BSOD: 1000007e
denniscompact
Hi.
So yesterday I decided to update the drivers to my graphic card (GeForce 9600 GT). Everything seemed fine, but this morning I got the dreaded BSOD. I figured it was because of the driver update, so I have tried to roll back the drivers and to reinstall the original drivers (off the CD that came with the card), but the problem still persists. I am out of ideas and need help. Upon booting safe mode, I get this:
Code:
Problem signature:
  Problem Event Name:    BlueScreen
  OS Version:    6.0.6002.2.1.144.768.3
  Locale ID:    1033
Additional information about the problem:
  BCCode:    1000007e
  BCP1:    C0000006
  BCP2:    8291B03D
  BCP3:    8D90C930
  BCP4:    8D90C62C
  OS Version:    6_0_6002
  Service Pack:    1_144
  Product:    768_1
Files that help describe the problem:
  C:\Windows\Minidump\Mini011811-09.dmp
  C:\Users\PC\AppData\Local\Temp\WER-141368-0.sysdata.xml
  C:\Users\PC\AppData\Local\Temp\WER5753.tmp.version.txt
Read our privacy statement:
  [url=http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409]Microsoft Online Crash Analysis[/url]
Can I get some advise on what to do? I am running a retail version of windows vista home premium 32bit.
richc46
Code:
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\richc46\AppData\Local\Temp\Temp13_Windows_NT6_BSOD_jcgriff2[1].zip\Windows_NT6_BSOD_jcgriff2\Mini112610-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 1Ð) MP (2 procs) Free x86 compatible
Built by: 6002.18209.x86fre.vistasp2_gdr.100218-0019
Machine Name:
Kernel base = 0x8261c000 PsLoadedModuleList = 0x82733c70
Debug session time: Fri Nov 26 16:11:52.305 2010 (GMT-5)
System Uptime: 0 days 10:21:35.226
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image \SystemRoot\System32\DRIVERS\srvnet.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for srvnet.sys
*** ERROR: Module load completed but symbols could not be loaded for srvnet.sys
BugCheck 1000008E, {c0000005, a2087df1, aa98c890, 0}
Unable to load image \SystemRoot\System32\Drivers\avgtdix.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for avgtdix.sys
*** ERROR: Module load completed but symbols could not be loaded for avgtdix.sys
Probably caused by : srvnet.sys ( srvnet+bdf1 )
Followup: MachineOwner
0: kd> !analyze -v
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003.  This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG.  This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG.  This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: a2087df1, The address that the exception occurred at
Arg3: aa98c890, Trap Frame
Arg4: 00000000
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
FAULTING_IP:
srvnet+bdf1
a2087df1 8b08            mov     ecx,dword ptr [eax]
TRAP_FRAME:  aa98c890 -- (.trap 0xffffffffaa98c890)
ErrCode = 00000000
eax=00000000 ebx=8801ae70 ecx=aa98c914 edx=00000000 esi=8801adc0 edi=8801afd8
