me please. The computer always did it as it is only a few months old and the graphics card is an Asus EAH4650 and we have done all the updates for it just recently.
stoneys-nutz
Gamerholic
Hello kiwibabs,
So, you have the latest drivers for your video card, and all the Vista updates.
From what you are describing, i would say it's a codec/file type error.
Can you check to see what format your video camera is, what format the files you are trying to play are.
What type of camera is it, make and model.
Take a look and post your results,good luck.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Dwarf
The Contemplator
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
kiwibabs
Thanks to the replies on my playback problem. I downloaded the codec required ffdshow and I can now see video taken on my digital camera. I now have another problem to solve and will post this separate. Thank you once for the help.
Dwarf
The Contemplator
You're welcome. :)
    Gigabyte IF233
stoneys-nutz
Gamerholic
Glad you got it fixed. :party:
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
