Interestingly, the debugger can't locate symbols for the pshed.dll file (which is one of the files that processes the hardware error). This could point to an issue with the OS itself. Is this a legitimate installation of Windows that's been activated through Microsoft? If so, I'd run SFC.EXE /SCANNOW from an elevated command prompt to see if it's fixable.
This is another STOP 0x124 error and occurred due to hardware while operating in CoDWaWmp.exe Lot's of issues on the web with cracked copies - is this the case with your copy? If not, then we're back to suspecting either the networking drivers, or the network devices themselves.
To test, disable your wired connection in Device Manager and only use the wireless for a day or two. Then switch around, disabling the wireless and only using the wired connection for a day or two.
Here's the memory dump file:
Code:
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\FUBAR-RC1-Desktop\TempDUMP\DATA\01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (4 procs) Free x64
Built by: 6002.18005.amd64fre.lh_sp2rtm.090410-1830
Machine Name:
Kernel base = 0xfffff800`02415000 PsLoadedModuleList = 0xfffff800`025d9dd0
Debug session time: Sun Jul 5 10:53:14.904 2009 (GMT-4)
System Uptime: 0 days 0:03:50.646
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 124, {0, fffffa8005875030, f2000008, 2000e0f}
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: pshed!_WHEA_ERROR_RECORD_HEADER ***
*** work. ***
*** Type referenced: pshed!_WHEA_ERROR_RECORD_SECTION_DESCRIPTOR ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : hardware
Followup: MachineOwner
3: kd> !thread;!analyze -v;r;kv;lmtn;lmtsmn;.bugcheck;.logclose;q
GetPointerFromAddress: unable to read from fffff8000263c000
THREAD fffffa800668abb0 Cid 0ff8.07c0 Teb: 000000007ef97000 Win32Thread: 0000000000000000 RUNNING on processor 3
Not impersonating
GetUlongFromAddress: unable to read from fffff800025bbc00
Owning Process fffffa8006f4f040 Image: CoDWaWmp.exe
Attached Process N/A Image: N/A
fffff78000000000: Unable to get shared data
Wait Start TickCount 14761
Context Switch Count 885
ReadMemory error: Cannot get nt!KeMaximumIncrement value.
UserTime 00:00:00.000
KernelTime 00:00:00.000
Win32 Start Address 0x000000006ebf9fca
Stack Init fffffa6007b5bdb0 Current fffffa6007b5baa0
Base fffffa6007b5c000 Limit fffffa6007b56000 Call 0
Priority 8 BasePriority 8 PriorityDecrement 0 IoPriority 2 PagePriority 5
Child-SP RetAddr : Args to Child : Call Site
fffffa60`019df958 fffff800`029348ba : 00000000`00000124 00000000`00000000 fffffa80`05875030 00000000`f2000008 : nt!KeBugCheckEx
fffffa60`019df960 fffff800`02536033 : 00000000`00000001 00000000`00000001 00000000`00000000 00000000`00000001 : hal!HalBugCheckSystem+0x12e
fffffa60`019df9d0 fffff800`029341bc : fffffa60`00000c3e fffffa60`019dfbb0 fffffa60`019dfc30 00000000`00000000 : nt!WheaReportHwError+0x243
fffffa60`019dfa30 fffff800`0246e6b1 : 00000000`177cfafc fffffa60`019dfc30 00000000`00000003 00000000`00000000 : hal!HalpMcaExceptionHandler+0x114