eip=a2087df1 esp=aa98c904 ebp=aa98c92c iopl=0         nv up ei ng nz na pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010286
srvnet+0xbdf1:
a2087df1 8b08            mov     ecx,dword ptr [eax]  ds:0023:00000000=????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0x8E
PROCESS_NAME:  avgnsx.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from a208411c to a2087df1
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
aa98c92c a208411c 8801ae70 a208c3a8 8801ae70 srvnet+0xbdf1
aa98c948 a2083fc6 0001ae70 8801afd8 8801ae70 srvnet+0x811c
aa98c970 a2082c83 0001ae70 aa98cb04 8805f620 srvnet+0x7fc6
aa98cab8 91d937cf 8801ae70 00000000 854755d4 srvnet+0x6c83
aa98cae8 91d99b48 8805f620 0098cb04 8800e540 afd!WskProTLEVENTReceive+0xa8
aa98cb1c 91d12e56 87f3fa40 8840a100 00000820 afd!WskTdiEHReceive+0x1f2
aa98cb7c 91d131ac 0000e4c8 00000000 8a70ef3c avgtdix+0x4e56
aa98cb94 91d13cd1 0000e4c8 8a70ef3c 00000089 avgtdix+0x51ac
aa98cbd0 91d0f2a4 857b8398 87f1ab28 877e6be8 avgtdix+0x5cd1
aa98cc1c 91d1157f 877e6be8 857b8398 aa98cc44 avgtdix+0x12a4
aa98cc2c 826609c6 877e6be8 857b8398 857b8398 avgtdix+0x357f
aa98cc44 82862761 87f1ab28 857b8398 857b8408 nt!IofCallDriver+0x63
aa98cc64 82862f06 877e6be8 87f1ab28 00000000 nt!IopSynchronousServiceTail+0x1d9
aa98cd00 82863fd0 877e6be8 857b8398 00000000 nt!IopXxxControlFile+0x6b7
aa98cd34 82666c7a 00000310 0000034c 00000000 nt!NtDeviceIoControlFile+0x2a
aa98cd34 76f05e74 00000310 0000034c 00000000 nt!KiFastCallEntry+0x12a
0173fd58 00000000 00000000 00000000 00000000 0x76f05e74
STACK_COMMAND:  kb
FOLLOWUP_IP:
srvnet+bdf1
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  srvnet+bdf1
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: srvnet
IMAGE_NAME:  srvnet.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4b22304e
FAILURE_BUCKET_ID:  0x8E_srvnet+bdf1
0: kd> lmtsmn
start    end        module name
90ab5000 90ac2080   1394BUS  1394BUS.SYS  Sat Jan 19 00:53:27 2008 (47919057)
805b8000 805fe000   acpi     acpi.sys     Sat Apr 11 00:19:03 2009 (49E01A37)
91d8e000 91dd6000   afd      afd.sys      Sat Apr 11 00:47:01 2009 (49E020C5)
90b12000 90b49000   agq20orr agq20orr.SYS Tue Apr 07 12:06:14 2009 (49DB79F6)
90b49000 90b81000   ala4hhdb ala4hhdb.SYS Sat Mar 21 10:47:30 2009 (49C4FE02)
90ace000 90ad6000   ASACPI   [B]ASACPI.sys[/B]   Wed Oct 18 01:44:46 2006 (4535BF4E)
924bd000 924be440   AsIO     AsIO.sys     Mon Dec 17 04:10:20 2007 (47663CFC)
8b9e2000 8b9eb000   asyncmac asyncmac.sys Sat Jan 19 00:56:29 2008 (4791910D)
8b2bd000 8b2c5000   atapi    atapi.sys    Sat Apr 11 00:39:09 2009 (49E01EED)
8b2c5000 8b2e3000   ataport  ataport.SYS  Sat Apr 11 00:39:10 2009 (49E01EEE)
9ec07000 9ec4a000   atksgt   atksgt.sys   Sun May 10 10:50:58 2009 (4A06E9D2)
9a530000 9a57c000   ATMFD    ATMFD.DLL    Wed May 26 10:47:41 2010 (4BFD348D)
92467000 9249a300   avgldx86 avgldx86.sys Thu Jun 03 17:05:19 2010 (4C08190F)
