Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\richc46\AppData\Local\Temp\Temp1_Windows_NT6_BSOD_jcgriff2 (1).zip\Windows_NT6_BSOD_jcgriff2\Mini052711-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 6002.18327.amd64fre.vistasp2_gdr.101014-0432
Machine Name:
Kernel base = 0xfffff800`02a53000 PsLoadedModuleList = 0xfffff800`02c17dd0
Debug session time: Thu May 26 18:47:59.399 2011 (GMT-4)
System Uptime: 0 days 0:00:35.070
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 1, {77876cba, 0, fffe, fffffa60063c8ca0}
Probably caused by : ntkrnlmp.exe ( nt!KiSystemServiceExit+209 )
Followup: MachineOwner
1: kd> !analyze -v
APC_INDEX_MISMATCH (1)
This is a kernel internal error. The most common reason to see this
bugcheck is when a filesystem or a driver has a mismatched number of
calls to disable and re-enable APCs. The key data item is the
Thread->KernelApcDisable field. A negative value indicates that a driver
has disabled APC calls without re-enabling them. A positive value indicates
that the reverse is true. This check is made on exit from a system call.
Arguments:
Arg1: 0000000077876cba, address of system function (system call)
Arg2: 0000000000000000, Thread->ApcStateIndex << 8 | Previous ApcStateIndex
Arg3: 000000000000fffe, Thread->KernelApcDisable
Arg4: fffffa60063c8ca0, Previous KernelApcDisable
Debugging Details:
FAULTING_IP:
+0
00000000`77876cba ?? ???
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x1
PROCESS_NAME: services.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff80002aad22e to fffff80002aad490
STACK_TEXT:
fffffa60`063c8ad8 fffff800`02aad22e : 00000000`00000001 00000000`77876cba 00000000`00000000 00000000`0000fffe : nt!KeBugCheckEx
fffffa60`063c8ae0 fffff800`02aad144 : 00000000`0031f388 fffffa60`00080000 00000000`0031f430 00000000`00000000 : nt!KiBugCheckDispatch+0x6e
fffffa60`063c8c20 00000000`77876cba : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0x209
00000000`0031f348 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x77876cba
STACK_COMMAND: kb
FOLLOWUP_IP:
fffff800`02aad144 4883ec50 sub rsp,50h
SYMBOL_STACK_INDEX: 2
SYMBOL_NAME: nt!KiSystemServiceExit+209
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4cb7275f
FAILURE_BUCKET_ID: X64_0x1_nt!KiSystemServiceExit+209
1: kd> !analyze -v
Arguments:
Debugging Details:
FAULTING_IP:
+0
BUGCHECK_STR: 0x1
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
MODULE_NAME: nt
1: kd> lmtsmn
start end module name
fffffa60`04b82000 fffffa60`04b91f00 1394BUS 1394BUS.SYS Sat Jan 19 01:34:04 2008 (479199DC)
fffffa60`0080c000 fffffa60`00862000 acpi acpi.sys Sat Apr 11 01:03:26 2009 (49E0249E)
fffffa60`07205000 fffffa60`07270000 afd afd.sys Sat Apr 11 01:44:21 2009 (49E02E35)
fffffa60`05842000 fffffa60`05856000 amdiox64 amdiox64.sys Thu Feb 18 10:17:53 2010 (4B7D5A21)
fffffa60`055f6000 fffffa60`055fe000 [B]ASACPI ASACPI.sys Mon Oct 30 22:09:12 2006[/B] (4546B048)
