Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\richc46\AppData\Local\Temp\Temp2_Mini071010-01[1].zip\Mini071010-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (4 procs) Free x86 compatible
Built by: 6002.18082.x86fre.vistasp2_gdr.090803-2339
Machine Name:
Kernel base = 0x81e09000 PsLoadedModuleList = 0x81f20c70
Debug session time: Sat Jul 10 10:04:08.414 2010 (GMT-4)
System Uptime: 0 days 0:35:31.489
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 1000008E, {c0000005, 81ebae53, 9df459c4, 0}
Unable to load image \??\C:\Program Files\CAPCOM\Monster Hunter Frontier Online\GameGuard\dump_wmimmc.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for dump_wmimmc.sys
*** ERROR: Module load completed but symbols could not be loaded for dump_wmimmc.sys
[B]Probably caused by : dump_wmimmc.sys[/B]
Followup: MachineOwner
2: kd> !analyze -v
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: 81ebae53, The address that the exception occurred at
Arg3: 9df459c4, Trap Frame
Arg4: 00000000
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
FAULTING_IP:
nt!KeStackAttachProcess+a
81ebae53 8b3524010000 mov esi,dword ptr ds:[124h]
TRAP_FRAME: 9df459c4 -- (.trap 0xffffffff9df459c4)
ErrCode = 00000000
eax=9df45aff ebx=0019f270 ecx=ffffffff edx=0000a800 esi=84d92bc0 edi=00000000
eip=81ebae53 esp=9df45a38 ebp=9df45ac8 iopl=0 nv up ei pl nz na po nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010202
nt!KeStackAttachProcess+0xa:
81ebae53 8b3524010000 mov esi,dword ptr ds:[124h] ds:0023:00000124=????????
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: CODE_CORRUPTION
BUGCHECK_STR: 0x8E
PROCESS_NAME: firefox.exe
CURRENT_IRQL: 0
MISALIGNED_IP:
LAST_CONTROL_TRANSFER: from 82017039 to 81ebae53
STACK_TEXT:
9df45ac8 82017039 ffffffff 0019f270 00000020 nt!KeStackAttachProcess+0xa
9df45d48 81e53c7a ffffffff 00000001 0019f270 nt!NtQueryInformationProcess+0x487
9df45d48 76f55e74 ffffffff 00000001 0019f270 nt!KiFastCallEntry+0x12a
WARNING: Frame IP not in any known module. Following frames may be wrong.
0019f2bc 00000000 00000000 00000000 00000000 0x76f55e74
STACK_COMMAND: kb
CHKIMG_EXTENSION: !chkimg -lo 50 -d !nt
81ebae49-81ebae4d 5 bytes - nt!KeStackAttachProcess
[ 8b ff 55 8b ec:e9 a2 b6 a8 24 ]
5 errors : !nt (81ebae49-81ebae4d)
MODULE_NAME: dump_wmimmc
IMAGE_NAME: dump_wmimmc.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4c1ad05a
FOLLOWUP_NAME: MachineOwner
MEMORY_CORRUPTOR: PATCH_dump_wmimmc
FAILURE_BUCKET_ID: MEMORY_CORRUPTION_PATCH_dump_wmimmc
2: kd> lmtsmn
start end module name
