Blue Screen on Logon error
FirmShark
Good evening. I am having a slight problem with my Vista Ultimate 32-bit. I've only just installed Vista for the first time and I cannot logon at all. I can logon in safe-mode but cannot logon in normal mode. I have searched around and it seems that it is a driver problem. Only thing is I have checked that I have the updated version of drivers etc. I had a similar problem with XP when I first got this PC. It was to do with the nforce drivers. Updated the driver on XP and it worked fine. But, I tried the same on for Vista and checked there was no problems reported yet the machine keeps giving the blue screen error. The details of the blue screen are below.
Product
Windows
Problem
Shut down unexpectedly
Date
23/12/2008 02:14
Status
Not Reported
Problem signature
Problem Event Name: BlueScreen
OS Version: 6.0.6001.2.1.0.256.1
Locale ID: 2057
Files that help describe the problem
Mini122308-02.dmp
sysdata.xml
Version.txt
Extra information about the problem
BCCode: 1000008e
BCP1: C0000005
BCP2: 00000000
BCP3: 95DC4CF0
BCP4: 00000000
OS Version: 6_0_6001
Service Pack: 1_0
Product: 256_1
I'm not sure if anyone can 'de-code' that and tell me what the problem is. Has anyone else suffered from this problem with nforce drivers?
Thanks
Presario
Banned
Hi.
This may not work but what's the odd's you could do a re-format/re-install or recovery to out of box state? If you can, I highly suggest you download and install ALL UPDATES AND SERVICE PACKS BEFORE ANYTHING ELSE (Of course, you must set a system restore point before you do this!!)
    Toshiba Satellite A215-S7428
    AMD Athlon 64 X2 Dual-Core Processor TK-55 1.8GHz
    3GB DDR2 RAM (1X1GB DDR2 RAM & 1X2GB DDR2 RAM)
    ATI Radeon X1200 Mobile Graphics 128MB
    15.4" Diagnol Widescreen Tru-Brite TFT LCD Display
    1280X800
    160GB (5400RPM)
    56K (Dial-up) : 10/100 ETHERNET : Wi-Fi (Realtek 802.11b/g
    It originally came with 2X1GB DDR2 RAM and I swapped out one of the 1GB DDR2 RAM cards for a 2GB DDR2 RAM card.
