Best way to Protect a Computer?
Mathieu19
Hi!
I have a HP Computer. It came with Windows Live One Care witch I find fantastic. I would like some help with some of the best program protection possible to help keep my computer away from risk. Such as:
Anti-Virus, Anti-Spyware, Extra Protection, Virus Vault, Scanning ECT.
I am not too good with computers, the whole protection thing, so some help would be appreciated.
Thanks.
Dwarf
The Contemplator
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
Fumz
Buggin
Results and comments - matousec.com
As you can see, Windows Live One Care does not do anything for you; a 5% success rate is beyond pitiful, thus, LIC is pointless.
To be honest, the best defense is you. Having said that, the top 3 AV apps are made by Kasperky, BitDefender and EST's NOD32.... NOD 32 is, to date, the best of the best as far as Vista is concerned. Keep in mind, no AV app is 100% effective, which is where you come in.
A couple weeks ago a new clickjacking exploit was release, and, to date, there is no fix, so the only defense is Firefox's No-Scripts.
    Fumz' Flux-Capacitor
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    500GB W.D. RE2 Primary
    1TB W.D. Caviar GP WD10EACS
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
mike-cow
Vista Pro
    Home made
    AMD Athlon X2 6000+
    ASRock ALiveXfire-eSATA2
    2x2GiB DDR2 PC2-6400
    GeCube ATI Radeon HD3870 512MiB GDDR4
    Built in HD Audio, digital output
    Samsung SyncMaster 206BW, SyncMaster 940B
    1680x1050 + 1280x1024
    WDC 250GB SATA + lots of externals. :)
    Antec Earthwatts 500W
    Antec Sonata III
    Air
    Logitech G9
    Logitech G15 (1st edition w blue lightning)
    DL/UL: 50/10Mbit
mastoark
If you have vista 64, comodo firewall works well... I think if you have 32 bit then Comodo/Outpost/Online armor would be your best bet for firewall.
Now antivirus I would personally use Avast antivirus.... Very good antivirus that is free...Plus its compatible with both Vista 32 and 64...
Spywareblaster is a decent program as well and is free.
I would also on occasion run any one of these programs, Ad-aware, spybot search and destroy, superantispyware....
To be honest most people that is about all you will need... You can get most of these programs from Majorgeeks.com a good trustworthy site to download from. hope this helps.
mastoark
That link you were giving is not useless it is highly usefull..... Those firewalls rated high are some of the best ones you can buy.... Firewalls do moniter your network, they also create rules to allow the software you choose to run,,, They also try and keep things from running like malware virus you may have accidently installed.....
Antimalware programs are only a small peace of the protection puzzle
Sorry for the double post my mistake.
mike-cow
Vista Pro
The results are misleading and it's definetely not unbiased. They charge companies for running through a full test of software. And I wouldn't be surprised if they manipulate results to make paying companies look better too.
All software should be tested on 100% equal terms. In the case of Matousec, it's only equal for paying companies. That makes it useless in my book.
    Home made
    AMD Athlon X2 6000+
    Antec Sonata III
    Air
    Logitech G9
    DL/UL: 50/10Mbit
Mark3748
I have used a lot of different AV programs, and I currently use Avira AntiVir Security Suite Premium. I deal with malware on a daily basis at work, and the absolute worst AV suites are AVG, McAfee and Norton, the majority of infected PCs I see are running these programs.
For a good comparison of different antivirus programs, this is a good site:
AV-Comparatives
    HP Pavilion Elite m9040n
    Intel Core 2 Quad Q6600 @2.4GHz
    4 GB PC2-6400
    nVidia GeForce 8800GTS 512MB
    2x Seagate Barracuda 7200.11 640GB SATA in RAID-0
    20Mb/s Comcast Business
