BSOD/ Perfmon Report
cckck
I have been getting the BSOD off and on for a while now. I followed the steps posted by jcgriff2. Everything is attached. I have Vista. When I purchased my pc from a retailer in 2007 I also bought the upgrade software to Vista Ultimate. OS 32-bit. Please help!
richc46
Code:
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\richc46\AppData\Local\Temp\Temp17_Windows_NT6_BSOD_jcgriff2[1].zip\Windows_NT6_BSOD_jcgriff2\Mini010511-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 6002.18267.x86fre.vistasp2_gdr.100608-0458
Machine Name:
Kernel base = 0x82005000 PsLoadedModuleList = 0x8211cc70
Debug session time: Wed Jan  5 19:25:07.047 2011 (GMT-5)
System Uptime: 7 days 2:40:53.245
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck BE, {9de147b7, 8cc6f121, f5480484, b}
Probably caused by : RDPDD.dll ( RDPDD!SBCCacheBits+221 )
Followup: MachineOwner
0: kd> !analyze -v
ATTEMPTED_WRITE_TO_READONLY_MEMORY (be)
An attempt was made to write to readonly memory.  The guilty driver is on the
stack trace (and is typically the current instruction pointer).
When possible, the guilty driver's name (Unicode string) is printed on
the bugcheck screen and saved in KiBugCheckDriver.
Arguments:
Arg1: 9de147b7, Virtual address for the attempted write.
Arg2: 8cc6f121, PTE contents.
Arg3: f5480484, (reserved)
Arg4: 0000000b, (reserved)
Debugging Details:
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0xBE
PROCESS_NAME:  iexplore.exe
CURRENT_IRQL:  0
TRAP_FRAME:  f5480484 -- (.trap 0xfffffffff5480484)
ErrCode = 00000003
eax=f548055c ebx=00000040 ecx=ff4237e9 edx=00000084 esi=ff4237cc edi=ff419010
eip=9e9ded29 esp=f54804f8 ebp=f5480534 iopl=0         nv up ei pl nz na po nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010202
RDPDD!SBCCacheBits+0x221:
9e9ded29 833d600f9f9e04  cmp     dword ptr [RDPDD!SbcContext+0x18 (9e9f0f60)],4 ds:0023:9e9f0f60=????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from 82052dd4 to 8209d38d
STACK_TEXT:
f548046c 82052dd4 00000001 9de147b7 00000000 nt!MmAccessFault+0x10a
f548046c 9e9ded29 00000001 9de147b7 00000000 nt!KiTrap0E+0xdc
f5480534 9e9df69e fda20010 ff42a880 fdb720a0 RDPDD!SBCCacheBits+0x221
f54805c4 9e9da066 fda20010 f5480994 00480978 RDPDD!SBC_CacheBitmapTile+0x1aa
f5480910 9e9da28a fda20010 00000084 00000240 RDPDD!OETileBitBltOrder+0x162
f5480938 9e9d3e95 00000000 f548099c f5480978 RDPDD!OEEncodeMemBlt+0x100
f54809dc 9e7177e8 ff4a1b20 fd107ab0 00000000 RDPDD!DrvStretchBlt+0x2e5
f5480a78 9e7173ae ff4a1b20 fd107ab0 00000000 win32k!EngStretchBltROP+0x3ad
f5480b60 9e7822c5 00000000 9e71743b 00000000 win32k!BLTRECORD::bStretch+0x42e
f5480cd0 9e78245a 31010da4 00000001 00000001 win32k!GreStretchBltInternal+0x686
f5480d0c 8204fc7a 31010da4 00000001 00000001 win32k!GreStretchBlt+0x30
f5480d0c 77675e74 31010da4 00000001 00000001 nt!KiFastCallEntry+0x12a
WARNING: Frame IP not in any known module. Following frames may be wrong.