fffffa60`07270000 fffffa60`0727a000 aswRdr aswRdr.SYS Thu Jan 13 03:37:32 2011 (4D2EB9CC)
fffffa60`0599e000 fffffa60`059e7000 aswSP aswSP.SYS Thu Jan 13 03:41:42 2011 (4D2EBAC6)
fffffa60`06ddb000 fffffa60`06deb000 aswTdi aswTdi.SYS Thu Jan 13 03:40:19 2011 (4D2EBA73)
fffffa60`009ac000 fffffa60`009b4000 atapi atapi.sys Sat Apr 11 01:34:19 2009 (49E02BDB)
fffffa60`009b4000 fffffa60`009d8000 ataport ataport.SYS Sat Apr 11 01:34:25 2009 (49E02BE1)
fffffa60`058f2000 fffffa60`05912000 AtihdLH6 AtihdLH6.sys Wed Nov 17 07:01:27 2010 (4CE3C417)
fffffa60`04c02000 fffffa60`05439000 atikmdag atikmdag.sys Tue Jan 04 21:48:52 2011 (4D23DC14)
fffffa60`04a0d000 fffffa60`04a5a000 atikmpag atikmpag.sys Tue Jan 04 21:19:38 2011 (4D23D53A)
fffffa60`011f7000 fffffa60`011ff000 AtiPcie AtiPcie.sys Tue May 05 11:00:22 2009 (4A005486)
fffffa60`06c07000 fffffa60`06ceea00 CamDrL64 CamDrL64.sys Sat Feb 03 13:17:27 2007 (45C4D1B7)
fffff960`00650000 fffff960`00661000 cdd cdd.dll unavailable (00000000)
fffffa60`055cd000 fffffa60`055e9000 cdrom cdrom.sys Sat Apr 11 01:34:39 2009 (49E02BEF)
fffffa60`0067b000 fffffa60`0072d000 CI CI.dll Sat Apr 11 03:08:09 2009 (49E041D9)
fffffa60`00dcf000 fffffa60`00dfb000 CLASSPNP CLASSPNP.SYS Sat Apr 11 01:34:15 2009 (49E02BD7)
fffffa60`0061e000 fffffa60`0067b000 CLFS CLFS.SYS Sat Apr 11 00:54:21 2009 (49E0227D)
fffffa60`0744f000 fffffa60`0745d000 crashdmp crashdmp.sys Sat Apr 11 01:34:31 2009 (49E02BE7)
fffffa60`00c00000 fffffa60`00c0a000 crcdisk crcdisk.sys Sat Jan 19 01:30:12 2008 (479198F4)
fffffa60`0735f000 fffffa60`073d5000 csc csc.sys Sat Apr 11 00:56:24 2009 (49E022F8)
fffffa60`073d5000 fffffa60`073f2000 dfsc dfsc.sys Sat Apr 11 00:54:44 2009 (49E02294)
fffffa60`011e3000 fffffa60`011f7000 disk disk.sys Sat Apr 11 01:34:38 2009 (49E02BEE)
fffffa60`0594d000 fffffa60`05970000 drmk drmk.sys Sat Jan 19 02:20:04 2008 (4791A4A4)
fffffa60`07469000 fffffa60`07471000 dump_atapi dump_atapi.sys Sat Apr 11 01:34:19 2009 (49E02BDB)
fffffa60`0745d000 fffffa60`07469000 dump_dumpata dump_dumpata.sys Sat Apr 11 01:34:22 2009 (49E02BDE)
fffffa60`07471000 fffffa60`07484000 dump_dumpfve dump_dumpfve.sys Sat Jan 19 00:52:25 2008 (47919019)
fffffa60`07484000 fffffa60`07490000 Dxapi Dxapi.sys Sat Jan 19 01:08:00 2008 (479193C0)
fffffa60`05439000 fffffa60`0551c000 dxgkrnl dxgkrnl.sys Thu Jan 20 09:09:42 2011 (4D384226)
fffffa60`00fa5000 fffffa60`00fd1000 ecache ecache.sys Sat Apr 11 01:36:18 2009 (49E02C52)
fffffa60`00a4d000 fffffa60`00a61000 fileinfo fileinfo.sys Sat Jan 19 01:05:23 2008 (47919323)
fffffa60`00a06000 fffffa60`00a4d000 fltmgr fltmgr.sys Sat Apr 11 00:54:38 2009 (49E0228E)
fffffa60`06d41000 fffffa60`06d4b000 Fs_Rec Fs_Rec.SYS Sat Jan 19 00:53:41 2008 (47919065)
fffffa60`00fd1000 fffffa60`00ffa000 fvevol fvevol.sys Sat Apr 11 00:52:54 2009 (49E02226)
fffffa60`00f79000 fffffa60`00fa5000 fwpkclnt fwpkclnt.sys Sat Apr 11 01:42:44 2009 (49E02DD4)