8f251000 8f25e080 1394BUS 1394BUS.SYS Sat Jan 19 00:53:27 2008 (47919057)
807b3000 807f9000 acpi acpi.sys Sat Apr 11 00:19:03 2009 (49E01A37)
94496000 944de000 afd afd.sys Sat Apr 11 00:47:01 2009 (49E020C5)
8f31b000 8f353000 ahsus71v ahsus71v.SYS Sat Mar 21 10:47:30 2009 (49C4FE02)
8a28a000 8a292000 atapi atapi.sys Sat Apr 11 00:39:09 2009 (49E01EED)
8a292000 8a2b0000 ataport ataport.SYS Sat Apr 11 00:39:10 2009 (49E01EEE)
8f2ec000 8f31b000 b57nd60x b57nd60x.sys Mon Feb 26 17:50:32 2007 (45E36438)
93fd4000 93fdb000 Beep Beep.SYS Sat Jan 19 00:49:10 2008 (47918F56)
8068a000 80692000 BOOTVID BOOTVID.dll Sat Jan 19 02:27:15 2008 (4791A653)
a0967000 a0980000 bowser bowser.sys Sat Jan 19 00:28:26 2008 (47918A7A)
a2705000 a270f000 BthEnum BthEnum.sys Sat Apr 11 00:43:09 2009 (49E01FDD)
a270f000 a2729000 bthpan bthpan.sys Sat Jan 19 00:53:44 2008 (47919068)
a265c000 a26dc000 bthport bthport.sys Sat Apr 11 00:43:09 2009 (49E01FDD)
a264f000 a265c000 BTHUSB BTHUSB.sys Sat Apr 11 00:43:08 2009 (49E01FDC)
9a6d0000 9a6de000 cdd cdd.dll Thu Sep 24 21:27:02 2009 (4ABC1C66)
a6929000 a693f000 cdfs cdfs.sys Sat Jan 19 00:28:02 2008 (47918A62)
8efdd000 8eff5000 cdrom cdrom.sys Sat Apr 11 00:39:17 2009 (49E01EF5)
806d3000 807b3000 CI CI.dll Sat Apr 11 02:25:22 2009 (49E037D2)
8a99e000 8a9bf000 CLASSPNP CLASSPNP.SYS Sat Apr 11 00:39:05 2009 (49E01EE9)
80692000 806d3000 CLFS CLFS.SYS Sat Apr 11 00:13:51 2009 (49E018FF)
945a4000 945b1000 crashdmp crashdmp.sys Sat Apr 11 00:39:12 2009 (49E01EF0)
8a9bf000 8a9c8000 crcdisk crcdisk.sys Thu Nov 02 04:52:27 2006 (4549B1CB)
93e0e000 93e3a000 CT20XUT CT20XUT.DLL Mon Mar 05 05:38:04 2007 (45EBF30C)
8a760000 8a7de780 ctaud2k ctaud2k.sys Mon Mar 05 05:36:04 2007 (45EBF294)
93e3a000 93f81000 CTEXFIFX CTEXFIFX.DLL Mon Mar 05 05:38:01 2007 (45EBF309)
8f204000 8f239000 ctoss2k ctoss2k.sys Mon Mar 05 05:35:42 2007 (45EBF27E)
8f239000 8f241000 ctprxy2k ctprxy2k.sys Mon Mar 05 05:36:08 2007 (45EBF298)
8f995000 8f9be000 ctsfm2k ctsfm2k.sys Mon Mar 05 05:35:37 2007 (45EBF279)
9458d000 945a4000 dfsc dfsc.sys Sat Apr 11 00:14:12 2009 (49E01914)
8a98d000 8a99e000 disk disk.sys Sat Apr 11 00:39:14 2009 (49E01EF2)
9f918000 9f91ee20 DLABMFSM DLABMFSM.SYS Fri Aug 18 16:15:47 2006 (44E61FF3)
9f91f000 9f9253e0 DLABOIOM DLABOIOM.SYS Fri Aug 18 16:15:42 2006 (44E61FEE)
9f8f8000 9f8f89c0 DLADResM DLADResM.SYS Fri Aug 18 16:17:02 2006 (44E6203E)
9f8f9000 9f910d20 DLAIFS_M DLAIFS_M.SYS Fri Aug 18 16:14:59 2006 (44E61FC3)
9f911000 9f915aa0 DLAOPIOM DLAOPIOM.SYS Fri Aug 18 16:16:20 2006 (44E62014)
9f916000 9f917dc0 DLAPoolM DLAPoolM.SYS Fri Aug 18 16:15:01 2006 (44E61FC5)