002be244 00000000 00000000 00000000 00000000 0x77675e74
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  RDPDD!SBCCacheBits+221
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: RDPDD
IMAGE_NAME:  RDPDD.dll
DEBUG_FLR_IMAGE_TIMESTAMP:  4791923e
FAILURE_BUCKET_ID:  0xBE_RDPDD!SBCCacheBits+221
0: kd> lmtsmn
start    end        module name
8e6da000 8e6e7080   1394BUS  1394BUS.SYS  Sat Jan 19 00:53:27 2008 (47919057)
8260b000 82651000   acpi     acpi.sys     Sat Apr 11 00:19:03 2009 (49E01A37)
904ff000 90547000   afd      afd.sys      Sat Apr 11 00:47:01 2009 (49E020C5)
833d9000 833e9000   amdk8    amdk8.sys    Sat Jan 19 00:27:20 2008 (47918A38)
a465d000 a4666000   asyncmac asyncmac.sys Sat Jan 19 00:56:29 2008 (4791910D)
82716000 8271e000   atapi    atapi.sys    Sat Apr 11 00:39:09 2009 (49E01EED)
8271e000 8273c000   ataport  ataport.SYS  Sat Apr 11 00:39:10 2009 (49E01EEE)
9e910000 9e95d000   ATMFD    ATMFD.DLL    unavailable (00000000)
8e94b000 8e94e000   BdaSup   BdaSup.SYS   Sat Jan 19 00:53:30 2008 (4791905A)
8fd76000 8fd7d000   Beep     Beep.SYS     Sat Jan 19 00:49:10 2008 (47918F56)
91d03000 91daf000   BHDrvx86 BHDrvx86.sys Mon Nov 15 17:35:02 2010 (4CE1B596)
8061f000 80627000   BOOTVID  BOOTVID.dll  Sat Jan 19 02:27:15 2008 (4791A653)
a3791000 a37aa000   bowser   bowser.sys   Sat Jan 19 00:28:26 2008 (47918A7A)
91c04000 91c83000   ccHPx86  ccHPx86.sys  Fri Feb 05 15:57:22 2010 (4B6C8632)
9e610000 9e61e000   cdd      cdd.dll      unavailable (00000000)
a478d000 a47a3000   cdfs     cdfs.sys     Sat Jan 19 00:28:02 2008 (47918A62)
8e906000 8e91e000   cdrom    cdrom.sys    Sat Apr 11 00:39:17 2009 (49E01EF5)
80668000 80748000   CI       CI.dll       Sat Apr 11 02:25:22 2009 (49E037D2)
8fcb2000 8fcc0000   circlass circlass.sys Sat Jan 19 00:53:24 2008 (47919054)
8a3ca000 8a3eb000   CLASSPNP CLASSPNP.SYS Sat Apr 11 00:39:05 2009 (49E01EE9)
80627000 80668000   CLFS     CLFS.SYS     Sat Apr 11 00:13:51 2009 (49E018FF)
91daf000 91dbc000   crashdmp crashdmp.sys Sat Apr 11 00:39:12 2009 (49E01EF0)
8a3eb000 8a3f4000   crcdisk  crcdisk.sys  Thu Nov 02 04:52:27 2006 (4549B1CB)
9151d000 91578000   csc      csc.sys      Sat Apr 11 00:14:49 2009 (49E01939)
91578000 9158f000   dfsc     dfsc.sys     Sat Apr 11 00:14:12 2009 (49E01914)
8a3b9000 8a3ca000   disk     disk.sys     Sat Apr 11 00:39:14 2009 (49E01EF2)
8e7b4000 8e7d9000   Dot4     Dot4.sys     Sat Jan 19 00:49:12 2008 (47918F58)
8fd7d000 8fd86000   Dot4Prt  Dot4Prt.sys  Sat Jan 19 00:49:09 2008 (47918F55)
8fdec000 8fdf9000   dot4usb  dot4usb.sys  Sat Jan 19 00:49:09 2008 (47918F55)
8fd4a000 8fd6f000   drmk     drmk.sys     Sat Jan 19 01:53:02 2008 (47919E4E)
91dbc000 91dc6000   dump_diskdump dump_diskdump.sys Sat Apr 11 00:39:11 2009 (49E01EEF)
91de3000 91df4000   dump_dumpfve dump_dumpfve.sys Sat Jan 19 00:27:05 2008 (47918A29)
91dc6000 91de3000   dump_nvstor32 dump_nvstor32.sys Fri Oct 26 14:50:16 2007 (472236E8)
91df4000 91dfe000   Dxapi    Dxapi.sys    Sat Jan 19 00:36:12 2008 (47918C4C)
