BSOD After Wake up from Sleep Mode
iboumiza
Here is my desktop config :
- Windows Vista x64 Service Pack 2
- NVIDIA GeForce 9500 GS
- Intel Quad Core 2 Q8200 2.33Ghz
I started recently receiving BSOD, so I reformated the PC and installed a fresh and clean Vista x64 SP 2, but nothing has stopped the BSOD from appearng everytime when I wake up to PC from sleep mode.
Attached you will find all the minidump files.
Thank you for your help, greatly appreciated
iboumiza
Shadowjk
Network Enthusiast
The problem will then be your Drivers or your Hardware do you Have the Latest Drivers for your Hardware?
Many Thanks,
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW ([email protected])
    Novatech Night
    Dell HID-compliant mouse
DustSailor
Did your computer come with driver software on a CD? I would install that first and update after. I had the problem of windows downloading the wrong driver automatically when I booted, so I had to go through and disable that and manually update through the website. Also, device manager may show if some drivers are not updated as they may be marked. I would check there as well. It may not just be your display driver, check the others as well as you mentioned this being a clean install, and everything will need updating.
    Self built home computer
    Nvidia
    On board sound
    5.14Mbps Download Speed, .65Mbps Upload Speed & 5ms Ping
Shadowjk
Network Enthusiast
First of all I have only started analysing BSOD's a couple of days ago and My theory could be wrong but winamp.exe or Winamp Media Player is a Possible problem by accessing memory that is Forbidden could you uninstall Winamp Media Player for me and Test your memory see Memtest86+ - Advanced Memory Diagnostic Tool for More information
DUMP CHECK
Code:
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced.  This cannot be protected by try-except,
it must be protected by a Probe.  Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: fffff900c06a3000, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff960000dffc3, If non-zero, the instruction address which referenced the bad memory
	address.
Arg4: 0000000000000000, (reserved)
Debugging Details:
Could not read faulting driver name
READ_ADDRESS:  fffff900c06a3000
FAULTING_IP:
win32k!RGNOBJ::bMerge+117
fffff960`000dffc3 418b08          mov     ecx,dword ptr [r8]
MM_INTERNAL_CODE:  0
CUSTOMER_CRASH_COUNT:  2
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0x50
PROCESS_NAME:  winamp.exe
CURRENT_IRQL:  0
TRAP_FRAME:  fffffa6009016170 -- (.trap 0xfffffa6009016170)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000001 rbx=0000000000000000 rcx=0000000000000000
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff960000dffc3 rsp=fffffa6009016300 rbp=fffff900c22a4490
 r8=fffff900c06a3000  r9=fffff900c22a449c r10=00000000ffffa66a
r11=fffff900c24ba208 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei pl zr na po nc
win32k!RGNOBJ::bMerge+0x117:
fffff960`000dffc3 418b08          mov     ecx,dword ptr [r8] ds:6310:fffff900`c06a3000=????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80001d0f8b0 to fffff80001cae4d0
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  win32k!RGNOBJ::bMerge+117
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: win32k
IMAGE_NAME:  win32k.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4c1f7191
FAILURE_BUCKET_ID:  X64_0x50_win32k!RGNOBJ::bMerge+117
Followup: MachineOwner
Full Dump Information:
Code:
Microsoft (R) Windows Debugger Version 6.12.0002.633 X86
Loading Dump File [C:\Users\Josh\Desktop\Mini081410-02.dmp]
Symbol search path is: SRV*C:\Symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (4 procs) Free x64
Built by: 6002.18267.amd64fre.vistasp2_gdr.100608-0458
Machine Name:
Kernel base = 0xfffff800`01c54000 PsLoadedModuleList = 0xfffff800`01e18dd0
Debug session time: Sat Aug 14 14:10:53.787 2010 (UTC + 1:00)
System Uptime: 0 days 0:03:56.857
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
Loading unloaded module list
BugCheck 50, {fffff900c06a3000, 0, fffff960000dffc3, 0}
Probably caused by : win32k.sys ( win32k!RGNOBJ::bMerge+117 )
3: kd> !analyze -v
Arguments:
	address.
Debugging Details:
FAULTING_IP:
MM_INTERNAL_CODE:  0
BUGCHECK_STR:  0x50
CURRENT_IRQL:  0
STACK_TEXT:
fffffa60`09016088 fffff800`01d0f8b0 : 00000000`00000050 fffff900`c06a3000 00000000`00000000 fffffa60`09016170 : nt!KeBugCheckEx
fffffa60`09016090 fffff800`01cad059 : 00000000`00000000 00000000`00000000 00000000`00000000 fffff900`c4200078 : nt! ?? ::FNODOBFM::`string'+0x2d3dc
fffffa60`09016170 fffff960`000dffc3 : fffff900`c24ba358 fffffa60`090163d0 00000000`00000000 00000000`08041249 : nt!KiPageFault+0x119
fffffa60`09016300 fffff960`000da0b0 : 00000000`00000001 00000000`00000001 00000000`000000a0 fffff960`00168808 : win32k!RGNOBJ::bMerge+0x117
fffffa60`09016350 fffff960`000d8707 : 00000000`00000000 00000000`08041249 00000000`08041249 fffff960`0012224c : win32k!RGNOBJ::iCombine+0x1cc
fffffa60`090163b0 fffff800`01cadf73 : 00000000`08041249 fffffa60`09016530 fffff960`0028184c 00000000`00000001 : win32k!GreCombineRgn+0x363
fffffa60`090164b0 00000000`75303d09 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`003ae158 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x75303d09
STACK_COMMAND:  kb
FOLLOWUP_IP:
MODULE_NAME: win32k
3: kd> !analyze -v
Arguments:
	address.
Debugging Details:
FAULTING_IP:
MM_INTERNAL_CODE:  0
BUGCHECK_STR:  0x50
CURRENT_IRQL:  0
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
MODULE_NAME: win32k
Make a Restore point before Doing anything
Hope This Helps,
Josh
    AMD HD Radeon 6870
    Novatech Night
richc46
STOP 0x00000050: PAGE_FAULT_IN_NONPAGED_AREA :Usual causes: Defective hardware (particularly memory - but not just RAM), Faulty system service, Antivirus, Device driver, NTFS corruption, BIOS
This is just the last File that you posted.
Josh has given you good advice. With memtes86, run for 6 passes and then take a known good stick and test the MB slots. I would wait a while before uninsalling Media Player.
If after completing the above step, you continue to get BSOD, uninstall your antivirus and install MSE, Micrsoft Security Essentials, at least for test purposes.
Check your hard drive, at the HD Manufacturer website.
Uninstall your virtualization programs: Daemnon or Alcohol 120%. KNown cause of BSODs. This driver SPTD is the cause and must be removed with the uninstall tool.
http://www.duplexsecure.com/en/downloads
Remove SPTD Do this now now.
sptd sptd.sys Sun Oct 11 16:55:14 2009
