Boot Up Problem
Rob S
Hey everyone, this is my first post... I've been having problems for a while now where every now and then my PC would boot up in 600x800 Res. And just this past weekend it won't stop happening, every time I try to boot up it is in 600x800 res. Also there's no way for me to adjust this once it's booted because none of my i/o devices are being recognized (Keys, mouse, headset, even the ethernet ports are not being recognized.) Some help would be excellent, I really don't feel like reinstalling the OS :p Also I'm running 64-Bit Vista Ultimate. My PC knowledge is decent, there's a heck of a lot I don't know though.
    Intel Core 2 Quad-Core processor
    Gigabyte
    4GB RAM
    Nvidia 9800 GTX+
    Viewssonic vx2262wm 22" LCD
    OCZ Gamestream 600w
    Apevia X-Discovery
    Razer Deathadder
    Razer Lycosa
Hi and welcome to vistax64
Rob\
Every I/o device needs a driver to work. If you fill in your system specs (lower left corner of your posts) so we know what kind of hardware you have we can help you locate and install them. You video is displaying the 800x600 because thats the only resolution it can display without the driver
ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Rob\
ken
Thank's for the welcome! :D
But the thing is the drivers just randomly stopped working... they were fine on Friday and I did a restart for an update with my Anti-Virus and then it just started booting in the 800x600 res. And I can't install the driver for my V Card after the PC boots because nothing works...
And also what kind of system specs are you looking for? I feel like such a noob askign that :p
    Gigabyte
    4GB RAM
    Nvidia 9800 GTX+
    OCZ Gamestream 600w
    Apevia X-Discovery
    Razer Deathadder
    Razer Lycosa
Rob\
ken
any clues there??!! ;)
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
hey not to worry everyone starts as a noob
system specs
computer maker, model, ram, cpu, etc
if you look in the lower left corner of your post you will see a thing labeled system specs. Just click on it and fill in whatever you can about your computer. In you case we need the things whose drivers arent working.
BTW it may be your virus update, or a vista update.
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Rob\
ken
This has happened beforeo though, and the Anti-Virus wasn't updated for my restart. It was just an every day shut down. And the next time I rebooted it, it was in 800x600 res and none of the drivers were working. So I don't know if that has a whole lot to do with it :/
    Gigabyte
    4GB RAM
    Nvidia 9800 GTX+
    OCZ Gamestream 600w
    Apevia X-Discovery
    Razer Deathadder
    Razer Lycosa
how old is the computer's cmos battery?
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
    Gigabyte
    4GB RAM
    Nvidia 9800 GTX+
    OCZ Gamestream 600w
    Apevia X-Discovery
    Razer Deathadder
    Razer Lycosa
RS
something has to be causes the settings to be forgotten. how about we look in event viewer (type event viewer in search). go to the windows logs, applications tab and look for any errors (red "X" in left ocrner) that re-occur around the times when you boot up. tell us what the event ID and source codes are
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Where can I do a search if I can't access my desktop? I feel like a total noob right now haha. And also i'm at school right now so I can't access my own PC but i can get back to you with those IDs and source-codes later tonight.
    Gigabyte
    4GB RAM
    Nvidia 9800 GTX+
    OCZ Gamestream 600w
    Apevia X-Discovery
    Razer Deathadder
    Razer Lycosa
If this is any help at all, I had a flash drive plugged in at the time of the problem and it saved this text file on the flash drive which I just found earlier...
Checking file system on E:
The type of the file system is FAT.
One of your disks needs to be checked for consistency. You
may cancel the disk check, but it is strongly recommended
that you continue.
Windows will now check the disk.
Volume Serial Number is DCE7-3B31
Windows has checked the file system and found no problems.
1001127936 bytes total disk space.
98304 bytes in 2 hidden files.
1753088 bytes in 107 folders.
583352320 bytes in 2167 files.
415924224 bytes available on disk.
16384 bytes in each allocation unit.
61104 total allocation units on disk.
25386 allocation units available on disk.
    Gigabyte
    4GB RAM
    Nvidia 9800 GTX+
    OCZ Gamestream 600w
    Apevia X-Discovery
    Razer Deathadder
    Razer Lycosa
Im sorry its n ot you its me. Im helping both here and in win 7 and when it gets hectic I have a tendancy to go to warp drive.