fffffa60`019dfa70 fffff800`0246e4f5 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x71
fffffa60`019dfbb0 00000000`6ea35313 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0xf5 (TrapFrame @ fffffa60`019dfbb0)
00000000`177cf88c 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x6ea35313
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa8005875030, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000f2000008, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000002000e0f, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
BUGCHECK_STR: 0x124_GenuineIntel
DEFAULT_BUCKET_ID: VERIFIER_ENABLED_VISTA_MINIDUMP
PROCESS_NAME: CoDWaWmp.exe
CURRENT_IRQL: f
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: hardware
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_GenuineIntel_VRF__UNKNOWN
rax=0000000002000e0f rbx=fffffa8005875030 rcx=0000000000000124
rdx=0000000000000000 rsi=fffffa8005875150 rdi=0000000000000002
rip=fffff8000246f450 rsp=fffffa60019df958 rbp=fffffa8005875000
r8=fffffa8005875030 r9=00000000f2000008 r10=dbf3c493f1165eb6
r11=fffff8000292d000 r12=fffffa80027fe690 r13=fffffa80057ffbc0
r14=fffffa80027fc9c8 r15=0000000075053380
iopl=0 nv up ei pl nz na pe nc
cs=0010 ss=0000 ds=002b es=002b fs=0053 gs=002b efl=00000202
nt!KeBugCheckEx:
fffff800`0246f450 48894c2408 mov qword ptr [rsp+8],rcx ss:fffffa60`019df960=0000000000000124
start end module name
fffff800`02415000 fffff800`0292d000 nt ntkrnlmp.exe Sat Apr 11 00:58:39 2009 (49E0237F)
fffff800`0292d000 fffff800`02973000 hal hal.dll Sat Apr 11 03:04:56 2009 (49E04118)
fffff960`00030000 fffff960`002e1000 win32k win32k.sys Tue Apr 21 08:03:41 2009 (49EDB61D)
fffff960`004c0000 fffff960`004ca000 TSDDD TSDDD.dll unavailable (00000000)
fffff960`00620000 fffff960`00631000 cdd cdd.dll Sat Apr 11 03:03:49 2009 (49E040D5)
fffffa60`00605000 fffffa60`0060f000 kdcom kdcom.dll Sat Apr 11 03:07:57 2009 (49E041CD)
fffffa60`0060f000 fffffa60`0064a000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Apr 11 03:05:41 2009 (49E04145)
fffffa60`0064a000 fffffa60`0065e000 PSHED PSHED.dll Sat Apr 11 03:08:17 2009 (49E041E1)
fffffa60`0065e000 fffffa60`006bb000 CLFS CLFS.SYS Sat Apr 11 00:54:21 2009 (49E0227D)
fffffa60`006bb000 fffffa60`0076d000 CI CI.dll Sat Apr 11 03:08:09 2009 (49E041D9)
fffffa60`0076d000 fffffa60`007d3000 volmgrx volmgrx.sys Sat Apr 11 01:35:14 2009 (49E02C12)
fffffa60`007d3000 fffffa60`007f7000 ataport ataport.SYS Sat Apr 11 01:34:25 2009 (49E02BE1)
fffffa60`0080d000 fffffa60`008e7000 Wdf01000 Wdf01000.sys Sat Jan 19 01:33:27 2008 (479199B7)
fffffa60`008e7000 fffffa60`008f5000 WDFLDR WDFLDR.SYS Sat Jan 19 01:32:33 2008 (47919981)
fffffa60`008f5000 fffffa60`0094b000 acpi acpi.sys Sat Apr 11 01:03:26 2009 (49E0249E)
fffffa60`0094b000 fffffa60`00954000 WMILIB WMILIB.SYS Sat Jan 19 01:33:45 2008 (479199C9)
fffffa60`00954000 fffffa60`0095e000 msisadrv msisadrv.sys Sat Jan 19 01:02:50 2008 (4791928A)
