Hi Purefire,
I have looked up the BSOD codes you have provided...
Bug Check 0xB8:
The ATTEMPTED_SWITCH_FROM_DPC bug check has a value of 0x100000B8. This indicates that an illegal operation was attempted by a delayed procedure call (DPC) routine.
Cause: A wait operation, attach process, or yield was attempted from a DPC routine. This is an illegal operation.
Resolving the Problem: The stack trace will lead to the code in the original DPC routine that caused the error
Bug Check 0xD1
The DRIVER_IRQL_NOT_LESS_OR_EQUAL bug check has a value of 0x000000D1. This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
Cause
A driver tried to access an address that is pageable (or that is completely invalid) while the IRQL was too high.
This bug check is usually caused by drivers that have used improper addresses.
If the first parameter has the same value as the fourth parameter, and the third parameter indicates an execute operation, this bug check was likely caused by a driver that was trying to execute code when the code itself was paged out. Possible causes for the page fault include the following:
-The function was marked as pageable and was running at an elevated IRQL (which includes obtaining a lock).
-The function call was made to a function in another driver, and that driver was unloaded.
-The function was called by using a function pointer that was an invalid pointer.
Check BIOS settings and Run MEMTEST, This BSOD is caused by hardware or emulation driver software like Daemon Tools or Nero.
Hope it helps
Steven
I got my new computer last week (5/18/08) and so far I have gotten 5 bluescreens so far...this is really starting to frustrate me. Here are the info for each bluescreen.
1. 5/19/08
Problem Event Name: BlueScreen
BCCode: 100000b8
2. 5/21/08
BCCode: 100000b8
3. 5/22/08
BCCode: d1
4. 5/23/08
BCCode: 100000b8
5. 5/26/08
BCCode: 100000b8
Please help me. Thanks.