92461000 92466940   avgmfx86 avgmfx86.sys Sun Apr 25 17:05:02 2010 (4BD4AE7E)
91d0e000 91d47b00   avgtdix  avgtdix.sys  Thu Jun 03 17:08:25 2010 (4C0819C9)
91c7f000 91c86000   Beep     Beep.SYS     Sat Jan 19 00:49:10 2008 (47918F56)
8048f000 80497000   BOOTVID  BOOTVID.dll  Sat Jan 19 02:27:15 2008 (4791A653)
a2099000 a20b2000   bowser   bowser.sys   Sat Jan 19 00:28:26 2008 (47918A7A)
90e0c000 90ef0780   CamthWDM CamthWDM.sys Sat Jan 26 02:50:49 2008 (479AE659)
9a520000 9a52e000   cdd      cdd.dll      unavailable (00000000)
9ed6b000 9ed81000   cdfs     cdfs.sys     Sat Jan 19 00:28:02 2008 (47918A62)
90afa000 90b12000   cdrom    cdrom.sys    Sat Apr 11 00:39:17 2009 (49E01EF5)
804d8000 805b8000   CI       CI.dll       Sat Apr 11 02:25:22 2009 (49E037D2)
8b9a8000 8b9c9000   CLASSPNP CLASSPNP.SYS Sat Apr 11 00:39:05 2009 (49E01EE9)
80497000 804d8000   CLFS     CLFS.SYS     Sat Apr 11 00:13:51 2009 (49E018FF)
924fa000 92507000   crashdmp crashdmp.sys Sat Apr 11 00:39:12 2009 (49E01EF0)
8b9c9000 8b9d2000   crcdisk  crcdisk.sys  Sat Jan 19 00:50:29 2008 (47918FA5)
9244a000 92461000   dfsc     dfsc.sys     Sat Apr 11 00:14:12 2009 (49E01914)
8b997000 8b9a8000   disk     disk.sys     Sat Apr 11 00:39:14 2009 (49E01EF2)
91c39000 91c5e000   drmk     drmk.sys     Sat Jan 19 01:53:02 2008 (47919E4E)
92512000 9251a000   dump_atapi dump_atapi.sys Sat Apr 11 00:39:09 2009 (49E01EED)
92507000 92512000   dump_dumpata dump_dumpata.sys Sat Apr 11 00:39:09 2009 (49E01EED)
9251a000 92524000   Dxapi    Dxapi.sys    Sat Jan 19 00:36:12 2008 (47918C4C)
8b71e000 8b7bf000   dxgkrnl  dxgkrnl.sys  Thu Sep 24 21:27:14 2009 (4ABC1C72)
8b970000 8b997000   ecache   ecache.sys   Sat Apr 11 00:40:12 2009 (49E01F2C)
9ed43000 9ed6b000   fastfat  fastfat.SYS  Sat Apr 11 00:13:52 2009 (49E01900)
90ac3000 90ace000   fdc      fdc.sys      Sat Jan 19 00:49:37 2008 (47918F71)
8b323000 8b333000   fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
909e7000 909f1000   flpydisk flpydisk.sys Sat Jan 19 00:49:37 2008 (47918F71)
807be000 807f0000   fltmgr   fltmgr.sys   Sat Apr 11 00:13:59 2009 (49E01907)
91c6f000 91c78000   Fs_Rec   Fs_Rec.SYS   unavailable (00000000)
8b6f4000 8b70f000   fwpkclnt fwpkclnt.sys Sat Apr 11 00:45:42 2009 (49E02076)
8b96f000 8b96f680   giveio   giveio.sys   Wed Apr 03 22:33:25 1996 (316334F5)
829d5000 82a08000   hal      halmacpi.dll Sat Apr 11 00:13:13 2009 (49E018D9)
90fa5000 90fa9c00   hamachi  hamachi.sys  Thu Feb 19 05:36:27 2009 (499D362B)
90a08000 90a95000   HDAudBus HDAudBus.sys Sat Apr 11 00:42:41 2009 (49E01FC1)
8b590000 8b5a0000   HIDCLASS HIDCLASS.SYS Sat Apr 11 00:42:47 2009 (49E01FC7)
909f1000 909f7380   HIDPARSE HIDPARSE.SYS Sat Jan 19 00:53:16 2008 (4791904C)
9249b000 924a4000   hidusb   hidusb.sys   Sat Apr 11 00:42:48 2009 (49E01FC8)
a200f000 a207c000   HTTP     HTTP.sys     Sat Feb 20 15:53:31 2010 (4B804BCB)