fffffa60`0095e000 fffffa60`0098e000 pci pci.sys Sat Apr 11 01:03:33 2009 (49E024A5)
fffffa60`0098e000 fffffa60`009a3000 partmgr partmgr.sys Sat Apr 11 01:34:51 2009 (49E02BFB)
fffffa60`009a3000 fffffa60`009b7000 volmgr volmgr.sys Sat Apr 11 01:34:49 2009 (49E02BF9)
fffffa60`009b7000 fffffa60`009be000 pciide pciide.sys Sat Apr 11 01:34:28 2009 (49E02BE4)
fffffa60`009be000 fffffa60`009ce000 PCIIDEX PCIIDEX.SYS Sat Apr 11 01:34:22 2009 (49E02BDE)
fffffa60`009ce000 fffffa60`009e1000 mountmgr mountmgr.sys Sat Jan 19 01:28:01 2008 (47919871)
fffffa60`009e1000 fffffa60`009e9000 atapi atapi.sys Sat Apr 11 01:34:19 2009 (49E02BDB)
fffffa60`009e9000 fffffa60`009f9000 nvstor nvstor.sys Wed Jun 06 16:34:00 2007 (46671A38)
fffffa60`00a06000 fffffa60`00a63000 storport storport.sys Sat Apr 11 01:34:45 2009 (49E02BF5)
fffffa60`00a63000 fffffa60`00a8f000 nvstor64 nvstor64.sys Wed Nov 12 19:57:58 2008 (491B7B96)
fffffa60`00a8f000 fffffa60`00ad6000 fltmgr fltmgr.sys Sat Apr 11 00:54:38 2009 (49E0228E)
fffffa60`00ad6000 fffffa60`00aea000 fileinfo fileinfo.sys Sat Jan 19 01:05:23 2008 (47919323)
fffffa60`00aea000 fffffa60`00b70000 ksecdd ksecdd.sys Sat Apr 11 01:21:49 2009 (49E028ED)
fffffa60`00b70000 fffffa60`00bc0000 msrpc msrpc.sys Sat Apr 11 01:32:13 2009 (49E02B5D)
fffffa60`00bc0000 fffffa60`00bec000 ecache ecache.sys Sat Apr 11 01:36:18 2009 (49E02C52)
fffffa60`00c0f000 fffffa60`00dd2000 ndis ndis.sys Sat Apr 11 01:43:15 2009 (49E02DF3)
fffffa60`00dd2000 fffffa60`00dfe000 fwpkclnt fwpkclnt.sys Sat Apr 11 01:42:44 2009 (49E02DD4)
fffffa60`00e0c000 fffffa60`00e65000 NETIO NETIO.SYS Sat Apr 11 01:43:34 2009 (49E02E06)
fffffa60`00e65000 fffffa60`00fda000 tcpip tcpip.sys Sat Apr 11 01:44:47 2009 (49E02E4F)
fffffa60`00fda000 fffffa60`00fee000 disk disk.sys Sat Apr 11 01:34:38 2009 (49E02BEE)
fffffa60`01000000 fffffa60`0100e000 vga vga.sys Sat Jan 19 01:32:21 2008 (47919975)
fffffa60`0100e000 fffffa60`0118e000 Ntfs Ntfs.sys Sat Apr 11 00:55:38 2009 (49E022CA)
fffffa60`0118e000 fffffa60`011d2000 volsnap volsnap.sys Sat Apr 11 01:35:33 2009 (49E02C25)
fffffa60`011d2000 fffffa60`011da000 spldr spldr.sys Mon Jan 12 16:51:29 2009 (496BBB61)
fffffa60`011da000 fffffa60`011e1000 speedfan speedfan.sys Sun Sep 24 09:26:48 2006 (45168798)
fffffa60`011e1000 fffffa60`011f3000 mup mup.sys Sat Apr 11 00:54:47 2009 (49E02297)
fffffa60`01200000 fffffa60`01209000 Null Null.SYS Thu Nov 02 05:37:15 2006 (4549BC4B)
fffffa60`0120c000 fffffa60`01238000 CLASSPNP CLASSPNP.SYS Sat Apr 11 01:34:15 2009 (49E02BD7)
fffffa60`01238000 fffffa60`01242000 crcdisk crcdisk.sys Sat Jan 19 01:30:12 2008 (479198F4)
fffffa60`01242000 fffffa60`0125e000 cdfs cdfs.sys Sat Jan 19 00:53:45 2008 (47919069)
fffffa60`01264000 fffffa60`01270000 tunnel tunnel.sys Sat Jan 19 01:36:44 2008 (47919A7C)
fffffa60`01270000 fffffa60`01279000 tunmp tunmp.sys Sat Jan 19 01:36:30 2008 (47919A6E)
fffffa60`01279000 fffffa60`0128c000 intelppm intelppm.sys Sat Jan 19 00:52:45 2008 (4791902D)
