Blue screen of death while trying to connect to internet
Well, i`m getting a Blue Screen of Death everytime i try to connect to the internet.
First of all i turn my computer on. Then, i see AVG can`t update, try to connect to the internet, after 10 seconds, piff. Blue Screen..
I`m running Windows Vista Ultimate 32 Bits, and my computer is:
Asus G2s
17" Generic PnP
3GB RAM ( Plus 10 GB of L2cache)
2.2 Ghz Core 2 Duo Santa Rosa
512 MB Geforce Nvidia 8600 GS
300 GB 4200 RPM.
I just formatted my Computer because i had some problems, and after it, this problem appeared.
Something like that appears for me on the Blue Screen:
A problem has been detected and Windows has been shut down to prevent
damage to your computer.
DRIVER_IRQL_NOT_LESS_OR_EQUAL
If this is the first time you've seen this Stop error screen, restart
your computer. If this screen appears again, follow these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or softwre
manufacturer for any Windows updates you might need.
If the problem continues, disable or remove any newly installed
hardware or software. Disable BIOS memory options such as caching or
shadowing. If you need to use Safe Mode to remove or disable
components, restart your computer, press F8 to select Advanced Startup
Options, and then select Safe Mode.
Technical Information:
*** STOP: 0x000000D1 (0x00000000, 0x00000002, 0x00000008, 0x00000000)
(((( For me is MINI-DUMP ))))
Beginning dump of physical memory
Physical memory dump complete
Contact your system administrator or technical support group for
further assistance. (((( For me is MINI-DUMP ))))
.Joe
1337 spammer
Is booting into safe mode an option for you? If so, without running AVG, is your internet connect working?
Well, i just tried it on safe mode, and it works fine !
No stupid Blue Screen when i connect to the PC.
This is when the PC says ( Windows has recovered itself from a unexpected error):
~Problem signature
Problem Event Name BlueScreen
OS Version 6.0.6001.2.1.0.256.1
Locale ID 1033
Additional information about the problem
BCCode 1000007f
BCP1 00000008
BCP2 8015D000
BCP3 00000000
BCP4 00000000
OS Version 6_0_6001
Service Pack 1_0
Product 256_1
Files that help describe the problem
CWindowsMinidumpMini090108-02.dmp
CUsersAdministratorAppDataLocalTempWER-62088-0.sysdata.xml
CUsersAdministratorAppDataLocalTempWER98B5.tmp.version.txt
Read our privacy statement
httpgo.microsoft.comfwlinklinkid=50163&clcid=0x0409
Please what can i do?
Now, the problem is even worse.
My computer doesn`t start anymore...
I Can`t belive i`m going to format again, it is the 15th Time i formatted my Computer since i bought it ( Two Months) ..
What is my problem? Am i retarded?