8f923000 8f9c4000   dxgkrnl  dxgkrnl.sys  Thu Sep 24 21:27:14 2009 (4ABC1C72)
8a36e000 8a395000   ecache   ecache.sys   Sat Apr 11 00:40:12 2009 (49E01F2C)
914a2000 91500000   eeCtrl   eeCtrl.sys   Fri May 21 17:44:53 2010 (4BF6FED5)
91500000 9151d000   EraserUtilRebootDrv EraserUtilRebootDrv.sys Fri May 21 17:44:53 2010 (4BF6FED5)
8305b000 8306b000   fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
8279a000 827cc000   fltmgr   fltmgr.sys   Sat Apr 11 00:13:59 2009 (49E01907)
901f3000 901fc000   Fs_Rec   Fs_Rec.SYS   unavailable (00000000)
8a395000 8a3b9000   fvevol   fvevol.sys   Sat Apr 11 00:13:03 2009 (49E018CF)
8337c000 83397000   fwpkclnt fwpkclnt.sys Sat Apr 11 00:45:42 2009 (49E02076)
8e91e000 8e923280   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:16:53 2009 (4A1151B5)
823be000 823f1000   hal      halmacpi.dll Sat Apr 11 00:13:13 2009 (49E018D9)
8e6e8000 8e775000   HDAudBus HDAudBus.sys Sat Apr 11 00:42:41 2009 (49E01FC1)
904d2000 904e2000   HIDCLASS HIDCLASS.SYS Sat Apr 11 00:42:47 2009 (49E01FC7)
905db000 905e6000   hidir    hidir.sys    Sat Jan 19 00:53:18 2008 (4791904E)
8fd86000 8fd8c380   HIDPARSE HIDPARSE.SYS Sat Jan 19 00:53:16 2008 (4791904C)
904c9000 904d2000   hidusb   hidusb.sys   Sat Apr 11 00:42:48 2009 (49E01FC8)
8e608000 8e6bd000   HSX_CNXT HSX_CNXT.sys Thu May 08 16:04:13 2008 (48235CBD)
8e4c9000 8e5cb000   HSX_DP   HSX_DP.sys   Thu May 08 16:03:14 2008 (48235C82)
8e453000 8e49f000   HSXHWBS2 HSXHWBS2.sys Thu May 08 16:05:16 2008 (48235CFC)
a3707000 a3774000   HTTP     HTTP.sys     Sat Feb 20 15:53:31 2010 (4B804BCB)
91447000 914a2000   IDSvix86 IDSvix86.sys Fri Nov 05 17:11:46 2010 (4CD47312)
905a6000 905c5000   Ironx86  Ironx86.SYS  Tue Apr 27 20:47:15 2010 (4BD78593)
8fc9a000 8fca5000   kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
904f6000 904ff000   kbdhid   kbdhid.sys   Sat Apr 11 00:38:40 2009 (49E01ED0)
80607000 8060e000   kdcom    kdcom.dll    Sat Apr 11 02:25:29 2009 (49E037D9)
8e49f000 8e4c9000   ks       ks.sys       Sat Apr 11 00:38:47 2009 (49E01ED7)
830a2000 83113000   ksecdd   ksecdd.sys   Mon Jun 15 08:48:53 2009 (4A364335)
a36b0000 a36c0000   lltdio   lltdio.sys   Sat Jan 19 00:55:03 2008 (479190B7)
9159e000 915b9000   luafv    luafv.sys    Sat Jan 19 00:30:35 2008 (47918AFB)
a4666000 a4669180   mdmxsdk  mdmxsdk.sys  Mon Jun 19 17:26:59 2006 (449716A3)
8e6bd000 8e6ca000   modem    modem.sys    Sat Jan 19 00:57:16 2008 (4791913C)
9158f000 9159e000   monitor  monitor.sys  Thu Nov 02 04:54:05 2006 (4549B22D)
8fca5000 8fcb0000   mouclass mouclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
90565000 9056d000   mouhid   mouhid.sys   Sat Jan 19 00:49:16 2008 (47918F5C)
82706000 82716000   mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
a37aa000 a37bf000   mpsdrv   mpsdrv.sys   Sat Jan 19 00:54:45 2008 (479190A5)
a37bf000 a37e0000   mrxdav   mrxdav.sys   Sat Apr 11 00:14:39 2009 (49E0192F)
