backup failed, chkdsk and sfc, sidebar settings.ini missing
witten1972
Hi, happy holidays for everyone.
This is my first post on this forum.
When I tried to make a backup I've got an error message saying:
Backup failed
0*80070017 cyclic redundancy control failed
I've searched the net for that code and they suggested chkdsk, I've done that
and ran sfc/scannow with elevated privileges. Sfc did correct some problems but there is one problem he could not repair.
I've looked at the log in c:\windows\logs\cbs and searched with the tag [SR] to narrow down, and there was a problem that occured several times.
Windows SIdebar settings.ini is corrupt or missing (64-32bit program files) and when sfc tries to look for backup of the source file it also stated that this one is corrupted.
So I was wondering I've someone knows a method to correct this?
Maybe if there is a way to reinstall the sidebar my problem could be solved (?)
I can't use System restore because I recently deleted those checkpoints, because of an space lack on that partition.
Any help will be much appreciated.
I've you need more info please feel free to ask.
Sorry if my English isn't perfect, not my native lingo.
Best regards Carlo
    HP Pavilion m9480
    Intel core 2 quad 2.50GHz
    American Megatrends 5.43 16/09/2010
    6 GB
    NVIDIA GeForce GT 120
    LG
    2 Seagate disks.
    Internal 1 TeraByte and external USB 1 TeraByte.
    HID - compliant mouse
    Microsoft eHome Remote Control
    10475 kbps dwnld and 488 kbps upld
Airbot
Backup failed
Best regards Carlo
Hi Carlo and welcome,
Read these tutorials and see if these can help.
http://www.vistax64.com/tutorials/117192-windows-sidebar-will-not-start-vista.html
http://www.vistax64.com/tutorials/161046-windows-sidebar-gadget-not-displayed-correctly.html
As to your other problem, try a startup repair if possible.
http://www.vistax64.com/tutorials/194765-system-recovery-options.html?ltr=S
You can generate a system health report to see if you get any other information.
http://www.vistax64.com/tutorials/82728-system-health-report.html
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    [email protected]
    1 OCZ Vertex2 180GB SSD
    Pioneer DVD Burner DVR-S18M
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
    Windows 7
    W.E.I final score= 7.7
    Windows Vista=5.9
rive0108
Dare I ask if you have been using registry cleaners?
Sounds like you have windows file corruption. You have two choices if this is a result of registry cleaning-1. restore your registry cleaner files that the program altered/deleted. 2. Reinstall Windows.
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    640GB 7200RPM SATA/RAID 0 (2x320GB)
    and 320GB 7200RPM External
    Wireless Microsoft 3000
    10 mbps/2 mbps
    Optical Drive:
    Panasonic UJ-220 DL BD-RE (Blu-Ray)
witten1972
Thanks for quick reply.
First I wanna say to Airbot that I don't have any problems with starting the sidebar nore with the gadgeds that are displayed.
I've tried some options from the recovery partition and disk, but I couldn't reinstall the sidebar without doing a complete install of Windows.
I think that rive0108 is closer to determine what caused my problem.
I've been thinking about the fact that some registry cleaners may caused this problem.
I'm trust those applications too much I guess.
Hopefully I still have the backups, because I used and tested quite alot of them.
But before I commence I want to ask something;
- do I choose backup per backup and starting with the last one, and do I need to restart after every single backup that I restore?
- on second thoughts though, there are 2 regcleanprogrs wich have a complete backup from the whole registry, from before the first action they took, I think it would be better to set one of those back...
And what happens with my system if I replace one and since that time I've updated some hardware, could that cause some serious troubles?
I wanna use a complete Windows restore as last resource, because I did just that
a week or 2 ago, and reinstalling everythng is something that I look up to do again.
Anyway thanks for the tips and I hope to get some answers from this reply.
Best regards guys
    HP Pavilion m9480
    6 GB
    LG
    2 Seagate disks.
rive0108
Best regards guys
A rule of thumb on registry cleaners-
they are notorious for deleting critical program/windows .dll registry entries (amongst other things). If you do not know the function of the things the cleaner wants to remove- do not allow it to remove it. This can cause severe file corruption in Windows.
The programs often do not discriminate between legitimate and unwanted items, and Inexperienced users are often advised to exercise caution. Personally I stay clear of registry cleaners- and if the time comes when I want/need to clean certain entries from the registry I search for it myself under "find" in regedit and delete the unwanted entries. I only do this for critical issues (like removing malware/unwanted programs), and never as a general "sweep" for performance improvements.
For restoring your computer this is what i suggest-
Stop using registry cleaners.
There are free disk imaging software programs for home premium. Reinstall Windows, download all updates, load all the programs you want. Do a full system defrag in command prompt as admin (defrag c: -w), run check disk, then create your image. Takes 15 min to reinstall image if needed at a later time. Download free DriveImage (similiar to Norton Ghost):Download Private Edition
note- Do not back up a corrupted image. This is why I suggest fresh Reinstallation of Windows and sp1 updates.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Optical Drive:
rive0108
Also, if you want to completely remove programs that are installed with Microsoft Windows Installer use this.
  • WindowsInstallerCleanup.exe
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Optical Drive:
witten1972
Best regards guys
There are free disk imaging software programs for home premium. Reinstall Windows, download all updates, load all the programs you want. Do a full system defrag in command prompt as admin (defrag c: -w), run check disk, then create your image. Takes 15 min to reinstall image if needed at a later time. Download DriveImage:Download Private Edition
Maybe I have to adjust my policy regarding those cleaners.