fffffa60`055e9000 fffffa60`055f6000 GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`02a0d000 fffff800`02a53000 hal hal.dll Sat Apr 11 03:04:56 2009 (49E04118)
fffffa60`04a5a000 fffffa60`04b47000 HDAudBus HDAudBus.sys Sat Apr 11 01:39:38 2009 (49E02D1A)
fffffa60`06d11000 fffffa60`06d23000 HIDCLASS HIDCLASS.SYS Sat Apr 11 01:39:32 2009 (49E02D14)
fffffa60`06d23000 fffffa60`06d2ab80 HIDPARSE HIDPARSE.SYS Sat Jan 19 01:33:51 2008 (479199CF)
fffffa60`06d08000 fffffa60`06d11000 hidusb hidusb.sys Sat Apr 11 01:39:32 2009 (49E02D14)
fffffa60`0094b000 fffffa60`0096b000 jraid jraid.sys Mon Jan 11 06:28:18 2010 (4B4B0B52)
fffffa60`057f0000 fffffa60`057fe000 kbdclass kbdclass.sys Sat Jan 19 01:28:05 2008 (47919875)
fffffa60`06d2b000 fffffa60`06d36000 kbdhid kbdhid.sys Sat Apr 11 01:33:40 2009 (49E02BB4)
fffffa60`00600000 fffffa60`0060a000 kdcom kdcom.dll Thu Feb 24 11:04:07 2011 (4D668177)
fffffa60`0580e000 fffffa60`05842000 ks ks.sys Sat Apr 11 01:33:51 2009 (49E02BBF)
fffffa60`00a61000 fffffa60`00ae8000 ksecdd ksecdd.sys Mon Jun 15 09:15:18 2009 (4A364966)
fffffa60`05970000 fffffa60`05975180 ksthunk ksthunk.sys Sat Jan 19 01:28:14 2008 (4791987E)
fffffa60`06be8000 fffffa60`06bf4980 LVUSBS64 LVUSBS64.sys Sat Feb 03 13:05:16 2007 (45C4CEDC)
fffffa60`07490000 fffffa60`074a3000 monitor monitor.sys Sat Jan 19 01:32:34 2008 (47919982)
fffffa60`05600000 fffffa60`0560c000 mouclass mouclass.sys Sat Jan 19 01:28:05 2008 (47919875)
fffffa60`06d36000 fffffa60`06d41000 mouhid mouhid.sys Sat Jan 19 01:28:10 2008 (4791987A)
fffffa60`00999000 fffffa60`009ac000 mountmgr mountmgr.sys Sat Jan 19 01:28:01 2008 (47919871)
fffffa60`06d99000 fffffa60`06da4000 Msfs Msfs.SYS Sat Jan 19 00:53:55 2008 (47919073)
fffffa60`0086b000 fffffa60`00875000 msisadrv msisadrv.sys Sat Jan 19 01:02:50 2008 (4791928A)
fffffa60`0560d000 fffffa60`05646000 msiscsi msiscsi.sys Sat Apr 11 01:36:09 2009 (49E02C49)
fffffa60`00ae8000 fffffa60`00b38000 msrpc msrpc.sys Sat Apr 11 01:32:13 2009 (49E02B5D)
fffffa60`05856000 fffffa60`05861000 mssmbios mssmbios.sys Sat Jan 19 01:02:54 2008 (4791928E)
fffffa60`011d1000 fffffa60`011e3000 mup mup.sys Sat Apr 11 00:54:47 2009 (49E02297)
fffffa60`00c0c000 fffffa60`00dcf000 ndis ndis.sys Sat Apr 11 01:43:15 2009 (49E02DF3)
fffffa60`056d3000 fffffa60`056df000 ndistapi ndistapi.sys Sat Jan 19 01:37:22 2008 (47919AA2)
fffffa60`056df000 fffffa60`05710000 ndiswan ndiswan.sys Sat Apr 11 01:43:39 2009 (49E02E0B)
fffffa60`058d1000 fffffa60`058e5000 NDProxy NDProxy.SYS Sat Jan 19 01:37:26 2008 (47919AA6)
fffffa60`072dc000 fffffa60`072eb000 netbios netbios.sys Sat Jan 19 01:36:35 2008 (47919A73)
fffffa60`0727a000 fffffa60`072be000 netbt netbt.sys Sat Apr 11 01:42:31 2009 (49E02DC7)
fffffa60`00b38000 fffffa60`00b91000 NETIO NETIO.SYS Sat Apr 11 01:43:34 2009 (49E02E06)
