I have a dual boot system using two hard drives, both with Vista SP2 and up to date.
Last week I was having a slowdown problem on the drive I use as my primary. I did all kinds of testing to try to determine the cause but came up empty handed. All the while, I was running SFC repeatedly because it kept finding corrupt files. I shut down last night and when I rebooted this morning, the desktop itself is the one from the other secondary hard drive while the task bar is the correct one. However, programs I normally run that are in the taskbar and desktop that aren't on the secondary drive, won't run any more. After checking, I find that Vista is using the registry from the secondary drive while the contents of all my partitions (3) on the primary are correct.
I had an image stored on the secondary drive but I can't run it because Windows Explorer doesn't see the C: on that drive. It does see the other two partitions on that drive.
In addition, the secondary drive will no longer boot and asks me to do a repair.
Trouble is, if I run a repair on the secondary drive, what's that going to do in regards to booting from the primary drive since the latter is using the registry from the secondary drive?
Anybody got any ideas besides wiping both and reinstalling Vista?
- Operating System
- Vista Home Premium 64 bit SP2
- Cyberpower
- Intel Quad CPU Q6700 2.67 GHZ
- NVIDIA 780i
- 4 GB
- Graphics Card(s)
- MSI GTX 560 TI Twin Frozr
- Sound Blaster SB Audigy
- Viewsonic VG2436
- 1920x1080p
Samsung HD 105SI
WDC WD20
- Case
- Apevia XJupiter
- Cooling
- air
- Logitech MX 600
- Logitech MX 3200
- 30 Mbps
