bootmgr is missing/compressed message - 64 bit compatability
2
I am having the bootmgr is missing/compressed message problem, I have read all the solutions and am sure I can fix the problem, however I cannot get past the "windows is loading files" because once that finishes I get another message stating that windows cannot start because I am attempting to load a 64 bit application and my cpu is not compatible with 64 bit mode. If anyone can help me with this I would appreciate it. Thanks.
Shadowjk
Network Enthusiast
2,180
Location
Northamptonshire, England
That means that you have a Program that is for 64-Bit only do you know what Program it is when you downloaded it did you have a Choice between 32-Bit and 64-Bit
Hope This Helps,
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
richc46
Staff member
20,105
Location
Fairfield County, CT
2
ok i know what to do once i get to the repair screen, my problem is i cannot get there because the disk i am using to reboot is a 64 bit and apparently my laptop is 32 bit, i need to know if there is a way to change this using the bios or something else, once i can get the disk to load im good, thanks for any help.
Bare Foot Kid
R.I.P. August 13th 2014
2,616
Location
The Lowcountry
Hello lawtech328, welcome to Vista Forums!
Have a look at the tutorial at the link below; be sure to download the correct 32-bit ISO; be sure to post back to keep us informed.
How to Create a Vista Recovery Disc
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