8b70f000 8b71e000   intelppm intelppm.sys Sat Jan 19 00:27:20 2008 (47918A38)
90fc3000 90fce000   kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
91c5e000 91c67000   kbdhid   kbdhid.sys   Sat Apr 11 00:38:40 2009 (49E01ED0)
80407000 8040e000   kdcom    kdcom.dll    Sat Apr 11 02:25:29 2009 (49E037D9)
90efe000 90f28000   ks       ks.sys       Sat Apr 11 00:38:47 2009 (49E01ED7)
8b36c000 8b3dd000   ksecdd   ksecdd.sys   Mon Jun 15 08:48:53 2009 (4A364335)
90a95000 90aa5000   L1E60x86 L1E60x86.sys Tue Jul 01 04:28:34 2008 (4869EAB2)
9ec4a000 9ec4e880   lirsgt   lirsgt.sys   Sat Mar 07 10:17:27 2009 (49B29007)
8b9d2000 8b9e2000   lltdio   lltdio.sys   Sat Jan 19 00:55:03 2008 (479190B7)
92533000 9254e000   luafv    luafv.sys    Sat Jan 19 00:30:35 2008 (47918AFB)
90fe3000 90fff800   mcdbus   mcdbus.sys   Mon Jul 28 05:19:27 2008 (488D8F1F)
8040e000 8047e000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Apr 11 02:23:19 2009 (49E03757)
92524000 92533000   monitor  monitor.sys  Sat Jan 19 00:52:19 2008 (47919013)
90fce000 90fd9000   mouclass mouclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
91c67000 91c6f000   mouhid   mouhid.sys   Sat Jan 19 00:49:16 2008 (47918F5C)
8b2ad000 8b2bd000   mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
a20b2000 a20c7000   mpsdrv   mpsdrv.sys   Sat Jan 19 00:54:45 2008 (479190A5)
a20c7000 a20e8000   mrxdav   mrxdav.sys   Sat Apr 11 00:14:39 2009 (49E0192F)
a20e8000 a2107000   mrxsmb   mrxsmb.sys   Tue Feb 23 06:10:12 2010 (4B83B794)
a2107000 a2140000   mrxsmb10 mrxsmb10.sys Tue Feb 23 06:10:17 2010 (4B83B799)
a2140000 a2158000   mrxsmb20 mrxsmb20.sys Tue Feb 23 06:10:12 2010 (4B83B794)
91cd6000 91ce1000   Msfs     Msfs.SYS     unavailable (00000000)
807f0000 807f8000   msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
90b90000 90bbf000   msiscsi  msiscsi.sys  Sat Apr 11 00:40:07 2009 (49E01F27)
8b519000 8b544000   msrpc    msrpc.sys    unavailable (00000000)
90e02000 90e0c000   mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
8b960000 8b96f000   mup      mup.sys      Sat Apr 11 00:14:12 2009 (49E01914)
8b2e3000 8b323000   mv61xx   mv61xx.sys   Tue Jun 10 06:25:20 2008 (484E5690)
8b40e000 8b519000   ndis     ndis.sys     Sat Apr 11 00:45:52 2009 (49E02080)
90f3f000 90f4a000   ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
90f4a000 90f6d000   ndiswan  ndiswan.sys  Sat Apr 11 00:46:31 2009 (49E020A7)
8b57f000 8b590000   NDProxy  NDProxy.SYS  Sat Jan 19 00:56:28 2008 (4791910C)
91dec000 91dfa000   netbios  netbios.sys  Sat Jan 19 00:55:45 2008 (479190E1)
91d48000 91d7a000   netbt    netbt.sys    Sat Apr 11 00:45:35 2009 (49E0206F)
8b544000 8b57f000   NETIO    NETIO.SYS    Sat Apr 11 00:46:21 2009 (49E0209D)
91ce1000 91cef000   Npfs     Npfs.SYS     Sat Apr 11 00:14:01 2009 (49E01909)
92440000 9244a000   nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
