Solved BSOD Error Help Needed Thanks
poncho
hello guys,
i'm using windows vista home premium 6.0 build 6000
on acer aspire 2930
bios: insydeh2o version v1.13
proc intel core2duo @2ghz
and 3gb ram
i've got some problem here
when i'm using ie or firefox, for a few minutes, when it's downloading files or just browsing, bsod appears
same thing while i'm using chrome, but in chrome it's an instant bsod a few seconds after i open the app
i'm doing fine while using ie or firefox or chrome while in safe mode, actually i'm using chrome right now
i've checked the driver using un*blue driver updater, and last night it took a while to upgrade all of the drivers, approximately 500mb, and thats still havent solve the problem
any clue guys? thanks :)
fyi. i havent installed any new application recently, that i knew of, but i dont know if my relatives did :|
and the app driver maybe causing this? i havent found any strange app running in the background though
Just to be clear. You have no problem in safe mode?
That is great news. It shows that there is nothing wrong with the computer. It is a software problem. We will concentrate on that area.
Did the problem begin after you installed new software or after recent MS updates?
If the answer is no or you do not know, and the problem just started go back a week before the problem with System Restore.
Are you updated to the most current SP, SP2. If not do so
Service Pack and Update Center - Microsoft Windows
icrosoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Loading Dump File [C:\Users\Richard\AppData\Local\Temp\Temp1_SF_09-12-2013.zip\SF_09-12-2013\Mini120913-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Vista Kernel Version 6000 MP (2 procs) Free x86 compatible
Built by: 6000.17021.x86fre.vista_gdr.100218-0019
Machine Name:
Kernel base = 0x82800000 PsLoadedModuleList = 0x82911e10
Debug session time: Sun Dec 8 11:40:22.442 2013 (UTC - 5:00)
System Uptime: 0 days 0:56:19.381
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 1000008E, {c0000005, c, af0ffcf0, 0}
Probably caused by : Unknown_Image ( ANALYSIS_INCONCLUSIVE )
Followup: MachineOwner
0: kd> !analyze -v
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: 0000000c, The address that the exception occurred at
Arg3: af0ffcf0, Trap Frame
Arg4: 00000000
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
FAULTING_IP:
+0
0000000c ?? ???
TRAP_FRAME: af0ffcf0 -- (.trap 0xffffffffaf0ffcf0)
ErrCode = 00000010
eax=00000102 ebx=804270e0 ecx=00000000 edx=00000000 esi=00000000 edi=00000000
eip=0000000c esp=af0ffd64 ebp=af0ffd64 iopl=0 nv up ei ng nz na po nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010282
0000000c ?? ???
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x8E
PROCESS_NAME: chrome.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from 0031e954 to 0000000c
STACK_TEXT:
WARNING: Frame IP not in any known module. Following frames may be wrong.
af0ffd60 0031e954 77ce0f34 badb0d00 0031e8e8 0xc
af0ffd64 77ce0f34 badb0d00 0031e8e8 00000000 0x31e954
af0ffd68 badb0d00 0031e8e8 00000000 00000000 0x77ce0f34
af0ffd6c 0031e8e8 00000000 00000000 00000000 0xbadb0d00
af0ffd70 00000000 00000000 00000000 00000000 0x31e8e8
STACK_COMMAND: .trap 0xffffffffaf0ffcf0 ; kb
SYMBOL_NAME: ANALYSIS_INCONCLUSIVE
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP: 0
BUCKET_ID: BAD_STACK
The above is what I can see from the file that you posted. I have bolded where the report indicates that the results are inconclusive, which is unusual
the truth is, my relatives's the one who used this computer for months, i didn't touch it for a while
no, system restore point is not set when i tried to do one. and for software installation, the last software installed here are by mid-year, so I thought maybe my relatives installed some apps or add ins causing this problem, maybe I'll ask them again if they remember anything :shock:
for the ms updates, this computer hasnt been updated for ages, couple days ago i just upgraded it to sp1, which is after i know there's been an error on the pc
for now i'll upgrade it to sp2 first and report if anything happens
thanks a lot :D
If you do not have updates.
Run a full antivirus scan
Download and run a full scan with Malwarebytes.
I say this, now just to help. it is not wise not to get the updates. Many of them are to prevent virus. Virus may be part of your problem. Get all the updates and get the most current SP.
it takes a while to download and installing sp1 and sp2,
and lots of security updates, so I left the PC to work while i'm finishing my work outside of the town,
i just got back, updates are all installed
i'm opening chrome, and *bam* no BSOD :D
i don't know if the problem is fully fixed or not until another BSOD appear,
let's hope they wont appear in the future :D
thank youuu for the help :)
MS says that all SPs should be installed, now you did that. I think that was the cause of your BSODs, glad that we could help