a37e0000 a37ff000   mrxsmb   mrxsmb.sys   Tue Feb 23 06:10:12 2010 (4B83B794)
915c1000 915fa000   mrxsmb10 mrxsmb10.sys Tue Feb 23 06:10:17 2010 (4B83B799)
8e5cb000 8e5e3000   mrxsmb20 mrxsmb20.sys Tue Feb 23 06:10:12 2010 (4B83B794)
8fdca000 8fdd5000   Msfs     Msfs.SYS     unavailable (00000000)
8265a000 82662000   msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
8f9d0000 8f9ff000   msiscsi  msiscsi.sys  Sat Apr 11 00:40:07 2009 (49E01F27)
83316000 83341000   msrpc    msrpc.sys    unavailable (00000000)
8fcc0000 8fcca000   mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
8a35f000 8a36e000   mup      mup.sys      Sat Apr 11 00:14:12 2009 (49E01914)
b774b000 b775e580   NAVENG   NAVENG.SYS   Mon Dec 13 20:42:27 2010 (4D06CB83)
b7600000 b774a900   NAVEX15  NAVEX15.SYS  Mon Dec 13 20:51:18 2010 (4D06CD96)
8320b000 83316000   ndis     ndis.sys     Sat Apr 11 00:45:52 2009 (49E02080)
8f1f4000 8f1ff000   ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
a36ea000 a36f4000   ndisuio  ndisuio.sys  Sat Jan 19 00:55:40 2008 (479190DC)
8e9c1000 8e9e4000   ndiswan  ndiswan.sys  Sat Apr 11 00:46:31 2009 (49E020A7)
8fd0c000 8fd1d000   NDProxy  NDProxy.SYS  Sat Jan 19 00:56:28 2008 (4791910C)
90585000 90593000   netbios  netbios.sys  Sat Jan 19 00:55:45 2008 (479190E1)
90497000 904c9000   netbt    netbt.sys    Sat Apr 11 00:45:35 2009 (49E0206F)
83341000 8337c000   NETIO    NETIO.SYS    Sat Apr 11 00:46:21 2009 (49E0209D)
91c83000 91d03000   netr73   netr73.sys   Tue Feb 26 04:17:28 2008 (47C3D928)
8fdd5000 8fde3000   Npfs     Npfs.SYS     Sat Apr 11 00:14:01 2009 (49E01909)
9143d000 91447000   nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
82005000 823be000   nt       ntkrpamp.exe Tue Jun 08 10:36:44 2010 (4C0E557C)
8a20e000 8a31e000   Ntfs     Ntfs.sys     Sat Apr 11 00:14:34 2009 (49E0192A)
90547000 9054f000   NuidFltr NuidFltr.sys Wed Aug 15 04:14:02 2007 (46C2B5CA)
8fd6f000 8fd76000   Null     Null.SYS     unavailable (00000000)
8f204000 8f922960   nvlddmkm nvlddmkm.sys Thu May 22 18:51:06 2008 (4835F8DA)
8e803000 8e905680   nvmfdx32 nvmfdx32.sys Thu May 03 20:41:02 2007 (463A811E)
8273c000 82759000   nvstor32 nvstor32.sys Fri Oct 26 14:50:16 2007 (472236E8)
a36c0000 a36ea000   nwifi    nwifi.sys    Sat Apr 11 00:43:27 2009 (49E01FEF)
8e6ca000 8e6d9300   ohci1394 ohci1394.sys Sat Apr 11 00:43:04 2009 (49E01FD8)
9054f000 90565000   pacer    pacer.sys    Sat Apr 11 00:45:51 2009 (49E0207F)
82689000 82698000   partmgr  partmgr.sys  Sat Apr 11 00:39:19 2009 (49E01EF7)
82662000 82689000   pci      pci.sys      Sat Apr 11 00:19:16 2009 (49E01A44)
826f1000 826f8000   pciide   pciide.sys   Sat Apr 11 00:39:10 2009 (49E01EEE)
826f8000 82706000   PCIIDEX  PCIIDEX.SYS  Sat Apr 11 00:39:09 2009 (49E01EED)
a466a000 a4748000   peauth   peauth.sys   Mon Oct 23 04:55:32 2006 (453C8384)
9057a000 90585000   point32k point32k.sys Wed Nov 08 02:02:38 2006 (4551810E)
8fd1d000 8fd4a000   portcls  portcls.sys  Sat Apr 11 00:42:48 2009 (49E01FC8)