fffffa60`06da4000 fffffa60`06db5000 Npfs Npfs.SYS Sat Apr 11 00:54:22 2009 (49E0227E)
fffffa60`07353000 fffffa60`0735f000 nsiproxy nsiproxy.sys Sat Jan 19 01:36:45 2008 (47919A7D)
fffff800`02a53000 fffff800`02f6b000 nt ntkrnlmp.exe Thu Oct 14 11:53:03 2010 (4CB7275F)
fffffa60`01005000 fffffa60`01185000 Ntfs Ntfs.sys Sat Apr 11 00:55:38 2009 (49E022CA)
fffffa60`06d4b000 fffffa60`06d54000 Null Null.SYS Thu Nov 02 05:37:15 2006 (4549BC4B)
fffffa60`05871000 fffffa60`05889000 nusb3hub nusb3hub.sys Thu Jan 21 22:22:18 2010 (4B5919EA)
fffffa60`0552c000 fffffa60`0555c000 nusb3xhc nusb3xhc.sys Thu Jan 21 22:22:21 2010 (4B5919ED)
fffffa60`04b70000 fffffa60`04b81b00 ohci1394 ohci1394.sys Sat Apr 11 01:39:49 2009 (49E02D25)
fffffa60`072be000 fffffa60`072dc000 pacer pacer.sys Sat Apr 11 01:42:56 2009 (49E02DE0)
fffffa60`008a5000 fffffa60`008ba000 partmgr partmgr.sys Sat Apr 11 01:34:51 2009 (49E02BFB)
fffffa60`00875000 fffffa60`008a5000 pci pci.sys Sat Apr 11 01:03:33 2009 (49E024A5)
fffffa60`00934000 fffffa60`0093b000 pciide pciide.sys Sat Apr 11 01:34:28 2009 (49E02BE4)
fffffa60`0093b000 fffffa60`0094b000 PCIIDEX PCIIDEX.SYS Sat Apr 11 01:34:22 2009 (49E02BDE)
fffffa60`05912000 fffffa60`0594d000 portcls portcls.sys Sat Apr 11 01:39:36 2009 (49E02D18)
fffffa60`00bdb000 fffffa60`00bee000 processr processr.sys Sat Jan 19 00:52:45 2008 (4791902D)
fffffa60`0060a000 fffffa60`0061e000 PSHED PSHED.dll Sat Apr 11 03:08:17 2009 (49E041E1)
fffffa60`06db5000 fffffa60`06dbe000 rasacd rasacd.sys Sat Jan 19 01:37:30 2008 (47919AAA)
fffffa60`056b0000 fffffa60`056d3000 rasl2tp rasl2tp.sys Sat Apr 11 01:43:37 2009 (49E02E09)
fffffa60`05710000 fffffa60`05720000 raspppoe raspppoe.sys Sat Apr 11 01:43:33 2009 (49E02E05)
fffffa60`05720000 fffffa60`0573e000 raspptp raspptp.sys Sat Apr 11 01:43:38 2009 (49E02E0A)
fffffa60`0573e000 fffffa60`05756000 rassstp rassstp.sys Sat Apr 11 01:43:46 2009 (49E02E12)
fffffa60`07306000 fffffa60`07353000 rdbss rdbss.sys Sat Apr 11 00:55:21 2009 (49E022B9)
fffffa60`06d87000 fffffa60`06d90000 RDPCDD RDPCDD.sys Sat Jan 19 01:42:04 2008 (47919BBC)
fffffa60`05756000 fffffa60`057f0000 rdpdr rdpdr.sys Sat Apr 11 01:49:54 2009 (49E02F82)
fffffa60`06d90000 fffffa60`06d99000 rdpencdd rdpencdd.sys Sat Jan 19 01:42:03 2008 (47919BBB)
fffffa60`04b92000 fffffa60`04bde000 Rtlh64 Rtlh64.sys Mon Feb 08 22:53:28 2010 (4B70DC38)
fffffa60`0096b000 fffffa60`00999000 SCSIPORT SCSIPORT.SYS Sat Jan 19 01:28:52 2008 (479198A4)
fffffa60`04b64000 fffffa60`04b70000 serenum serenum.sys Sat Jan 19 01:28:36 2008 (47919894)
fffffa60`04b47000 fffffa60`04b64000 serial serial.sys Sat Jan 19 01:28:41 2008 (47919899)
fffffa60`05983000 fffffa60`0599e000 smb smb.sys Sat Apr 11 01:42:19 2009 (49E02DBB)
fffffa60`011c9000 fffffa60`011d1000 spldr spldr.sys Mon Jan 12 16:51:29 2009 (496BBB61)
fffffa60`05646000 fffffa60`056a3000 storport storport.sys Sat Apr 11 01:34:45 2009 (49E02BF5)
