32 bit Vista Home Premium gives the BSOD named in the title. It's an HP Pavilion and it is connected to a working modem via an ethernet cable.
Only gives the IRQL on a normal boot and even then it takes probably close to a minute before the BSOD. During that minute I can bring up taskmgr, I can see my desktop and all the icons and have even managed to at least initiate TDSSKiller. But after a minute- BSOD, and always the same one.
PC boots just fine in safe mode. And I have run Malwarebytes (quick scan only) and removed 408 items, 407 of which were PUP MyWebSearch errors and 1 Trojan. I did of course reboot afetr the scan, but I cannot get to the internet using Safe Mode with Networking. I get every browser's (IE, Firefox, Chrome) version of 'page cannot be displayed.
I have unchecked almost everything from the MSconfig startup, and disabled all non-MS services.
If I run Ipconfig from an elevated prompt, I have a good IP address. The version of mbam On the PC is outdated by 18 months, but it cannot be updated because of the connection issue.
From safe mode I have attempted 4 restores, going back as far as Oct/01/12. Every one of them has, on reboot told me that it didn't work because the restore files were corrupted.
I tried Last Good Config and Directory Services Restore to no avail - same BSOD.
I hit F11 (?) on boot to go into HP Diagnostics. It passed all 5 steps.
I used a Vista 32 bit Home Premium CD. It found the OS okay, and when I clicked on startup repair I was told it could find no problems.
Then I went to the command prompt and started a chkdsk /r. It hit stage 4 of 5 (without encountering any problems on stages 1-3), and has now been motionless for at least 45 minutes at 15% - 150001 of 158256 (obviously MS has never gotten around to fixing the percentage display, but the 150001 hasn't budged). OOps, now it has. Stage 4 (USN Journal Verification) Completed - no errors. It's about 30% through stage 5 now.
Any thoughts? I have little confidence that chkdsk will make a difference. Should I be running a full scan on a newer Malwarebytes? ComboFix? I did run TDSSKiller in safe mode and it found 0 problems, which I thought was weird, since that always seems to find something - even if it's nonsense.
Finshed chkdsk- no errors found and no change to boot IRQL problem