8060e000 8061f000   PSHED    PSHED.dll    Sat Apr 11 02:25:32 2009 (49E037DC)
83098000 830a1300   PxHelp20 PxHelp20.sys Tue Jun 23 19:16:17 2009 (4A416241)
8fde3000 8fdec000   rasacd   rasacd.sys   Sat Jan 19 00:56:31 2008 (4791910F)
8f1dd000 8f1f4000   rasl2tp  rasl2tp.sys  Sat Jan 19 00:56:33 2008 (47919111)
8e9e4000 8e9f3000   raspppoe raspppoe.sys Sat Apr 11 00:46:30 2009 (49E020A6)
8e775000 8e789000   raspptp  raspptp.sys  Sat Jan 19 00:56:34 2008 (47919112)
8e789000 8e79e000   rassstp  rassstp.sys  Sat Apr 11 00:46:40 2009 (49E020B0)
91401000 9143d000   rdbss    rdbss.sys    Sat Apr 11 00:14:26 2009 (49E01922)
8fdba000 8fdc2000   RDPCDD   RDPCDD.sys   Sat Jan 19 01:01:08 2008 (47919224)
9e9d0000 9e9f6000   RDPDD    RDPDD.dll    Sat Jan 19 01:01:34 2008 (4791923E)
8fc01000 8fc8a000   rdpdr    rdpdr.sys    Sat Apr 11 00:52:32 2009 (49E02210)
8fdc2000 8fdca000   rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
b777b000 b77ae000   RDPWD    RDPWD.SYS    Sat Apr 11 00:51:22 2009 (49E021CA)
8e9f3000 8e9f9780   RimSerial RimSerial.sys Tue Jan 09 11:52:20 2007 (45A3C844)
8f1d5000 8f1dd000   RootMdm  RootMdm.sys  Sat Jan 19 00:57:14 2008 (4791913A)
a36f4000 a3707000   rspndr   rspndr.sys   Sat Jan 19 00:55:03 2008 (479190B7)
90000000 901f2940   RTKVHDA  RTKVHDA.sys  Tue Jan 15 06:18:36 2008 (478C968C)
a4748000 a4752000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
904e2000 904f6000   smb      smb.sys      Sat Apr 11 00:45:22 2009 (49E02062)
8a357000 8a35f000   spldr    spldr.sys    Thu Jun 21 20:29:17 2007 (467B17DD)
a3600000 a36b0000   spsys    spsys.sys    Tue Mar 10 13:10:28 2009 (49B69F04)
a47a3000 a47fa000   SRTSP    SRTSP.SYS    Wed Feb 24 18:54:51 2010 (4B85BC4B)
8e7ee000 8e7f7080   SRTSPX   SRTSPX.SYS   Wed Feb 24 18:55:07 2010 (4B85BC5B)
a460f000 a465d000   srv      srv.sys      Mon Sep 06 09:45:36 2010 (4C84F080)
83397000 833bf000   srv2     srv2.sys     Mon Sep 06 09:45:21 2010 (4C84F071)
a3774000 a3791000   srvnet   srvnet.sys   Mon Sep 06 09:45:18 2010 (4C84F06E)
82759000 8279a000   storport storport.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
8fcb0000 8fcb1380   swenum   swenum.sys   Sat Jan 19 00:49:20 2008 (47918F60)
83005000 8305b000   SYMDS    SYMDS.SYS    Mon Aug 17 19:34:39 2009 (4A89E90F)
8306b000 83098000   SYMEFA   SYMEFA.SYS   Wed Apr 21 17:46:52 2010 (4BCF724C)
90459000 9047e000   SYMEVENT SYMEVENT.SYS Thu Aug 13 18:22:41 2009 (4A849231)
9056d000 9057a000   SymIMv   SymIMv.sys   Fri Apr 30 22:02:30 2010 (4BDB8BB6)
90400000 90459000   SYMTDIV  SYMTDIV.SYS  Tue May 04 00:29:10 2010 (4BDFA296)
83113000 831fd000   tcpip    tcpip.sys    Wed Jun 16 09:45:41 2010 (4C18D585)
a4752000 a475e000   tcpipreg tcpipreg.sys Tue Dec 08 12:26:18 2009 (4B1E8C3A)
8f1ca000 8f1d5000   TDI      TDI.SYS      Sat Jan 19 00:57:10 2008 (47919136)
b7764000 b776f000   tdtcp    tdtcp.sys    Sat Jan 19 01:01:08 2008 (47919224)
8e79e000 8e7b4000   tdx      tdx.sys      Sat Apr 11 00:45:56 2009 (49E02084)