If you cant boot up normally you might be able to boot into safe mode. you probably can because in safe mode (hit F8 repeatedly when booting) non of the drivers are loaded.
there is one thing you can do. its called a system file check. its easy and not destructive to your data. to run it you go to start>search>type cmd>right click and run as admin>type sfc /scannow and tell us the results
Again im sorry for the warp drive
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
ken
haha don't even worry about :p and I totally forgot about safe mode... I'll have to give that a try later, thank's for the help! I'll get back to you with more details after I give safe mode a try and what-not. Thanks again!
    Gigabyte
    4GB RAM
    Nvidia 9800 GTX+
    OCZ Gamestream 600w
    Apevia X-Discovery
    Razer Deathadder
    Razer Lycosa
rob
my pleasure. Im at 1/2 impulse so plenty of time. I will subscribe to this thread so if anything is posted I will get e-mail. talk to you later
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
With Vista, at least in my experiences, there shouldn't be many drivers that Vista doesn't take care of for you. So I don't think it will do much good to install them again unless you have to.
If you have access to a voltage meter, I guess it would be a cheap check on the CMOS Battery as mention above, but if that was going out I think you'd be having troubles far before you notice the resolution.
If you have recently added new hardware remove it and its driver completely for a while and see if that doesn't fix something.
I am leaning towards Virus
Anti virus programs have been known to miss now and then. I am sure something below is mentioned above already but...
If you can boot up, login, and just get to an idle in Windows normal mode. Then do the Ctrl-Alt-Delete thingy to get to TASK MANAGER. Go to the PROCESSES TAB. DO NOT have any programs running and click on the CPU heading so that System Idle is first and everything else descends from there (Picture below). If a program is using resources that you have no clue what it is, Google the "said.exe" name in left column. Check a few out. Then with it up try install one of the missing drivers and see if an unfamiliar .exe spikes while loading and you lose that driver google that one. If you are having trouble getting booted and logged in try it in SAFE MODE.
Do you have any disk utility software that has bootable media like System Mechanic? If so run a registry scan and see if there is a correlation in grouped errors. Some of these programs also have virus checking functions in them as well. So maybe close down your Active Antivirus so it doesn't conflict and run a different one. Some Internet providers offer Full Antivirus Programs like Mcafee or supplemental scans and utilities for free. Check with them. But also know some are horrible to try to remove completely.
Goodluck in getting through
    AMD Phenom I 9850be quad core clocked to 3.2Ghz
    ASUS M3N72-D
    G.Skill 2x2Gig DDR2 1066
    ATi Sapphire 4870 1Gig Toxic and Nvidia XFX 8500GT
    On Board
    Vizio 37" HDTV, Samsung 23" LCD, Samsung 19" LCD
    Various per monitor
    3 Seagate 640GB SATA drives in RAID 5 1 Seagate 320GB for OS 1 Notebook 250GB for OS backups
    Corsair TX750w
    Thermaltake Full Tower Armor
    Swiftech H20-220
    Razor Death Adder
    Microsoft Ergonomic 4000
    DSL
If you can boot safe mode, start installing the drivers, starting with video. While you are there downad all the drivers you need, video and sound, wireless etc and then disconnect from the internet, uninstall the antivirus, then install the drivers one by one. Reinstall the antivirus when you are done.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
I would do this but I can't do anything when i get to my desktop because my i/o devices don't work.
    Gigabyte
    4GB RAM
    Nvidia 9800 GTX+
    OCZ Gamestream 600w
    Apevia X-Discovery
    Razer Deathadder
    Razer Lycosa
I can't boot in safe mode because when I get to "Windows Error Recovery" screen my arrow keys won't let me move the option up or down to get to "Safe Mode." This feature has never worked ever on this computer. I can't even press "Enter," I just have to wait for the seconds to count down.
    Gigabyte
    4GB RAM
    Nvidia 9800 GTX+
    OCZ Gamestream 600w
    Apevia X-Discovery
    Razer Deathadder
    Razer Lycosa
Rob
so you cant safe mode boot?
you cant boot from the dvd?
you dont have a backup to restore from?
We can get you to boot. but your best bet is probably going to be a clean install. let us know what you want to do
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Rob
ken
Do you have skype or MSN Messenger to talk on right now?
    Gigabyte
    4GB RAM
    Nvidia 9800 GTX+
    OCZ Gamestream 600w
    Apevia X-Discovery
    Razer Deathadder
    Razer Lycosa
