BSOD during multiplayer games - ntoskrnl.exe
argh
Started getting many BSODs yesterday while playing multiplayer games. Nothing new was installed or modified recently. Many mentions of ntoskrnl.exe. I've scanned for system file integrity, and it passed. Updating to the latest NVIDIA drivers didn't do much. Here's the BlueScreenView Report. This computer has ran Vista x64 for a long time with no problems, then Windows 7 x64 (with many problems), and back to a clean install of Vista x64 (with a flawless record till today).
stoneys-nutz
Gamerholic
Hello argh,
Go to C > Windows > Minidump, zip up the dump files and upload them with your next post, you may have to save them to your desktop first.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
cpruett86
you may want to try downloading just the driver for your video card. What package are you trying to download? I just had the same problem with my ati radeon video cards. I ended up having to download just the driver with no other package options. And this solution worked for me the first time. What is the stop error you get?
http://www.vistax64.com/general-discussion/266731-vistax64-ulitmate-bsod-error-when-rendering-mp4-sony-vegas-pro-9-a-2.html
i also started getting bsod during multiplayer games toward the end of trying to figure out what was wrong.
    intel i7
    ati radeon 4800hd
    realtek hd
    22 in acer v223w
    150gb
    thermaltake custom
    ideazon reaper edge 3200dpi
    wolf king gaming keyboard
    cable
cpruett86
lol........ im guessing these issues are resolved?
    intel i7
    ati radeon 4800hd
    realtek hd
    22 in acer v223w
    150gb
    thermaltake custom
    cable
argh
The BSODs went away immediately after that and suddenly started again, with the only change being that I installed Lightroom. Had three BSODs today under the same scenarios (Minidumps).
stoneys-nutz
Gamerholic
argh,
I cant get on your hosting site, zip them up, and upload the dump files with your next post.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
argh
The upload may time out the first time, but there shouldn't be any problems retrieving the 100KB file after a second try. :)
Code:
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Windows\Minidump\Mini021510-01.dmp]
Symbol search path is: C:\Symbols
Executable search path is:
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows Server 2008/Windows Vista Kernel Version 6001 (Service Pack 1) MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0xfffff800`01c1c000 PsLoadedModuleList = 0xfffff800`01de1db0
Debug session time: Mon Feb 15 20:58:52.482 2010 (GMT-8)
System Uptime: 0 days 21:04:01.558
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 50, {fffffa6020d70685, 8, fffffa6020d70685, 2}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
***    Your debugger is not using the correct symbols                 ***
***    In order for this command to work properly, your symbol path   ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: nt!_KPRCB                                     ***
***    work.                                                          ***
***    Type referenced: nt!KPRCB                                      ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
Probably caused by : ntoskrnl.exe ( nt+546d0 )
Followup: MachineOwner
4: kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced.  This cannot be protected by try-except,
it must be protected by a Probe.  Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: fffffa6020d70685, memory referenced.
Arg2: 0000000000000008, value 0 = read operation, 1 = write operation.
Arg3: fffffa6020d70685, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
***    work.                                                          ***
ADDITIONAL_DEBUG_TEXT:
Use '!findthebuild' command to search for the target build information.
If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols.
MODULE_NAME: nt
FAULTING_MODULE: fffff80001c1c000 nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4b1e8eb8
WRITE_ADDRESS: unable to get nt!MmSpecialPoolStart
unable to get nt!MmSpecialPoolEnd
unable to get nt!MmPoolCodeStart
unable to get nt!MmPoolCodeEnd
 fffffa6020d70685
FAULTING_IP:
+0
fffffa60`20d70685 ??              ???
MM_INTERNAL_CODE:  2
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0x50
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80001c7e824 to fffff80001c706d0
STACK_TEXT:
fffffa60`01a67a68 fffff800`01c7e824 : 00000000`00000050 fffffa60`20d70685 00000000`00000008 fffffa60`01a67b60 : nt+0x546d0
fffffa60`01a67a70 00000000`00000050 : fffffa60`20d70685 00000000`00000008 fffffa60`01a67b60 00000000`00000002 : nt+0x62824
fffffa60`01a67a78 fffffa60`20d70685 : 00000000`00000008 fffffa60`01a67b60 00000000`00000002 00000000`00000000 : 0x50
fffffa60`01a67a80 00000000`00000008 : fffffa60`01a67b60 00000000`00000002 00000000`00000000 fffffa80`06618ae0 : 0xfffffa60`20d70685
fffffa60`01a67a88 fffffa60`01a67b60 : 00000000`00000002 00000000`00000000 fffffa80`06618ae0 00000000`00000004 : 0x8
fffffa60`01a67a90 00000000`00000002 : 00000000`00000000 fffffa80`06618ae0 00000000`00000004 fffffa60`01a67b60 : 0xfffffa60`01a67b60
fffffa60`01a67a98 00000000`00000000 : fffffa80`06618ae0 00000000`00000004 fffffa60`01a67b60 fffff800`01c81397 : 0x2
STACK_COMMAND:  kb
FOLLOWUP_IP:
nt+546d0
fffff800`01c706d0 48894c2408      mov     qword ptr [rsp+8],rcx
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt+546d0
FOLLOWUP_NAME:  MachineOwner
IMAGE_NAME:  ntoskrnl.exe
BUCKET_ID:  WRONG_SYMBOLS
niemiro
Banned
I have managed to get onto the hosting site, so I have attached the minidumps in case someone else cannot access them. Each of the three dump files are different, but they all reference the same file and address, ntoskrnl.exe, and they all happened at the same time.
STOP: 0x0000000a
IRQL_NOT_LESS_OR_EQUAL
Probable culprit driver: ntoskrnl.exe
STOP: 0x00000050
STOP: 0x000000c5
DRIVER_CORRUPTED_EXPOOL
Probable overall cause: Driver
I would really check and update ALL of your drivers in particular your grapics and network cards. Don't miss any out, and make sure your copy of Windows and your anti-virus is fully updated. Make sure the games you are playing, and lightroom, are also fully updated. It is also probably worth running a memory testing tool and chkdsk.
This may not be an option, but if you have a wireless network card, and an ethernet port, try the other one (ie. If you normally use the wireless card, use the ethernet port, and vice versa). Now disable the one you normally use, and try your multiplayer game again. Tell us how it goes, but it will probably just lead us to nowhere. Make sure you update the drivers for both of them.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
argh
Anyone know why the symbols aren't loading for the debugger? I tried several of the symbol packages that were closest to my configuration of Vista and none of them could load properly.
niemiro
Banned
Hi argh,
I don't know why the symbols are not loading, but for a simple analysis, Blue Screen View will do the job. Install it, open up advanced options and change to folder with your minidump in it. Then interpret it! IMPORTANT: If you post here for help, always include the minidump, not just your analysis.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
stoneys-nutz
Gamerholic
Are all your updates and both service packs installed ?.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
argh
As of right now I have everything updated (applications, drivers, BIOS) and service pack 2. Memtest revealed no errors after 10 hours. No BSODs.. for now.
stoneys-nutz
Gamerholic
Have you entered the correct symbol path ?.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
stoneys-nutz
Gamerholic
Copy and paste this into the debugger, go to File > symbol file path.
Symbol information
Two of the dump files had errors, i could not get all the symbols to load either, the third was OK.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