8fc8a000 8fc9a000   termdd   termdd.sys   Sat Apr 11 00:51:14 2009 (49E021C2)
9e8e0000 9e8e9000   TSDDD    TSDDD.dll    unavailable (00000000)
b776f000 b777b000   tssecsrv tssecsrv.sys Sat Jan 19 01:01:15 2008 (4791922B)
833d0000 833d9000   tunmp    tunmp.sys    Sat Jan 19 00:55:40 2008 (479190DC)
833c5000 833d0000   tunnel   tunnel.sys   Thu Feb 18 06:28:13 2010 (4B7D244D)
8fcca000 8fcd7000   umbus    umbus.sys    Sat Jan 19 00:53:40 2008 (47919064)
9047e000 90495000   usbccgp  usbccgp.sys  Sat Jan 19 00:53:29 2008 (47919059)
905c5000 905db000   usbcir   usbcir.sys   Sat Jan 19 00:53:25 2008 (47919055)
90495000 90496700   USBD     USBD.SYS     Sat Jan 19 00:53:17 2008 (4791904D)
8e444000 8e453000   usbehci  usbehci.sys  Sat Apr 11 00:42:52 2009 (49E01FCC)
8fcd7000 8fd0c000   usbhub   usbhub.sys   Sat Apr 11 00:43:14 2009 (49E01FE2)
833e9000 833f3000   usbohci  usbohci.sys  Sat Apr 11 00:42:52 2009 (49E01FCC)
8e406000 8e444000   USBPORT  USBPORT.SYS  Sat Apr 11 00:42:55 2009 (49E01FCF)
905f3000 905fd000   usbprint usbprint.sys Sat Jan 19 01:14:40 2008 (47919550)
905e6000 905f3000   usbscan  usbscan.sys  Sat Jan 19 01:14:09 2008 (47919531)
8e7d9000 8e7ee000   USBSTOR  USBSTOR.SYS  Sat Apr 11 00:42:55 2009 (49E01FCF)
8fd8d000 8fd99000   vga      vga.sys      Sat Jan 19 00:52:06 2008 (47919006)
8fd99000 8fdba000   VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
82698000 826a7000   volmgr   volmgr.sys   Sat Jan 19 00:49:51 2008 (47918F7F)
826a7000 826f1000   volmgrx  volmgrx.sys  Sat Apr 11 00:39:25 2009 (49E01EFD)
8a31e000 8a357000   volsnap  volsnap.sys  Sat Apr 11 00:39:37 2009 (49E01F09)
90593000 905a6000   wanarp   wanarp.sys   Sat Jan 19 00:56:31 2008 (4791910F)
8f9c4000 8f9d0000   watchdog watchdog.sys Sat Apr 11 00:22:43 2009 (49E01B13)
80748000 807c4000   Wdf01000 Wdf01000.sys Sat Jan 19 00:52:21 2008 (47919015)
807c4000 807d1000   WDFLDR   WDFLDR.SYS   Sat Jan 19 00:52:19 2008 (47919013)
9e6c0000 9e8c3000   win32k   win32k.sys   Mon Oct 18 09:31:09 2010 (4CBC4C1D)
82651000 8265a000   WMILIB   WMILIB.SYS   Sat Jan 19 00:53:08 2008 (47919044)
a4773000 a4785000   WUDFPf   WUDFPf.sys   Sat Jan 19 00:52:49 2008 (47919031)
a475e000 a4772580   WUDFRd   WUDFRd.sys   Sat Jan 19 00:53:04 2008 (47919040)
a4785000 a478d000   xaudio   xaudio.sys   Thu Oct 18 18:36:53 2007 (4717E005)
8e924000 8e94a500   xcbda    xcbda.sys    Fri Sep 07 14:36:07 2007 (46E19A17)
8e94e000 8e9c1000   xcfe     xcfe.sys     Fri Sep 07 14:35:06 2007 (46E199DA)
8ec04000 8f172000   xchal    xchal.sys    Fri Sep 07 14:33:46 2007 (46E1998A)
8f172000 8f1ca000   xcmem    xcmem.sys    Fri Sep 07 14:32:37 2007 (46E19945)
Unloaded modules:
91447000 914a2000   IDSvix86.sys
    Timestamp: unavailable (00000000)
    Checksum:  00000000
b77ae000 b77b8000   hiber_storpo
    Checksum:  00000000
b77b8000 b77d5000   hiber_nvstor
    Checksum:  00000000
b77d5000 b77e6000   hiber_dumpfv
    Checksum:  00000000
b774b000 b775f000   NAVENG.SYS
    Checksum:  00000000