fffffa60`0128c000 fffffa60`0129c000 watchdog watchdog.sys Sat Apr 11 01:09:16 2009 (49E025FC)
fffffa60`0129c000 fffffa60`012a9000 fdc fdc.sys Sat Jan 19 01:28:45 2008 (4791989D)
fffffa60`012a9000 fffffa60`012c5000 parport parport.sys Sat Jan 19 01:28:36 2008 (47919894)
fffffa60`012c5000 fffffa60`012db000 i8042prt i8042prt.sys Sat Jan 19 01:28:08 2008 (47919878)
fffffa60`012db000 fffffa60`012e9000 kbdclass kbdclass.sys Sat Jan 19 01:28:05 2008 (47919875)
fffffa60`012e9000 fffffa60`01306000 serial serial.sys Sat Jan 19 01:28:41 2008 (47919899)
fffffa60`01306000 fffffa60`01312000 serenum serenum.sys Sat Jan 19 01:28:36 2008 (47919894)
fffffa60`01312000 fffffa60`0131d000 usbohci usbohci.sys Sat Apr 11 01:39:36 2009 (49E02D18)
fffffa60`0131d000 fffffa60`01363000 USBPORT USBPORT.SYS Sat Apr 11 01:39:39 2009 (49E02D1B)
fffffa60`01363000 fffffa60`01374000 usbehci usbehci.sys Sat Apr 11 01:39:36 2009 (49E02D18)
fffffa60`01374000 fffffa60`01390000 cdrom cdrom.sys Sat Apr 11 01:34:39 2009 (49E02BEF)
fffffa60`01390000 fffffa60`013a1b00 ohci1394 ohci1394.sys Sat Apr 11 01:39:49 2009 (49E02D25)
fffffa60`013a2000 fffffa60`013b1f00 1394BUS 1394BUS.SYS Sat Jan 19 01:34:04 2008 (479199DC)
fffffa60`013b2000 fffffa60`013fa000 usbhub usbhub.sys Sat Apr 11 01:39:52 2009 (49E02D28)
fffffa60`02e03000 fffffa60`03919680 nvlddmkm nvlddmkm.sys Wed Jun 10 10:31:48 2009 (4A2FC3D4)
fffffa60`0391a000 fffffa60`0391b180 nvBridge nvBridge.kmd Wed Jun 10 09:24:21 2009 (4A2FB405)
fffffa60`0391c000 fffffa60`039fd000 dxgkrnl dxgkrnl.sys Sat Apr 11 01:10:13 2009 (49E02635)
fffffa60`03c06000 fffffa60`03cf3000 HDAudBus HDAudBus.sys Sat Apr 11 01:39:38 2009 (49E02D1A)
fffffa60`03cf3000 fffffa60`03d24000 ndiswan ndiswan.sys Sat Apr 11 01:43:39 2009 (49E02E0B)
fffffa60`03d24000 fffffa60`03d42000 raspptp raspptp.sys Sat Apr 11 01:43:38 2009 (49E02E0A)
fffffa60`03d42000 fffffa60`03d5a000 rassstp rassstp.sys Sat Apr 11 01:43:46 2009 (49E02E12)
fffffa60`03d5a000 fffffa60`03d6d000 termdd termdd.sys Sat Apr 11 01:48:13 2009 (49E02F1D)
fffffa60`03d6d000 fffffa60`03d6e480 swenum swenum.sys Thu Nov 02 05:37:33 2006 (4549BC5D)
fffffa60`03d6f000 fffffa60`03da3000 ks ks.sys Sat Apr 11 01:33:51 2009 (49E02BBF)
fffffa60`03da3000 fffffa60`03dae000 mssmbios mssmbios.sys Sat Jan 19 01:02:54 2008 (4791928E)
fffffa60`03dae000 fffffa60`03dbe000 umbus umbus.sys Sat Jan 19 01:34:16 2008 (479199E8)
fffffa60`03dbe000 fffffa60`03dc9000 flpydisk flpydisk.sys Sat Jan 19 01:28:45 2008 (4791989D)
fffffa60`03dc9000 fffffa60`03ddd000 NDProxy NDProxy.SYS Sat Jan 19 01:37:26 2008 (47919AA6)
fffffa60`03ddd000 fffffa60`03e00000 drmk drmk.sys Sat Jan 19 02:20:04 2008 (4791A4A4)
fffffa60`03e01000 fffffa60`03f6d180 nvmfdx64 nvmfdx64.sys Fri Aug 01 14:38:28 2008 (48935824)
fffffa60`03f6e000 fffffa60`03fa7000 msiscsi msiscsi.sys Sat Apr 11 01:36:09 2009 (49E02C49)
fffffa60`03fa7000 fffffa60`03fb4000 TDI TDI.SYS Sat Apr 11 01:44:14 2009 (49E02E2E)
