Boot problems
Pc starts but won't boot every time. Loads windows and 30sec. In pc restarts window error recovery starts and reboots ok. Please help!!!
9950 amd be
msi k9a2 platinum main board
x2 4870 graphics cards
x2 tera bit drives in raid stripe
sound blaster platinum card
1200 cwt power supply
johngalt
Antidisestablishmentarian
Hi, michael yancey, and welcome to the forums.
First, a word of advice - don't be sparing with your use of words. We don't want to see how little you can post and get your point across - we want as much information as you can give us. Screen shots go a long way as well.
Now, I am reading this to mean that it loads Windows (to a desktop) and then within 30 seconds it runs into an error, Blue screens, and the reboots, upon which you are asked some sort of recovery question, which you answer, and then it boots up just fine.
Is this correct? If so, we need several things:
  • What do you do as far as the recovery - what selections do you make, etc....
  • When it reboots from the recovery and it boots fine, is there any sort of message?
  • Can you disable Automatic restarting of the machine so we can get you to write out exactly what the BSOD states? (To disable automatic restart, Hold the WIN key down on your keyboard and press the PAUSE key - then click on Advanced Settings link (far left), and then on the Settings button under the Startup and Recovery section of the Advanced tab, and then uncheck Automatically restart. Click OK all the way out.)
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Calssified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    2 * Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM SATA II
    Seagate Barracuda 7200.12 ST1500DL001 1.5 TB SATA II
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    180 Mbit down / 15 Mbit up
    3 VMs built off IP 14971:
    UUP disabled / single VHD | UUP disabled / dual VHDs with moved \User Tree | UUP enabled / single VHD
THANK'S FOR THE REPLY! I do not do a thing after the recovery screen it wait's 30sec then boot in windows.The problem happens when it starts to load the bars at the bottom of screen then it restarts ok...