b7600000 b774b000   NAVEX15.SYS
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
b77e6000 b77f4000   usbaapl.sys
    Checksum:  00000000
b77ae000 b77bc000   wpdusb.sys
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
    Checksum:  00000000
Outdated Drivers Update
Code:
The reports that you have submitted reveal clues to the cause of your problem. They do not give a definitive answer. The more reports that we receive the more clues are made available improving our chances of finding a solution to your problem. Each remedy suggested must be performed regardless of placement in this report or other variables. You may have to experience several more BSODs until the final answer is discovered.
If overclocking restore normal settings
SFC /scannow
System Files - SFC Command
Scan with your Anti Virus
Update outdated listed drivers. If I have inadvertently listed any Microsoft Drivers, they can be ignored.
How to Find Drivers
search Google for the name of the driver
- compare the Google results with what's installed on your system to figure out which device/program it belongs to
- visit the web site of the manufacturer of the hardware/program to get the latest drivers (DON'T use Windows Update or the Update driver function of Device Manager).
- if there are difficulties in locating them, post back with questions and someone - will help you search Google for the name of the driver
- - if there are difficulties in locating them, post back with questions and someone will try and help you locate the appropriate program.
- The most common drivers are listed on this page: http://www.carrona.org/dvrref.html
- - Driver manufacturer links are on this page: http://www.carrona.org/drvrdown.html
and here
http://www.edbott.com/weblog/the-vista-master-driver-list/
To remove any left over driver remnants, especially from graphics cards, use driver sweeper
www.guru3d.com/category/driversweeper/
You can also locate information about your driver using this information
http://www.sevenforums.com/tutorials/96442-device-manager-finding-unknown-devices.html
Download memtest86 and test RAM
www.sevenforums.com/tutorials/105647-ram-test-memtest86.html
Run for 8 passes
If passes try a good stick in each slot for 3 passes
If fails do the same for 8 passes.
Run the upgrade advisor to help discover hardware problems
www.microsoft.com/Windows/windows-7/get/upgrade-advisor.aspx
After performing all of the above, post back with any new BSOD reports, or indicate that the attempted repairs were successful.
If any links do not work, if clicked, please copy and paste to browser address bar.
It is very important to remember that the dump reports only give clues as to the problem and although it is very easy to analyze only one or two, usually more are needed. If you experience additional BSOD after installing a current version of the driver in question, be sure to post so that we can use the additional information to assist you in preventing the BSOD's