fffffa60`03fb4000 fffffa60`03fd7000 rasl2tp rasl2tp.sys Sat Apr 11 01:43:37 2009 (49E02E09)
fffffa60`03fd7000 fffffa60`03fe3000 ndistapi ndistapi.sys Sat Jan 19 01:37:22 2008 (47919AA2)
fffffa60`03fe3000 fffffa60`03ff3000 raspppoe raspppoe.sys Sat Apr 11 01:43:33 2009 (49E02E05)
fffffa60`03ff3000 fffffa60`03fff000 mouclass mouclass.sys Sat Jan 19 01:28:05 2008 (47919875)
fffffa60`04609000 fffffa60`0462e000 VIDEOPRT VIDEOPRT.SYS Sat Jan 19 01:32:25 2008 (47919979)
fffffa60`0462e000 fffffa60`04637000 hidusb hidusb.sys Sat Apr 11 01:39:32 2009 (49E02D14)
fffffa60`04637000 fffffa60`04649000 HIDCLASS HIDCLASS.SYS Sat Apr 11 01:39:32 2009 (49E02D14)
fffffa60`04649000 fffffa60`04650b80 HIDPARSE HIDPARSE.SYS Sat Jan 19 01:33:51 2008 (479199CF)
fffffa60`04651000 fffffa60`04652e00 USBD USBD.SYS Sat Jan 19 01:33:53 2008 (479199D1)
fffffa60`04653000 fffffa60`0465e000 mouhid mouhid.sys Sat Jan 19 01:28:10 2008 (4791987A)
fffffa60`0465e000 fffffa60`04667000 RDPCDD RDPCDD.sys Sat Jan 19 01:42:04 2008 (47919BBC)
fffffa60`04667000 fffffa60`04670000 rdpencdd rdpencdd.sys Sat Jan 19 01:42:03 2008 (47919BBB)
fffffa60`04670000 fffffa60`0467b000 Msfs Msfs.SYS Sat Jan 19 00:53:55 2008 (47919073)
fffffa60`0467b000 fffffa60`0468c000 Npfs Npfs.SYS Sat Apr 11 00:54:22 2009 (49E0227E)
fffffa60`0468c000 fffffa60`04695000 rasacd rasacd.sys Sat Jan 19 01:37:30 2008 (47919AAA)
fffffa60`04695000 fffffa60`046b2000 tdx tdx.sys Sat Apr 11 01:43:00 2009 (49E02DE4)
fffffa60`046b2000 fffffa60`046cd000 smb smb.sys Sat Apr 11 01:42:19 2009 (49E02DBB)
fffffa60`046cd000 fffffa60`046de000 aswTdi aswTdi.SYS Thu Feb 05 16:06:22 2009 (498B54CE)
fffffa60`046de000 fffffa60`04749000 afd afd.sys Sat Apr 11 01:44:21 2009 (49E02E35)
fffffa60`04749000 fffffa60`04752000 aswRdr aswRdr.SYS Thu Feb 05 16:06:11 2009 (498B54C3)
fffffa60`04752000 fffffa60`04796000 netbt netbt.sys Sat Apr 11 01:42:31 2009 (49E02DC7)
fffffa60`04796000 fffffa60`047b4000 pacer pacer.sys Sat Apr 11 01:42:56 2009 (49E02DE0)
fffffa60`047b4000 fffffa60`047bf000 rtlprot rtlprot.sys Fri Apr 20 05:16:48 2007 (46288500)
fffffa60`047bf000 fffffa60`047ce000 netbios netbios.sys Sat Jan 19 01:36:35 2008 (47919A73)
fffffa60`047ce000 fffffa60`047e9000 wanarp wanarp.sys Sat Apr 11 01:43:38 2009 (49E02E0A)
fffffa60`04800000 fffffa60`0480a000 Fs_Rec Fs_Rec.SYS Sat Jan 19 00:53:41 2008 (47919065)
fffffa60`0480c000 fffffa60`049bce80 RTKVHD64 RTKVHD64.sys Tue Jun 16 06:12:51 2009 (4A377023)
fffffa60`049bd000 fffffa60`049f8000 portcls portcls.sys Sat Apr 11 01:39:36 2009 (49E02D18)
fffffa60`049f8000 fffffa60`049fd180 ksthunk ksthunk.sys Sat Jan 19 01:28:14 2008 (4791987E)
fffffa60`04a03000 fffffa60`04a50000 rdbss rdbss.sys Sat Apr 11 00:55:21 2009 (49E022B9)
fffffa60`04a50000 fffffa60`04a5c000 nsiproxy nsiproxy.sys Sat Jan 19 01:36:45 2008 (47919A7D)
fffffa60`04a5c000 fffffa60`04a79000 dfsc dfsc.sys Sat Apr 11 00:54:44 2009 (49E02294)
fffffa60`04a79000 fffffa60`04a95000 aswSP aswSP.SYS Thu Feb 05 16:07:35 2009 (498B5517)
