Last few days i've been getting this BSOD. Happened twice now. Some google search said it could be harddrive issue?
If that's the case i need to know asap cause i've got about 1.4TB of data on it.
Probleemhandtekening:
Gebeurtenisnaam van probleem: BlueScreen
Versie van besturingssysteem: 6.0.6002.2.2.0.256.1
Landinstelling-id: 2067
Aanvullende informatie over dit probleem:
BCCode: c0000218
BCP1: FFFFF88004B84200
BCP2: 0000000000000000
BCP3: 0000000000000000
BCP4: 0000000000000000
OS Version: 6_0_6002
Service Pack: 2_0
Product: 256_1
Bestanden die helpen bij het beschrijven van het probleem:
C:\Windows\Minidump\Mini050714-01.dmp
C:\Users\Wim\AppData\Local\Temp\WER-172911-0.sysdata.xml <== couldn't find this one
C:\Users\Wim\AppData\Local\Temp\WER9D57.tmp.version.txt <== couldn't find this one
Lees onze privacyverklaring:
Privacyverklaring voor de Microsoft Error Reporting Service
some additional info:
Code:
http://rg.to/file/d18d32a51eaeabfe8d8fa273357d331a/Mini050714-01.dmp.html
BCCode: c0000218
Service Pack: 2_0
Product: 256_1
Error C0000218 (registry file failure)
Cannot load SYSTEMROOT\SYSTEM32\config\SOFTWARE or its log or alternate
It is corrupt, absent or not writeable
- custom
- Q5550
- Asus P5Q-E
- 8GB DDR2 400Mhz
- Graphics Card(s)
- GTX 680 DirectCU II OC 2GB
- onboard
- Asus VG278HR and HP w2448h
