z3r010
Staff member
BSOD - Posting Instructions
This will show you how to help provide needed information about your system and dump files. It will not contain any personal or sensitive information about you or your data.
To get better help with your Vista BSOD issue, please follow these steps below.
To Use DM Log Collector
1. Click/tap on the Download button below to download the file below.
2. Save the .exe file to your desktop or other convenient location.3. Double click on the file to run it.
4. If prompted by UAC then, click/tap on Yes (Windows 7/8) or Continue (Vista).
5. A command prompt will now open to get the required information from your system, save the information into a YourComputerName-xxxx.zip file on your desktop, and close.
6. When finished with step 5, do either step 7 or 8 below.
7. If You Have Already Started a Thread in "Crashes and Debugging"
A) Go back to your original thread that you created for your BSOD issue, edit your existing post or reply with a new post, and go to step 9 below.
8. If You Have Not Already Started a Thread in "Crashes and Debugging"NOTE: Please do not create duplicate threads and posts on the same issue. Doing so will only waste your time and the time of other members trying to help.
A) Start a new thread in the Crashes and Debugging forum area, post all details about your BSOD issue, then go to step 9 below.
9. In your BSOD post, upload the created zip file folder into your post.
- Operating System
- Windows 10
- me
- Intel Core i7 5960X Extreme Unlocked
- Asus RAMPAGE V EXTREME
- 32GB (8x4GB) Corsair DDR4 Vengeance LPX Black PC3-24000 3000
- Graphics Card(s)
- 2x 4GB ASUS GTX 980 STRIX CUII
- Creative
- 3 x27" Dell U2714H & 3 x 25" U2515H Dell
- 6 @ 2560x1440
- 3x 1TB Samsung Evo 840's
- PSU
- 1500W ThermalTake Toughpower
- Case
- ThermalTake Level 10 GT
- Cooling
- Enermax Liqtech 240
- Logitech Performance MX
- Surface Ergonomic.
- 350 Mb/s
- Other Info
WinTV NovaTD
HP CP1515n Color Laser
Microsoft LifeCam Cinema
APC 750i Smart UPS
- Operating System
- windows 10
- Surface Pro 3
- 1.9GHz Intel Core i5-4300U (dual-core, 3MB cache, up to 2.9GHz with Turbo Boost)
- 4GB
- Intel HD Graphics 4400
- 12" Multi Touch
- 2160 x 144
- 128GB
- Logitech
- yes
- 350 Mb/s