fffffa60`057fe000 fffffa60`057ff480 swenum swenum.sys Thu Nov 02 05:37:33 2006 (4549BC5D)
fffffa60`00e03000 fffffa60`00f79000 tcpip tcpip.sys Wed Jun 16 10:51:56 2010 (4C18E50C)
fffffa60`056a3000 fffffa60`056b0000 TDI TDI.SYS Sat Apr 11 01:44:14 2009 (49E02E2E)
fffffa60`06dbe000 fffffa60`06ddb000 tdx tdx.sys Sat Apr 11 01:43:00 2009 (49E02DE4)
fffffa60`04be7000 fffffa60`04bfa000 termdd termdd.sys Sat Apr 11 01:48:13 2009 (49E02F1D)
fffff960`00480000 fffff960`0048a000 TSDDD TSDDD.dll Sat Jan 19 01:42:04 2008 (47919BBC)
fffffa60`00bd2000 fffffa60`00bdb000 tunmp tunmp.sys Sat Jan 19 01:36:30 2008 (47919A6E)
fffffa60`00bc6000 fffffa60`00bd2000 tunnel tunnel.sys Sat Jan 19 01:36:44 2008 (47919A7C)
fffffa60`07401000 fffffa60`0744f000 udfs udfs.sys Sat Apr 11 00:54:21 2009 (49E0227D)
fffffa60`05861000 fffffa60`05871000 umbus umbus.sys Sat Jan 19 01:34:16 2008 (479199E8)
fffffa60`06cef000 fffffa60`06d07280 usbaudio usbaudio.sys Sat Apr 11 01:39:34 2009 (49E02D16)
fffffa60`06bb4000 fffffa60`06bd0000 usbccgp usbccgp.sys Sat Jan 19 01:34:04 2008 (479199DC)
fffffa60`0555c000 fffffa60`0555de00 USBD USBD.SYS Sat Jan 19 01:33:53 2008 (479199D1)
fffffa60`055bc000 fffffa60`055cd000 usbehci usbehci.sys Sat Apr 11 01:39:36 2009 (49E02D18)
fffffa60`0555e000 fffffa60`0556b000 usbfilter usbfilter.sys Wed Oct 07 03:44:08 2009 (4ACC46C8)
fffffa60`05889000 fffffa60`058d1000 usbhub usbhub.sys Sat Apr 11 01:39:52 2009 (49E02D28)
fffffa60`0556b000 fffffa60`05576000 usbohci usbohci.sys Sat Apr 11 01:39:36 2009 (49E02D18)
fffffa60`05576000 fffffa60`055bc000 USBPORT USBPORT.SYS Sat Apr 11 01:39:39 2009 (49E02D1B)
fffffa60`06bd0000 fffffa60`06be8000 USBSTOR USBSTOR.SYS Sat Apr 11 01:39:38 2009 (49E02D1A)
fffffa60`06d54000 fffffa60`06d62000 vga vga.sys Sat Jan 19 01:32:21 2008 (47919975)
fffffa60`06a03000 fffffa60`06bb4000 viahduaa viahduaa.sys Tue Mar 02 06:30:18 2010 (4B8CF6CA)
fffffa60`06d62000 fffffa60`06d87000 VIDEOPRT VIDEOPRT.SYS Sat Jan 19 01:32:25 2008 (47919979)
fffffa60`008ba000 fffffa60`008ce000 volmgr volmgr.sys Sat Apr 11 01:34:49 2009 (49E02BF9)
fffffa60`008ce000 fffffa60`00934000 volmgrx volmgrx.sys Sat Apr 11 01:35:14 2009 (49E02C12)
fffffa60`01185000 fffffa60`011c9000 volsnap volsnap.sys Sat Apr 11 01:35:33 2009 (49E02C25)
fffffa60`072eb000 fffffa60`07306000 wanarp wanarp.sys Sat Apr 11 01:43:38 2009 (49E02E0A)
fffffa60`0551c000 fffffa60`0552c000 watchdog watchdog.sys Sat Apr 11 01:09:16 2009 (49E025FC)
fffffa60`0072d000 fffffa60`007d1000 Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffffa60`007d1000 fffffa60`007e0000 WDFLDR WDFLDR.SYS Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff960`000b0000 fffff960`00366000 win32k win32k.sys Thu Mar 03 08:46:14 2011 (4D6F9BA6)
fffffa60`04bde000 fffffa60`04be7000 wmiacpi wmiacpi.sys Sat Jan 19 01:02:42 2008 (47919282)
fffffa60`00862000 fffffa60`0086b000 WMILIB WMILIB.SYS Sat Jan 19 01:33:45 2008 (479199C9)