93fdb000 93fe0320 DLARTL_M DLARTL_M.SYS Fri Aug 11 13:33:56 2006 (44DCBF84)
9f93c000 9f952340 DLAUDF_M DLAUDF_M.SYS Fri Aug 18 16:15:12 2006 (44E61FD0)
9f926000 9f93b6c0 DLAUDFAM DLAUDFAM.SYS Fri Aug 18 16:15:30 2006 (44E61FE2)
8a5a4000 8a5c9000 drmk drmk.sys Sat Jan 19 01:53:02 2008 (47919E4E)
8a340000 8a355fe0 DRVMCDB DRVMCDB.SYS Fri Jul 21 14:20:31 2006 (44C11AEF)
9f8ed000 9f8f7600 DRVNDDM DRVNDDM.SYS Fri Aug 11 14:05:15 2006 (44DCC6DB)
945b1000 945bb000 dump_diskdump dump_diskdump.sys Sat Apr 11 00:39:11 2009 (49E01EEF)
945bb000 945c8000 dump_nvstor dump_nvstor.sys Wed Jun 06 16:34:41 2007 (46671A61)
a693f000 a6996880 dump_wmimmc dump_wmimmc.sys Thu Jun 17 21:48:10 2010 (4C1AD05A)
8f9f2000 8f9fc000 Dxapi Dxapi.sys Sat Jan 19 00:36:12 2008 (47918C4C)
8ef15000 8efb6000 dxgkrnl dxgkrnl.sys Thu Sep 24 21:27:14 2009 (4ABC1C72)
9f821000 9f8ed000 eamon eamon.sys Tue Sep 29 06:51:42 2009 (4AC1E6BE)
8a966000 8a98d000 ecache ecache.sys Sat Apr 11 00:40:12 2009 (49E01F2C)
93fe1000 93ffe000 ehdrv ehdrv.sys Tue Sep 29 06:52:16 2009 (4AC1E6E0)
8f965000 8f995000 emupia2k emupia2k.sys Mon Mar 05 05:35:36 2007 (45EBF278)
9447d000 94496000 epfwtdir epfwtdir.sys Tue Sep 29 06:46:23 2009 (4AC1E57F)
a68eb000 a6913000 fastfat fastfat.SYS Sat Apr 11 00:13:52 2009 (49E01900)
8a330000 8a340000 fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
8a2fe000 8a330000 fltmgr fltmgr.sys Sat Apr 11 00:13:59 2009 (49E01907)
93fc4000 93fcd000 Fs_Rec Fs_Rec.SYS Sat Jan 19 00:27:57 2008 (47918A5D)
8a6ef000 8a70a000 fwpkclnt fwpkclnt.sys Sat Apr 11 00:45:42 2009 (49E02076)
8a965000 8a965680 giveio giveio.sys Wed Apr 03 22:33:25 1996 (316334F5)
8f843000 8f965000 ha20x2k ha20x2k.sys Mon Mar 05 05:35:48 2007 (45EBF284)
821c2000 821f5000 hal halmacpi.dll Sat Apr 11 00:13:13 2009 (49E018D9)
8f25f000 8f2ec000 HDAudBus HDAudBus.sys Sat Apr 11 00:42:41 2009 (49E01FC1)
93f81000 93fc0000 HdAudio HdAudio.sys Sat Apr 11 00:43:01 2009 (49E01FD5)
a2729000 a2735000 hidbth hidbth.sys Sat Apr 11 00:43:09 2009 (49E01FDD)
945d1000 945e1000 HIDCLASS HIDCLASS.SYS Sat Apr 11 00:42:47 2009 (49E01FC7)
8f9e4000 8f9ea380 HIDPARSE HIDPARSE.SYS Sat Jan 19 00:53:16 2008 (4791904C)
945c8000 945d1000 hidusb hidusb.sys Sat Apr 11 00:42:48 2009 (49E01FC8)
a08dd000 a094a000 HTTP HTTP.sys Mon Nov 09 05:36:42 2009 (4AF7F0BA)
8a70a000 8a719000 intelppm intelppm.sys Sat Jan 19 00:27:20 2008 (47918A38)
8f3f5000 8f3fd000 IPvEx86 IPvEx86.sys Sun Apr 19 14:59:37 2009 (49EB7499)
8eff5000 8f000000 kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
