BOOTMGR is compressed - i have no Vista cd
2
Hi, i turned on my computer today and bootmgr is compressed press Ctrl+Alt+Del to restart. I have google it online to try fix it but all i can find is i need the vista cd but i dont have the cd as the computer was given to me and all i got was computer and plug.
Is it possible to use any vista cd from someone else??
Please help i miss my computer.
Thanks Julie
2,456
Location
NY USA
Jul
Do you have a friend you can borrow a vista cd from?
    Dell Inspiron E 1405
    2@2.0
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
SIW2
2,741
Download the recovery disc - gives you the system recovery options. ( get the same bit version , 32 or 64 as you currently have installed )
torrent:
Windows Vista Recovery Disc Download — The NeoSmart Files
direct d/l:
( might be in be in German - select your language at the first screen that pops up where you select Language and keyboard) )
Vista Recovery-CD Downloads Systemtools - Go Windows Vista - Forum News Hilfe Board-
When it has found the installed o/s , click Next
Click the command prompt, type notepad, press enter.
Notepad pops up - click File then click Save.
Navigate to the drive - rt click it , select Properties.
Untick Compress this Drive, Apply, OK.
    Intel E8400
    ASRock1333-GLAN R2.0
    2gb DDR2 800
    nvidia 9500GT 1gb