8261c000 829d5000   nt       ntkrpamp.exe Thu Feb 18 06:01:28 2010 (4B7D1E08)
8b80d000 8b91d000   Ntfs     Ntfs.sys     Sat Apr 11 00:14:34 2009 (49E0192A)
91c78000 91c7f000   Null     Null.SYS     unavailable (00000000)
90969000 9096a040   nvBridge nvBridge.kmd Fri Mar 27 14:16:24 2009 (49CD17F8)
90207000 909685c0   nvlddmkm nvlddmkm.sys Fri Mar 27 14:52:31 2009 (49CD206F)
90aa5000 90ab4300   ohci1394 ohci1394.sys Sat Apr 11 00:43:04 2009 (49E01FD8)
91dd6000 91dec000   pacer    pacer.sys    Sat Apr 11 00:45:51 2009 (49E0207F)
8b230000 8b23f000   partmgr  partmgr.sys  Sat Apr 11 00:39:19 2009 (49E01EF7)
8b209000 8b230000   pci      pci.sys      Sat Apr 11 00:19:16 2009 (49E01A44)
8b298000 8b29f000   pciide   pciide.sys   Sat Apr 11 00:39:10 2009 (49E01EEE)
8b29f000 8b2ad000   PCIIDEX  PCIIDEX.SYS  Sat Apr 11 00:39:09 2009 (49E01EED)
8b333000 8b36c000   PCTCore  PCTCore.sys  Sun Mar 28 18:47:11 2010 (4BAFDC6F)
90fb0000 90fb2300   PdiPorts PdiPorts.sys Thu Nov 16 19:31:13 2006 (455D02D1)
9ec4f000 9ed2d000   peauth   peauth.sys   Mon Oct 23 04:55:32 2006 (453C8384)
91c0c000 91c39000   portcls  portcls.sys  Sat Apr 11 00:42:48 2009 (49E01FC8)
8047e000 8048f000   PSHED    PSHED.dll    Sat Apr 11 02:25:32 2009 (49E037DC)
91cef000 91cf8000   rasacd   rasacd.sys   Sat Jan 19 00:56:31 2008 (4791910F)
90f28000 90f3f000   rasl2tp  rasl2tp.sys  Sat Jan 19 00:56:33 2008 (47919111)
90f6d000 90f7c000   raspppoe raspppoe.sys Sat Apr 11 00:46:30 2009 (49E020A6)
90f7c000 90f90000   raspptp  raspptp.sys  Sat Jan 19 00:56:34 2008 (47919112)
90f90000 90fa5000   rassstp  rassstp.sys  Sat Apr 11 00:46:40 2009 (49E020B0)
92404000 92440000   rdbss    rdbss.sys    Sat Apr 11 00:14:26 2009 (49E01922)
91cc6000 91cce000   RDPCDD   RDPCDD.sys   Sat Jan 19 01:01:08 2008 (47919224)
91cce000 91cd6000   rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
8b5e8000 8b5fb000   rspndr   rspndr.sys   Sat Jan 19 00:55:03 2008 (479190B7)
91a02000 91c0b980   RTKVHDA  RTKVHDA.sys  Tue May 20 05:58:56 2008 (4832A0E0)
90fd9000 90fe2080   SaiBus   SaiBus.sys   Wed Jun 03 05:43:07 2009 (4A2645AB)
90a00000 90a03700   SaiMini  SaiMini.sys  Wed Jun 03 05:43:06 2009 (4A2645AA)
8b5db000 8b5e8000   SCDEmu   SCDEmu.SYS   Sun Nov 02 03:44:10 2008 (490D685A)
80798000 807be000   SCSIPORT SCSIPORT.SYS Sat Jan 19 00:49:44 2008 (47918F78)
9ed2d000 9ed37000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
90af0000 90afa000   serenum  serenum.sys  Sat Jan 19 00:49:29 2008 (47918F69)
90ad6000 90af0000   serial   serial.sys   Sat Jan 19 00:49:34 2008 (47918F6E)
91d7a000 91d8e000   smb      smb.sys      Sat Apr 11 00:45:22 2009 (49E02062)
8b95e000 8b95f480   speedfan speedfan.sys Sun Sep 24 09:28:47 2006 (4516880F)
8b956000 8b95e000   spldr    spldr.sys    Thu Jun 21 20:29:17 2007 (467B17DD)
9254e000 925fe000   spsys    spsys.sys    Tue Mar 10 13:10:28 2009 (49B69F04)
8068e000 8078f000   sptd     sptd.sys     Mon Mar 23 02:38:33 2009 (49C72E69)