945e3000 945ec000 kbdhid kbdhid.sys Sat Apr 11 00:38:40 2009 (49E01ED0)
80602000 80609000 kdcom kdcom.dll Sat Apr 11 02:25:29 2009 (49E037D9)
8a5c9000 8a5f3000 ks ks.sys Sat Apr 11 00:38:47 2009 (49E01ED7)
8a35f000 8a3d0000 ksecdd ksecdd.sys Mon Jun 15 08:48:53 2009 (4A364335)
945ec000 945f2300 LHidFilt LHidFilt.Sys Thu Jan 11 22:02:47 2007 (45A6FA57)
a08ba000 a08ca000 lltdio lltdio.sys Sat Jan 19 00:55:03 2008 (479190B7)
8f9eb000 8f9f1400 LMouFilt LMouFilt.Sys Thu Jan 11 22:02:48 2007 (45A6FA58)
9f806000 9f821000 luafv luafv.sys Sat Jan 19 00:30:35 2008 (47918AFB)
80609000 80679000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Apr 11 02:23:19 2009 (49E03757)
8a3ed000 8a3fc000 monitor monitor.sys Sat Jan 19 00:52:19 2008 (47919013)
8a7f4000 8a7ff000 mouclass mouclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
945f3000 945fb000 mouhid mouhid.sys Sat Jan 19 00:49:16 2008 (47918F5C)
8a27a000 8a28a000 mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
a0980000 a0995000 mpsdrv mpsdrv.sys Sat Jan 19 00:54:45 2008 (479190A5)
a0995000 a09b6000 mrxdav mrxdav.sys Sat Apr 11 00:14:39 2009 (49E0192F)
a09b6000 a09d5000 mrxsmb mrxsmb.sys Sat Apr 11 00:14:27 2009 (49E01923)
9f95b000 9f994000 mrxsmb10 mrxsmb10.sys Sat Apr 11 00:14:34 2009 (49E0192A)
a09d5000 a09ed000 mrxsmb20 mrxsmb20.sys Sat Apr 11 00:14:28 2009 (49E01924)
94431000 9443c000 Msfs Msfs.SYS Sat Jan 19 00:28:08 2008 (47918A68)
8a1c8000 8a1d0000 msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
8f353000 8f382000 msiscsi msiscsi.sys Sat Apr 11 00:40:07 2009 (49E01F27)
8a511000 8a53c000 msrpc msrpc.sys Sat Apr 11 00:37:32 2009 (49E01E8C)
8a5f3000 8a5fd000 mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
8a956000 8a965000 mup mup.sys Sat Apr 11 00:14:12 2009 (49E01914)
8a406000 8a511000 ndis ndis.sys Sat Apr 11 00:45:52 2009 (49E02080)
8f3a4000 8f3af000 ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
8f3af000 8f3d2000 ndiswan ndiswan.sys Sat Apr 11 00:46:31 2009 (49E020A7)
8f9be000 8f9cf000 NDProxy NDProxy.SYS Sat Jan 19 00:56:28 2008 (4791910C)
94526000 94534000 netbios netbios.sys Sat Jan 19 00:55:45 2008 (479190E1)
944de000 94510000 netbt netbt.sys Sat Apr 11 00:45:35 2009 (49E0206F)
8a53c000 8a577000 NETIO NETIO.SYS Sat Apr 11 00:46:21 2009 (49E0209D)
9443c000 9444a000 Npfs Npfs.SYS Sat Apr 11 00:14:01 2009 (49E01909)
94583000 9458d000 nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
81e09000 821c2000 nt ntkrpamp.exe Tue Aug 04 05:26:11 2009 (4A77FEB3)
8a803000 8a913000 Ntfs Ntfs.sys Sat Apr 11 00:14:34 2009 (49E0192A)