fffffa60`04a95000 fffffa60`04af3000 wg111v3 wg111v3.sys Fri Dec 28 01:59:29 2007 (47749ED1)
fffffa60`04af3000 fffffa60`04b01000 crashdmp crashdmp.sys Sat Apr 11 01:34:31 2009 (49E02BE7)
fffffa60`04b01000 fffffa60`04b0d000 dump_dumpata dump_dumpata.sys Sat Apr 11 01:34:22 2009 (49E02BDE)
fffffa60`04b0d000 fffffa60`04b15000 dump_atapi dump_atapi.sys Sat Apr 11 01:34:19 2009 (49E02BDB)
fffffa60`04b15000 fffffa60`04b21000 Dxapi Dxapi.sys Sat Jan 19 01:08:00 2008 (479193C0)
fffffa60`04b21000 fffffa60`04b34000 monitor monitor.sys Sat Jan 19 01:32:34 2008 (47919982)
fffffa60`04b34000 fffffa60`04b56000 luafv luafv.sys Sat Jan 19 00:59:06 2008 (479191AA)
fffffa60`04b56000 fffffa60`04b70000 aswMonFlt aswMonFlt.sys Thu Feb 05 16:07:05 2009 (498B54F9)
fffffa60`04b70000 fffffa60`04b79000 aswFsBlk aswFsBlk.sys Thu Feb 05 16:07:15 2009 (498B5503)
fffffa60`04b79000 fffffa60`04b97000 bowser bowser.sys Sat Jan 19 00:54:51 2008 (479190AB)
fffffa60`04b97000 fffffa60`04bbe000 mrxdav mrxdav.sys Sat Apr 11 00:55:42 2009 (49E022CE)
fffffa60`04bbe000 fffffa60`04be7000 mrxsmb mrxsmb.sys Sat Apr 11 00:55:33 2009 (49E022C5)
fffffa60`0840d000 fffffa60`084a7000 spsys spsys.sys Tue Mar 10 13:16:43 2009 (49B6A07B)
fffffa60`084a7000 fffffa60`084bb000 lltdio lltdio.sys Sat Jan 19 01:35:48 2008 (47919A44)
fffffa60`084bb000 fffffa60`084ef000 nwifi nwifi.sys Sat Apr 11 01:40:19 2009 (49E02D43)
fffffa60`084ef000 fffffa60`084fa000 ndisuio ndisuio.sys Sat Jan 19 01:36:29 2008 (47919A6D)
fffffa60`084fa000 fffffa60`08512000 rspndr rspndr.sys Sat Jan 19 01:35:48 2008 (47919A44)
fffffa60`08512000 fffffa60`0851d000 asyncmac asyncmac.sys Sat Jan 19 01:37:27 2008 (47919AA7)
fffffa60`0851d000 fffffa60`085bc000 HTTP HTTP.sys Sat Apr 11 01:42:20 2009 (49E02DBC)
fffffa60`085bc000 fffffa60`085e5000 srvnet srvnet.sys Sat Apr 11 00:57:28 2009 (49E02338)
fffffa60`085e5000 fffffa60`085ff000 mpsdrv mpsdrv.sys Sat Jan 19 01:35:28 2008 (47919A30)
fffffa60`08c04000 fffffa60`08c4d000 mrxsmb10 mrxsmb10.sys Sat Apr 11 00:55:23 2009 (49E022BB)
fffffa60`08c4d000 fffffa60`08c6c000 mrxsmb20 mrxsmb20.sys Sat Apr 11 00:55:26 2009 (49E022BE)
fffffa60`08c6c000 fffffa60`08c9e000 srv2 srv2.sys Sat Apr 11 00:57:35 2009 (49E0233F)
fffffa60`08c9e000 fffffa60`08d2f000 srv srv.sys Sat Apr 11 00:57:52 2009 (49E02350)
fffffa60`08d2f000 fffffa60`08de5000 peauth peauth.sys Mon Oct 23 07:57:00 2006 (453CAE0C)
fffffa60`08de5000 fffffa60`08df0000 secdrv secdrv.SYS Wed Sep 13 09:18:38 2006 (4508052E)
fffffa60`08df0000 fffffa60`08e00000 tcpipreg tcpipreg.sys Sat Apr 11 01:43:04 2009 (49E02DE8)
Unloaded modules:
fffffa60`01242000 fffffa60`01250000 crashdmp.sys
Timestamp: unavailable (00000000)
Checksum: 00000000
fffffa60`01250000 fffffa60`0125c000 dump_ataport
Checksum: 00000000
fffffa60`0125c000 fffffa60`01264000 dump_atapi.s
Checksum: 00000000
Unloaded modules:
Checksum: 00000000
Checksum: 00000000
Checksum: 00000000
Bugcheck code 00000124
Arguments 00000000`00000000 fffffa80`05875030 00000000`f2000008 00000000`02000e0f
