Blizzard's Diablo 1
Dzomlija
Resistance is Futile
For all those detractors out there who believe Vista is rubbish for older games, and in particular Vista x64, I'd like to present some evidence to the contrary, in the form of a blast from the past. 1995 to be exact.
I've recently re-aquired an original Diablo 1 (what can I say - I'm a Diablo fan), and figured because I was using Vista Ultimate x64, I'd have to run it in Windows XP under Microsoft Virtual PC 2007. However, when I got home from work this afternoon, I inserted the disk and allowed the autoplay to run.
The game installed without problems. Although I must mention that I changes the install path from "C:\Program Files (x86)\Diablo" to "C:\Games\Diablo". And it played! To top it off, it even showed up in the Vista Games Explorer.
This has surely got to be the oldest game I know of that has installed without any issues whatsoever onto Vista x64, and does not even need to have any compatibility mode settings manually changed!
Here are two screenshots that shows the following information:
  • That I am using Vista x64
  • Diablo 1 displays in the Game Explorer
  • Diablo 1 runs without any Compatibility Mode settings!
  • A view of the game in action, with a newly created character
This is truly a testament to the compatibility of Windows Vista x64, and the quality of games produced by Blizzard!
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    2 x 80GB Seagate (I)
    2 x 120GB Seagate (I/S)
    2 x 200GB Seagate (I/S)
    2 x 250GB Seagate (I/S)
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
MrNeeds
PC Geek
i can do one better than that m8, got the ultimate doom working :P
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Samsung 7200rpm 250Gb SATA,
    Samsung 7200rpm 750Gb SATA,
    WD 7200rpm 1TB SCSI SATA.
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
Dzomlija
About on a par there - Both where released in '95, and "Ultimate Doom" is a Windows re-write of the original Doom (for DOS). Diablo was originally written for Windows.
Where can I get "Ultimate Doom", btw?
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
MrNeeds
PC Geek
hehe, well, you can get it from steam if you want, i got it with the doom trilogy about 8 years ago, gathering dust in my loft :P
it was quite easy to get it working though, it kept asking me for dxplay.dll, but obviously the file system wasnt the same as windows 95's setup so i copied all the directx files on the disc into c:/windows/system and it worked like a dream.
    16Mb Sky bb
Dzomlija
It's actually pretty cool knowing that some of the classics that started the 3D Revolution are still out there being played by the masses. If it wasn't for titles like Doom, graphics cards as we know them wouldn't have been the same...
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
Ed Ministrator
Dzomlija,
Thanks for sharing this. I noticed you also have Diablo 2 installed, did it install with the same ease?
    "Homebrew"
    Intel Core 2 Duo E8500 3.16GHz
    GIGABYTE GA-EP45-DS3L LGA 775 Intel P45
    CORSAIR 4GB SDRAM DDR2 800
    HIS Hightech IceQ4 TurboX H485QX512P Radeon HD 4850 512MB
    onboard - Realtek ALC888
    Acer X223Wbd 22" Widescreen LCD and Samsung SyncMaster 17"
    1680x1050 and 1280x1024 respectively
    Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s
    SeaSonic S12 Energy Plus SS-550HT 550W 80 PLUS Certified
    X-Blaster ATX Case - Black w/ Clear Side
    Enermax fans - Cluster UCCL12, Everest UCEV12
    Logitech LX7 Cordless Optical
    Microsoft Comfort Curve 2000
    running Windows Live OneCare 2.5 security suite
Dzomlija
Dzomlija,
Yes. The only change that needs to be made is the install location. This needs to be changed from "Program Files" to something else, because as you know, Vista protects the "Program Files" folder.
My Diablo II is installed to "C:\Games\Diablo II".
In fact, this "trick" will work for many older games that may experience problems on Vista. Just change the default install location to some other unprotected folder, and the games should work.
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
celticscorpio
I own Vista Home Premium, Model NV52 SERIES, 64 bit. Yesterday,I installed Diablo 1 on my pc( also addicted to the origional Diablo :)). At 1st, when pc set to comparability mode, and game loaded, graphics were crappy. Am going to follow your advice on changing install path to "C:\Games\Diablo" , and see how it goes. Not even close to being a tech, so any feedback you can give to to install without compatability glitches, would appreciate the feedback.
MrNeeds
PC Geek
good luck, i think you should put the directx files directly in windows\system32 folder as well, i found that helps
    16Mb Sky bb
celticscorpio
Thanks for the feedback, also, windows puts it into compatability mode. The wierd part is, game attempts to bein with crappy graphics ( extreme color/very bright sections), then, when I restart system, t plays normally, Very sporadic on normal grahics mode, any suggestions?