93fcd000 93fd4000 Null Null.SYS Sat Jan 19 00:49:12 2008 (47918F58)
8ef13000 8ef14040 nvBridge nvBridge.kmd Tue Jan 12 00:18:11 2010 (4B4C0613)
8e407000 8ef12080 nvlddmkm nvlddmkm.sys Tue Jan 12 00:32:34 2010 (4B4C0972)
8a2b0000 8a2bd000 nvstor nvstor.sys Wed Jun 06 16:34:41 2007 (46671A61)
8f241000 8f250300 ohci1394 ohci1394.sys Sat Apr 11 00:43:04 2009 (49E01FD8)
94510000 94526000 pacer pacer.sys Sat Apr 11 00:45:51 2009 (49E0207F)
8a000000 8a00f000 partmgr partmgr.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
8a1d0000 8a1f7000 pci pci.sys Sat Apr 11 00:19:16 2009 (49E01A44)
8a265000 8a26c000 pciide pciide.sys Sat Apr 11 00:39:10 2009 (49E01EEE)
8a26c000 8a27a000 PCIIDEX PCIIDEX.SYS Sat Apr 11 00:39:09 2009 (49E01EED)
a680d000 a68eb000 peauth peauth.sys Mon Oct 23 04:55:32 2006 (453C8384)
8a577000 8a5a4000 portcls portcls.sys Sat Apr 11 00:42:48 2009 (49E01FC8)
80679000 8068a000 PSHED PSHED.dll Sat Apr 11 02:25:32 2009 (49E037DC)
8a356000 8a35eb40 PxHelp20 PxHelp20.sys Mon Jul 24 20:18:21 2006 (44C5634D)
9444a000 94453000 rasacd rasacd.sys Sat Jan 19 00:56:31 2008 (4791910F)
8f38d000 8f3a4000 rasl2tp rasl2tp.sys Sat Jan 19 00:56:33 2008 (47919111)
8f3d2000 8f3e1000 raspppoe raspppoe.sys Sat Apr 11 00:46:30 2009 (49E020A6)
8f3e1000 8f3f5000 raspptp raspptp.sys Sat Jan 19 00:56:34 2008 (47919112)
8a7df000 8a7f4000 rassstp rassstp.sys Sat Apr 11 00:46:40 2009 (49E020B0)
94547000 94583000 rdbss rdbss.sys Sat Apr 11 00:14:26 2009 (49E01922)
94421000 94429000 RDPCDD RDPCDD.sys Sat Jan 19 01:01:08 2008 (47919224)
94429000 94431000 rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
a26dc000 a2705000 rfcomm rfcomm.sys Sat Apr 11 00:43:12 2009 (49E01FE0)
a08ca000 a08dd000 rspndr rspndr.sys Sat Jan 19 00:55:03 2008 (479190B7)
8a1a2000 8a1c8000 SCSIPORT SCSIPORT.SYS Sat Jan 19 00:49:44 2008 (47918F78)
a6913000 a691d000 secdrv secdrv.SYS Wed Sep 13 09:18:32 2006 (45080528)
94469000 9447d000 smb smb.sys Sat Apr 11 00:45:22 2009 (49E02062)
8a954000 8a955480 speedfan speedfan.sys Sun Sep 24 09:28:47 2006 (4516880F)
8a94c000 8a954000 spldr spldr.sys Thu Jun 21 20:29:17 2007 (467B17DD)
a080a000 a08ba000 spsys spsys.sys Tue Mar 10 13:10:28 2009 (49B69F04)
8a098000 8a199000 sptd sptd.sys Mon Mar 23 02:38:33 2009 (49C72E69)
a2603000 a264f000 srv srv.sys Sat Apr 11 00:15:17 2009 (49E01955)
9f994000 9f9bb000 srv2 srv2.sys Mon Sep 14 05:29:49 2009 (4AAE0D0D)
a094a000 a0967000 srvnet srvnet.sys Sat Apr 11 00:15:01 2009 (49E01945)
8a2bd000 8a2fe000 storport storport.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