a217f000 a21cd000   srv      srv.sys      Fri Dec 11 06:43:28 2009 (4B223060)
a2158000 a217f000   srv2     srv2.sys     Mon Sep 14 05:29:49 2009 (4AAE0D0D)
a207c000 a2099000   srvnet   srvnet.sys   Fri Dec 11 06:43:10 2009 (4B22304E)
90bbf000 90c00000   storport storport.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
90ef1000 90efdf00   STREAM   STREAM.SYS   Sat Apr 11 00:42:47 2009 (49E01FC7)
90e00000 90e01380   swenum   swenum.sys   Sat Jan 19 00:49:20 2008 (47918F60)
8b60a000 8b6f4000   tcpip    tcpip.sys    Thu Feb 18 06:28:54 2010 (4B7D2476)
9ed37000 9ed43000   tcpipreg tcpipreg.sys Tue Dec 08 12:26:18 2009 (4B1E8C3A)
909cf000 909da000   TDI      TDI.SYS      Sat Jan 19 00:57:10 2008 (47919136)
91cf8000 91d0e000   tdx      tdx.sys      Sat Apr 11 00:45:56 2009 (49E02084)
90fb3000 90fc3000   termdd   termdd.sys   Sat Apr 11 00:51:14 2009 (49E021C2)
9a500000 9a509000   TSDDD    TSDDD.dll    Sat Jan 19 01:01:09 2008 (47919225)
8b800000 8b809000   tunmp    tunmp.sys    Sat Jan 19 00:55:40 2008 (479190DC)
8b9f2000 8b9fd000   tunnel   tunnel.sys   Thu Feb 18 06:28:13 2010 (4B7D244D)
924bf000 924fa000   udfs     udfs.sys     Sat Apr 11 00:13:59 2009 (49E01907)
909da000 909e7000   umbus    umbus.sys    Sat Jan 19 00:53:40 2008 (47919064)
924a6000 924bd000   usbccgp  usbccgp.sys  Sat Jan 19 00:53:29 2008 (47919059)
924a4000 924a5700   USBD     USBD.SYS     Sat Jan 19 00:53:17 2008 (4791904D)
909c0000 909cf000   usbehci  usbehci.sys  Sat Apr 11 00:42:52 2009 (49E01FCC)
8b7bf000 8b7f4000   usbhub   usbhub.sys   Sat Apr 11 00:43:14 2009 (49E01FE2)
90982000 909c0000   USBPORT  USBPORT.SYS  Sat Apr 11 00:42:55 2009 (49E01FCF)
90977000 90982000   usbuhci  usbuhci.sys  Sat Jan 19 00:53:20 2008 (47919050)
91c99000 91ca5000   vga      vga.sys      Sat Jan 19 00:52:06 2008 (47919006)
91ca5000 91cc6000   VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
8b5a0000 8b5db000   vmm      vmm.sys      Fri May 15 08:27:51 2009 (4A0D5FC7)
90b81000 90b90000   VMNetSrv VMNetSrv.sys Wed Jan 24 07:05:29 2007 (45B74B89)
8b23f000 8b24e000   volmgr   volmgr.sys   Sat Jan 19 00:49:51 2008 (47918F7F)
8b24e000 8b298000   volmgrx  volmgrx.sys  Sat Apr 11 00:39:25 2009 (49E01EFD)
8b91d000 8b956000   volsnap  volsnap.sys  Sat Apr 11 00:39:37 2009 (49E01F09)
91c86000 91c99000   wanarp   wanarp.sys   Sat Jan 19 00:56:31 2008 (4791910F)
90faa000 90faf020   wanatw4  wanatw4.sys  Tue Jul 16 11:23:14 2002 (3D343A62)
9096b000 90977000   watchdog watchdog.sys Sat Apr 11 00:22:43 2009 (49E01B13)
80605000 80681000   Wdf01000 Wdf01000.sys Sat Jan 19 00:52:21 2008 (47919015)
80681000 8068e000   WDFLDR   WDFLDR.SYS   Sat Jan 19 00:52:19 2008 (47919013)
9a2e0000 9a4e3000   win32k   win32k.sys   Sat May 01 10:13:35 2010 (4BDC370F)
8078f000 80798000   WMILIB   WMILIB.SYS   Sat Jan 19 00:53:08 2008 (47919044)
Unloaded modules:
8b9d2000 8b9df000   crashdmp.sys
