Best NVIDIA card for my DELL GX270
alishan
7
Hey Guys!
I recently purchased a REFURBISHED DELL GX270 which has 3 GHZ processor and 1 GB of RAM from local market here in PAKISTAN.It came pre-installed with WIN-XP but I want to upgrade to WINDOWS VISTA and want to add some 3d card which will enable WINDOWS-AERO graphics on desktop.
You can view my computer specs at Documentation
Can u please some NVIDIA GEFORCE card which will atleast enable windows aero.
I think I should go for
GeForce AGP FX5500 256MB (128-BITS)
GeForce AGP FX5500 128MB (128-BITS)
GeForce AGP FX5200 128MB (64-BITS)
CAN U PLEASE TELL ME WHAT CARD should I purchase and that what is AGP or PCI.
By reading my pc specs, can u tell me its AGP or PCI compliant but I think its AGP compliant.
I SHALL BE THANKFUL FOR ANY HELP U MAY OFFER.
xguntherc
I Click Home To Much
1,208
Location
Vegas Baby
Well, if your model is the desktop model, then yes. if it's the small mini computer sytle. then you''ll have a hard time getting something to fit.. Maybe look at something like this. I know the best card you could get would probably be the AGP Sapphire 3850.. it can run Crysis, no other AGP card can as good as it. not sure if that matters, but it's probs one of the best cards thats not a PCI-E card.
Look here.
Newegg.com - AGP 4X/8X, Desktop Graphics / Video Cards, Video Cards & Video Devices, Computer Hardware
    Q9650 E0 4.0 GHz @1.304v
    eVGA 750i FTW
    eVGA/MSI GTX 260 SLI
    X-Fi XtremeGamer
    Samsung T240 & 226BW
    1920x1200 & 1680x1050
    PC P&C 750w Silencer PSU
    Logitech MX-518
    Logitech G11
johngalt
Antidisestablishmentarian
3,909
Location
3rd Rock
I had an ATI x1650 Pro 512 MB card that worked really really well with Vista, and played games like NFS:MW Black Edition with no issue.
Processor was a P4 3.2 GHz HT Prescott, and I had 1 GB of RAM, that I later upgraded to 3 GB.
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Calssified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    2 * Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM SATA II
    Seagate Barracuda 7200.12 ST1500DL001 1.5 TB SATA II
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    180 Mbit down / 15 Mbit up
    3 VMs built off IP 14971:
    UUP disabled / single VHD | UUP disabled / dual VHDs with moved \User Tree | UUP enabled / single VHD
xguntherc
1,208
Location
Vegas Baby
I think my idea works.. AGP 4/8 correct?
    eVGA 750i FTW
    X-Fi XtremeGamer
    Logitech MX-518
    Logitech G11
alishan
7
Yap I hope so dude but I am concerned by some one,s comment on nvidia forum that I should also buy DELL POWER SUPPLY which might not be available in local market.
Let me talk to my computer hardware store.
skunksmash
im coming for cake
2,254
Location
norfolk
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
johngalt
3,909
Location
3rd Rock
#8
Ummm, actually, *mine* *did* require an external power source....
Welcome to Visiontek: Unbelievably Real Graphics
System requirements: 350W PSU....
I burned up my 250W testing it (just had to try) and then bought an XPower 500 that bit the dust so I then got a MadDog Multimedia 500W Modular PSU that I still have in the case with the card. Works perfectly (albeit a bit slowly) on Vista.
    The Beast Model V
    2 * 1920 x 1080
    Logitech MX Master
skunksmash
im coming for cake
2,254
Location
norfolk
#9
[FONT=arial, helvetica]System Requirements: PC with one 8X/4X AGP graphics slot available on the motherboard. 350-Watt power supply or greater (assumes fully loaded system). 512MB of system memory. Installation software requires CD-ROM drive. DVD playback requires DVD drive and decoder software (not included).
yes it does require a 350w min but my point was it only requires that through the PCI bus ....there is no PSU connection on this card
[/FONT]
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
Fumz
Buggin
878
Location
California
#10
... I want to upgrade to WINDOWS VISTA and want to add some 3d card which will enable WINDOWS-AERO graphics on desktop... Can u please some NVIDIA GEFORCE card which will atleast enable windows aero...
How much did you want to spend?
    Fumz' Flux-Capacitor
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    500GB W.D. RE2 Primary
    1TB W.D. Caviar GP WD10EACS
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
Fumz
Buggin
878
Location
California
#12
According to these guys that's only $40.15: Calculator for Pakistan Rupee (PKR) Currency Exchange Rate Conversion
Do I have that right?
The cards you picked all fall within that price range, and if your only concern is enabling Aero, then they will work just fine; however, if you could scrape up just a few dollars more (~$20.00), then this Raedon would be your best option: http://www.newegg.com/Product/Product.aspx?Item=N82E16814161052
You can probably find one cheaper in your neck of the woods, so don't get immediately discouraged by newegg's pricing.
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
johngalt
3,909
Location
3rd Rock
#14
[/FONT]
OK, then attached is a pic of my VisionTek x1650 Pro card right out of my old box.
    The Beast Model V
    2 * 1920 x 1080
    Logitech MX Master
Fumz
Buggin
878
Location
California
#15
hey dude thanx for advice but following r some of the gpus available in the local market
GALAXY... Pakistan's Leading Computer Store... Price Watch and click on
Gaming Cards and u will see all the cards available in my country but I need the one which is compatible
Look under the AGP menu and you'll find cards that work for you. Here they are:
Inno GeForce AGP FX7300GT 256MB (128-BITS)
Inno GeForce AGP FX5500 256MB (128-BITS)
XFX GeForce AGP FX5200 128MB (128-BITS)
HIS ATI AGP X1600 PRO ICEQ 512MB (128-BITS) DDRII
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
skunksmash
im coming for cake
2,254
Location
norfolk
#17
Hi alishan
are you saying you want to fit DDR2 RAM in a DDR slot...?
DDR is a 184pin DIMM....
DDR2 is a 240pin DIMM...
sorry :)
that's a PCI-E card ...if your board has one of those then you should have no problem.
but its unlikely considering you listed AGP cards in the OP there are very few boards if any which sport an AGP slot & a PCI-E slot
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