8f3fd000 8f3fe380 swenum swenum.sys Sat Jan 19 00:49:20 2008 (47918F60)
8a605000 8a6ef000 tcpip tcpip.sys Fri Aug 14 09:48:58 2009 (4A856B4A)
a691d000 a6929000 tcpipreg tcpipreg.sys Fri Aug 14 09:48:21 2009 (4A856B25)
8f382000 8f38d000 TDI TDI.SYS Sat Jan 19 00:57:10 2008 (47919136)
94453000 94469000 tdx tdx.sys Sat Apr 11 00:45:56 2009 (49E02084)
8a3d0000 8a3e0000 termdd termdd.sys Sat Apr 11 00:51:14 2009 (49E021C2)
9a6b0000 9a6b9000 TSDDD TSDDD.dll unavailable (00000000)
8a9f7000 8aa00000 tunmp tunmp.sys Sat Jan 19 00:55:40 2008 (479190DC)
8a9ec000 8a9f7000 tunnel tunnel.sys Sat Jan 19 00:55:50 2008 (479190E6)
8a3e0000 8a3ed000 umbus umbus.sys Sat Jan 19 00:53:40 2008 (47919064)
8a9c8000 8a9df000 usbccgp usbccgp.sys Sat Jan 19 00:53:29 2008 (47919059)
945e1000 945e2700 USBD USBD.SYS Sat Jan 19 00:53:17 2008 (4791904D)
8efcc000 8efdb000 usbehci usbehci.sys Sat Apr 11 00:42:52 2009 (49E01FCC)
8f80e000 8f843000 usbhub usbhub.sys Sat Apr 11 00:43:14 2009 (49E01FE2)
8efc2000 8efcc000 usbohci usbohci.sys Sat Apr 11 00:42:52 2009 (49E01FCC)
8a722000 8a760000 USBPORT USBPORT.SYS Sat Apr 11 00:42:55 2009 (49E01FCF)
93e00000 93e0c000 vga vga.sys Sat Jan 19 00:52:06 2008 (47919006)
94400000 94421000 VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
8a20c000 8a21b000 volmgr volmgr.sys Sat Jan 19 00:49:51 2008 (47918F7F)
8a21b000 8a265000 volmgrx volmgrx.sys Sat Apr 11 00:39:25 2009 (49E01EFD)
8a913000 8a94c000 volsnap volsnap.sys Sat Apr 11 00:39:37 2009 (49E01F09)
94534000 94547000 wanarp wanarp.sys Sat Jan 19 00:56:31 2008 (4791910F)
8efb6000 8efc2000 watchdog watchdog.sys Sat Apr 11 00:22:43 2009 (49E01B13)
8a00f000 8a08b000 Wdf01000 Wdf01000.sys Sat Jan 19 00:52:21 2008 (47919015)
8a08b000 8a098000 WDFLDR WDFLDR.SYS Sat Jan 19 00:52:19 2008 (47919013)
9a490000 9a692000 win32k win32k.sys Fri Aug 14 09:27:05 2009 (4A856629)
8a719000 8a722000 wmiacpi wmiacpi.sys Sat Jan 19 00:32:47 2008 (47918B7F)
8a199000 8a1a2000 WMILIB WMILIB.SYS Sat Jan 19 00:53:08 2008 (47919044)
Unloaded modules:
8f9cf000 8f9e4000 CTHWIUT.DLL
Timestamp: unavailable (00000000)
Checksum: 00000000
9f953000 9f95b000 drmkaud.sys
Checksum: 00000000
8a9c8000 8a9d5000 crashdmp.sys
Checksum: 00000000
8a9d5000 8a9df000 dump_storpor
Checksum: 00000000
8a9df000 8a9ec000 dump_nvstor.
Checksum: 00000000
93e00000 93e09000 kbdhid.sys
Checksum: 00000000
93fc2000 93fc4000 DLACDBHM.SYS
Checksum: 00000000
93fc0000 93fc2000 DLACDBHM.SYS
Checksum: 00000000
93c0f000 93cae000 ctac32k.sys
Checksum: 00000000
8eff5000 8eff7000 DLACDBHM.SYS
Checksum: 00000000
8efdb000 8efdd000 DLACDBHM.SYS
Checksum: 00000000