    Timestamp: unavailable (00000000)
    Checksum:  00000000
8b9df000 8b9ea000   dump_ataport
    Checksum:  00000000
8b9ea000 8b9f2000   dump_atapi.s
    Checksum:  00000000
91c86000 91c99000   i8042prt.sys
    Checksum:  00000000
Each step given below is important and must be performed. Regardless of placement or other variables.
Uninstall and AVG (Anti Virus and install Microsoft Security Essentials) use the uninstall tool
AVG Uninstall Tool | CRYSTALIDEA Software
Update the below named driver, from Asus.
ASACPI.sys
Update outdated drivers
Code:
ASACPI.sys   Wed Oct 18 01:44:46 2006
The reports that you have submitted reveal clues to the cause of your problem. They do not give a definitive answer. The more reports that we receive the more clues are made available improving our chances of finding a solution to your problem. You may have to experience several more BSODs until the final answer is discovered.
If overclocking restore normal settings
SFC /scannow
System Files - SFC Command
Scan with your Anti Virus
Update outdated listed drivers. If I have inadvertently listed any Microsoft Drivers, they can be ignored. If the list is extensive I have included the driver verifier test so that you may determine which drivers are in need of immediate attention.
Asacpi.sys is a driver from the Austek Computer Corp. Your driver is very old and is known to cause BSOD's in current Windows versions; it must be updated
http://support.asus.com/download/download.aspx?SLanguage=en-us
How to Find Drivers
search Google for the name of the driver
- compare the Google results with what's installed on your system to figure out which device/program it belongs to
- visit the web site of the manufacturer of the hardware/program to get the latest drivers (DON'T use Windows Update or the Update driver function of Device Manager).
- if there are difficulties in locating them, post back with questions and someone - will help you search Google for the name of the driver
- - if there are difficulties in locating them, post back with questions and someone will try and help you locate the appropriate program.
- The most common drivers are listed on this page: http://www.carrona.org/dvrref.html
- - Driver manufacturer links are on this page: http://www.carrona.org/drvrdown.html
and here
http://www.edbott.com/weblog/the-vista-master-driver-list/
To remove any left over driver remnants, especially from graphics cards, use driver sweeper
www.guru3d.com/category/driversweeper/
You can also locate information about your driver using this information
http://www.sevenforums.com/tutorials/96442-device-manager-finding-unknown-devices.html
Please remove any CD virtualization programs such as Daemon Tools and Alcohol 120%. They use a driver, found in your dmp, sptd.sys, that is notorious for causing BSODs. Use this SPTD uninstaller when you're done:
http://www.duplexsecure.com/en/faq