I trusted them too easy, and used them almost every day.
And to make matters wurse I use several cleaners;
Advanced System Care from IObit
RegistryEasy
and a built in cleaner from Advanced Vista Optimizer
I get carried away by promising words like optimize, clean, faster, tweak...
Are the built in features of Vista enough to keep the machine clean?
When your pc gets slow do you trust on Imaging software to replace it with a clean image?
I'm a little bit reserved using Imaging software.
On my previous xp machine I used Acronis, and when the time came when I needed that Image it was corrupted. Allthough I did a verificationproces when making it and afterwards, both turned out OK. A couple of weeks later it was corrupted due to bad sectors on the external hd.
Thats why I did an upgrade to Vista, and I tried a different Imaging prog
Spotmau (all- in-one), but that prog was a nightmare, when the imaging process was done everything was messed up. (my profile was gone, and partitions were changed...)
I did a new clean install of Vista, like I said in my previous post.
Is it possible to make a bootable version of DriveImage, so when Vista wont boot I still have a bootable cd?
Or can I trust the OEM preinstalled rescue/recovery manager to restore Windows boot items and then restore the image made by DriveImage when Vista is loaded?
Forgive me if I ask to much questions, but with all recent affairs I'm getting a bit vigilant.
Nevertheless, I appreciate your feedback!
Regards Carlo
    HP Pavilion m9480
    6 GB
    LG
    2 Seagate disks.
rive0108
I imaged my drive right away after Vista SP1 and all my essential programs were installed. I also back up files/folders through Windows backup utility to a 320GB external drive every week. My Complete Vista PC Image (5-DVD's) is used for catastrophic recovery, and I have recently used it for setting up my newly upgraded internal hard drives. (640GB-320GBx2)
I run a RAID 0 config, and when I notice performance loss, I do a full defrag through command prompt (this on top of the regularly scheduled default weekly defrag).
I use NOD32 antivirus/antispyware (while not free, is relatively inexpensive) which has a very small footprint and provides excellent heuristics, and I also use a tweaked Windows defender as a secondary backup- but mostly just for monitoring software not yet classified for risks (new)/and changes made by software that is already permitted to run.
I also run Check disk once a week or so. Always use UAC.
As for bootable images, Drive Image should create a bootable set of DVD disks, or a bootable file on your external. I am not really sure though as I do not use it. I created my Image with Vista, and boot off my Vista O/S disk into the advanced recovery options.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Optical Drive:
Airbot
I agree with rive0108, if you're not making absolutely sure as to what cleaner programs are cleaning then you can have disastrous results. If you just go on faith that they know better, they will wind up deleting important files and entries.
    Airbot 2.0
    ASUS Xonar D2X
    [email protected]
    Corsair HX1000W
    Windows 7
    Windows Vista=5.9
witten1972
Hi again
This is really helpfull information.
I'm gonna use DriverImage, and test it out.
If everything works as it should be than I'll do a complete reinstall of Windows and use your method.
There's one thing I want know, how do you make an Image with Windows.
Has it something to do with "Volume shadow copy", and how do I use it?
If I'm not mistaken, the Backup function in Windows doesn't backup system files and can't therefor be used as a total backup of the pc.
Correct me if I'm wrong.
Thanks for the adequate advice
    HP Pavilion m9480
    6 GB
    LG
    2 Seagate disks.
Brink
Staff member
mvp
Best regards guys
Hello Witten,
You might try a System Restore using a restore point dated before the problem. This would restore the registry back if it was a registry cleaner program that caused this.
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
rive0108
Hi again
Your version (premium) doesnt include Vista's Complete PC Backup and Restore utility this is only part of Business, Enterprise, and Ultimate versions. Your only options are third party utilites.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Optical Drive:
rive0108
Best regards guys
Hello Witten,
Hey Brink,
Unfortunately, he deleted all restore points... any other ideas short of a reinstall?
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Optical Drive:
Brink
Staff member
mvp
    Lumia 1520 phone
witten1972
Hi Shawn
Sytem Restore is not possible, because I recently deleted every restore point except the last one to create more space on the recovery partition.
    HP Pavilion m9480
    6 GB
    LG
    2 Seagate disks.
I'm having this same problem with Sidebar's settings.ini. I have never run a registry cleaner on my PC since I only got it in October and it's still fast. So the cause of the problem is not correct.
Many people all over the web are complaining about Sidebar's settings.ini file going corrupt, so there is a problem with Windows Vista (surprise!).
Further, I cannot delete settings.ini and recreate it. Why not? It's just a simple text file. It's my laptop; it's standalone (not part of a corporate network). I am the administrator. Why can't I just recreate this corrupted file? (I've tried working in Safe Mode, too).
The solutoin, according to this thread, is to reinstall Windows. But a complete Windows install seems a little extreme for a small, corrupted text file, which should take me 30 seconds to fix. To fix a corrupt file, I would have to backup all my data, reinstall Windows (which takes what 2 hrs?) reinstall all of my applications (no time estimate handy), then recover my data. And what's the procedure for the next time a file is corrupted (and why are they corrupting so often?)? I've already spent 3 days - nearly nonstop - trying to solve this issue.
So what is the best way to fix this Sidebar's settings.ini?
Note that I am running Vista x64 Ultimate. I have already run chkdsk and sfc (several times) and a built in disk check. Also, I am using a SSD (solid state drive) instead of a regular old HDD.
Thank you all in advance for your help.
