Backup location not available
8
Hard drive crashed; new one installed (HP Touchsmart IQ506). Have full system backup on external WD My Book but keep getting "backup location not available." I have read a number of threads on this problem but no solutions. Has anyone found the magic key yet?
    HP/IQ506
    4.0GB
richc46
Staff member
20,105
Location
Fairfield County, CT
When you click on the desktop computer icon, do you see the drive, if so
Try to change the drive letter of the back up. Use something high in the alphabet.
Lorien
Account Suspended
2,212
Location
Laytonsville, Maryland, USA
Do you even have access to Vista at all to check anything? Is it a clean drive with nothing installed on it and you're trying to restore an image to it? Or did you re-install Vista and are trying to restore a full backup but not a complete image backup?
Since Vista Home Premium doesn't include a complete image backup, what did you use to create the backup (software name and version)? Please explain the process by which you are trying to restore the backup - step-by-step. At what point does that error message appear? Do you have another computer you can attach the external backup drive to to confirm that it is being recognized by the computer and you can access the drive and rule out a problem with the drive itself?
Thanks!
    1920 x 1200 pixels
    Dell AIO Printer A940
    6TO4 Adapter
    Microsoft ISATAP Adapter
    Router Linksys / WRT54G -01
8
I can see the hard drive (Drive H in my case) when I click "Computer" and can see everything in it through Windows Explorer--just when I try to restore the backup from this drive using Advance Restore (i.e. backup from another computer...), I get the problem. I can see every backup folder--just won't restore.
    HP/IQ506
    4.0GB
richc46
Staff member
20,105
Location
Sometimes this works. Change the drive letter to something high in the alphabet.
If that does not work, try on another computer, for a test. So we can locate the problem
Is it recognized?
8
Lorien--I used the software that came with the Western Digital USB external hardware. I don't believe it's an image backup--it backs up using basically same folder/file as computer. Step by step I used: Clicked advance restore (backup from another computer); drop down box shows available locations for a backup and I choose my Drive H (the western digital drive); the computer recognizes the drive--no problem; I am given a choice of which backup (date & time) I want to use (I backed up once a week since 2008 so have MANY backup files) and I select the first one (the origional full backup that all the subsequent backups reference)--note that while I am given the choice of which backup to use, I get "backup location not available" comment next to every backup file; Again, I select a file, hit restore and it muddles along for awhile and I get "Restore Complete"--but no files show up (for example, no excel files, word files, pictures, itunes music etc even thought they were in the respective backup file)
    HP/IQ506
    4.0GB
richc46
Staff member
20,105
Location
Just to be sure
Run a full anti virus scan
download and scan with malwarbytes.
Many times virus will stop a back up so they will not be removed.
Since it is a new HD, I doubt that this will lead to anything, Probably due to the new HD.
8
#8
Virus scans done and clear. Have copied backup files to C Drive and now looking for files to extract individually--will take a year of Sundays at this rate...
    HP/IQ506
    4.0GB
richc46
Staff member
20,105
Location
#9
In that short a time, it must have been a quick scan. Do the full scan. AV will take about an hour and MB about 30 minutes, depending how many files you have.
derekimo
Staff member
784
Location
Shasta County
#10
If this is just an external hard drive, if you choose the location as "This Computer" instead of another computer, do you still get backup location not available?
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    250GB Samsung 850 EVO SSD
    1TB WD Blue
    1TB Hitachi
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
    Laptop specs: HP g7-1365dx /
    CPU: AMD A6-3420M APU with Radeon(tm) HD Graphics /
    RAM: Crucial 8Gb (2x4Gb) /
    SSD: Crucial M4-CT128M4SSD2 ATA Device/ FW 000F /
    GFX: AMD Radeon HD 6520G /
    OS: Windows 10 Pro x64
8
#11
Not guiven the option to select "This Computer"--message indicates there is no backup on this computer and forces me to go to advance restore.
Also did full scan--still no luck
    HP/IQ506
    4.0GB
