Blue screen after updates
2
i just installed Vista ultimate 64 and all the updates.. but it gave me a blue screen when it was loading windows after reboot. and this just kept going.
i reinstalled vista and all those updates but the problem still remained.
now i dare not install any updates... any one has any idea what is going on here?
johngalt
Antidisestablishmentarian
3,912
Location
3rd Rock
When you install Vista x64, do you install your drivers immediately? And then, after SP1 gets installed, do you check your drivers and make sure all are OK?
SP1 tends to not play nicely with drivers that are not the absolute latest....
  • Show second system?
    Yes
    Operating System
    Windows 10 Insider Preview current build
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Classified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    SanDisk Ultra SDSSDHII-960G-G25 SATA III SSD (System)
    Crucial MX100 CT256MX100SSD1 SATA III SSD (User Tree)
    2 * Seagate Barracuda 7200.12 ST31000528AS SATA II
    Seagate ST1500DL001 7200 RPM SATA II
    Intel SSDSA2M080G2GC SATA II SSD
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    300+ Mbps downstream / 30+ Mbps upstream
    Windows 10 Insider Preview (current)
    Dell Inspiron 3521
    Intel(R) Celeron(R) CPU 1007U @ 1.50GHz
    Dell
    Intel(R) HD Graphics
    Intel(R) Display Audio | Realtek Audio
    Inspiron 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Dell
    Dell
    Dell
    Logitech MX Master | Synaptics TouchPad
    Dell
    300+ Mbps downstream | 30+ Mbps upstream
1
I had the same problem after I installed Vista x64. I would receive the BSOD that pointed to either tcpip.sys or netio.sys. It turned out to be "Update KB938371". I had to restore my system to any point before that update was installed. It worked fine after that. I've installed all other updates and am now only having a few errors. Still getting the BSOD, but now for other reasons and not so often. I also change the automatic update to only notify me when their are new updates. That way, I won't have any surprises. I hope this helps.
johngalt
3,912
Location
3rd Rock
Hi, dangermousesc, and welcome to the forums.
If you are still getting BSODs then your problems are not over. I don't get BSODs, unless you count the Virtual Machine systems I purposefully infect with malware to test an antimalware product, or when I am playing around with OCing.
Also, System restore only changes registry entries and settings, not files themselves - so the files that were installed by that update are still on your system.
    Yes
    Operating System
    The Beast Model V
    2 * 1920 x 1080
    Logitech MX Master
    Dell Inspiron 3521
    Dell
    Inspiron 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Dell
    Dell
    Dell
    Dell
